Question about Pool & Spa
Wiring diagram for a Century 1.5 HP single phase motor (6-321358-01)
115 volt and 230 volt wiring diagrams
thepool
  • 78 Answers
SOURCE: need wiring diagram for a marathon electric motor
Wiring diagrams for AO Smith motors are located on the side of the motor.
Posted on Apr 21, 2010
john224
  • 1378 Answers
SOURCE: I am looking for a wiring diagram for the three
Thank you for posting your question here on Fixya.com.
I sent the number to my AOSmith tech contact. I hope to have it monday sometime. Please contact me thru our site, www.arrowmotor.net, so I have your email address to forward the connection diagram to.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 13, 2010
  • 221 Answers
SOURCE: i have a sta rite 1 hp 115/230 motor i cant find
I assume you mean the white wire under the rear motor cover? If so Sta-Rite puts a wiring diagram inside this back cover. Hopefully it is still intact for you. Depending on your model and if it is wired for 115vac or 220vac will make a difference. I would suggest you go to the link I attached and look up your manual. The manual will have the wiring diagram for you.
http://www.starite.com/
I hope this helps you out. Please rate my response. thanks
Posted on Jun 17, 2010
john224
  • 1378 Answers
SOURCE: My pool originally had a
Is it going to run on 230V then? If so you would normally use red and black. The white wire should be a neutral and the ground wire is obviously ground.
Do you have a meter you can use to confirm the voltage between the wires? If you do you'll want to start with red and white since you seem to think black was not being used before. If the voltage reads 230 and the motor is set up for 230 then attach one wire to L1 and the other to L2...it will not matter which is connected where as long as one is on each terminal. Insulate the black and ground the ground lead to the motor ground screw.
If the voltage is not 230 between those two check between red and black. If that is the 230 then insulate white and put red and black to L1 and L2.
John
Posted on May 24, 2011
  • 368 Answers
SOURCE: need wiring diagram for BN34
Usually the wiring diagram is on the nameplat of the motor. I hope this helps.
Posted on Aug 16, 2011
I have a 1 1/2 hp 230/110 marathon single phase motor controlled by forward reversing starters with 24 volt controlled. How do I wire this motor up for for/rev ???
You need to determine at which voltage you will run this motor. A motor starter mechanically and electrically interlocked for F & R. with 24v transformer, a SS and FR station. This is expensive but sweet, needs room for this equipment.
The easy budget is by using a drum switch.
The motor nameplate or splice box cover will hand the info on how to connect the motor for either voltage and for CW and CCW rotation.
The magnetic motor starter also will include a wiring diagram.
Nov 04, 2017 | HP Air Tools & Compressors
Need wiring diagram for switching volts on a century magnetek 5hp air compressor
What is the model number? Most of the Century 5 HP motors are 220 Volt single phase. What did you want to change it to?
Aug 15, 2014 | Air Tools & Compressors
Wire 230 volt air compressor wiring diagrams
On 230 volts you have 3 wires 2 are 115 volt and the third wire is ground. As long as you hook the ground wires together correctly the other wires don't matter. Usually the ground wire is either white or green. The black wires are hot (115 volts).
Feb 11, 2014 | Air Tools & Compressors
SINGLE PHASE WIRING DIGRAM
You need a single phase motor to do that. A 3 phase motor cannot be made to run on one phase.
May 16, 2013 | Ingersoll Rand - Rand Type - 30...
Need wireing diagram for AO Smith 1HP motor S#C56A97B08 Ser32409J2
less hassle replace whole pump if motor over heated possible bad seals and distortion to pump housing will leak
Dec 04, 2017 | Pool & Spa
I need wiring diagram for Gould Century Pump motor 1081 Part # 8-142776-20 1HP 230v/120v
www.bestbuypoolsupply.com/media/motormanual.pdf
This manual has the wiring diagrams both hi and lo voltage for
part # 8- 142776 -20 gould century 1081m 1 hp , pool pump motor 230/115 volts.... plus several similar motors
May 25, 2012 | Plumbing
Century single phase 2 hp 3450 rpm type cs motor Frame f56
the motor is on 220 volts ,i like hook that up on 120 volts ,,thanks
May 10, 2012 | Air Tools & Compressors
Trying to rewire my ingersoll rand air compressor motor, psi switch motor starter, need some kind of diagram, it has a 5hp single phase 220
Please check out the Web Site Below. It is a Quick Start manual for IR Compressors.
It should have everything you need. It DOES NOT Show you any wiring connections AT the motor.
Hope this helps....Jim
http://www.irtechpubs.com/ir_pdfs/Compressed%20Air/Air%20Compressors/Reciprocating%20Compressor/80445703.PDF
Feb 18, 2011 | Ingersoll Rand - Rand Type - 30...
I want to reverse rotation on my A.O. Smith 120/230 volt single phase 1.5 HP motor. Catalog number B762
I believe all you have to do is swap your two hot wires,that works for 3-phase but not sure on single phase
Oct 07, 2010 | AO Smith 1 1/2 HP 115/230V 56C Replacement...
I have a gould century 1 hp motor i need it to run on 115 and it had previously been tried at 230,i had it running for a sec but it isnt right ......i need to know the proper wiring ....also it has 6 posts...
There should be a wiring diagram on the motor name plate. If it isn't there, there isn't much anyone can do, there are literally hundreds of different wiring methods for single phase motors.
Jun 11, 2010 | Air Tools & Compressors
Pool & Spa Logo
178 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
