Question about Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
Delta RP 70 backwards? - Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve....
    President:
  • 2,976 Answers
You can either remount the fixture or reverse the supply lines.
Posted on Jan 16, 2013
The Delta diverter keeps blowing out the rubber washer? I believe it is because of the high pressure water source.
insert a valve between the faucet and the boiler and keep it at 50%-70% open
Sep 05, 2014 | Delta Home
How do you fix water coming out the top of Delta rp 13740 vacuum breaker?
take out screw and pull apart...make sure you line up parts so you can replace back the same way....after all out turn water on slow to blow out any trash...then get heat proof plumbers grease and grease up all parts...if it has a spring...streatch it out some and grease....put all back and should be ok....if this does not work...may need to get repair kit from plumbing supply house..good luck..
Jul 06, 2014 | Delta RP13740 Chrome Bidet - Vacuum...
Why is my delta kitchen faucet hot cold backwards
The supplies are probably hooked up backwards. Hot to cold side and cold to hot side.
May 24, 2014 | Delta & Single Handle Shower Faucet
RCA RP 3755 Clock radio: CD player will not spin
Hello
Check the voltage at the terminals of the sled motor. If it is found OK, replace the sled motor. Sled motor do spins the disc inside for any CD players. See the picture of its position.3_1_2012_3_05_08_pm.jpg
Feb 29, 2012 | RCA Audio Players & Recorders
I have 1604-Vlz3 mixer recorded on cubase5 best matchable sound card is? I have M-audio delta 1010LT.This not so good sound.after recording. For like "Bollowood Hindi VocaSetting" EQSettings...
The problem is that card has only UNBALANCED inputs. You really need balanced or first run the mixer outputs through a DI backwards. Frankly, I would recommend NOT using a card within the PC as there is so much digital noise. Use either a USB or Firewire external convertor and for goodness sakes use balanced lines from teh Mackie... ALL interconnected equipment needs to be powered from the same receptacle or source. M Audio, Roland/Cakewalk and Presonus all make cards as do others.
Mar 16, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I have a Delta Rockwell Radial Arm saw model L-40C (equivalent to model 33-527) that is running backwards. How do I reverse the motor rotation?
Sorry I don't know the saw in question, but I would assume either the starter winding connections or the run winding connections have been reversed. Was the motor replaced or was the starting capacitor serviced recently?
Thanks!
Jan 20, 2010 | Delta Saws
My Delta Faucet Leaks
Check that we were looking at same parts diagram, but I would say RP-70 Ball assy., as well as RP-4993 Seats & springs . If it's only dripping, just seats and spring will usually get you by, but if they are sending parts, free of charge, or ball assy., isn't too expensive, I'd change it too. I have had some luck with removing ball assy, cleaning it well with fine steel wool, then removing seals, and springs, stretching spring slightly, to add more pressure to seal, clean seal, then dab on a little vaseline to seals, and re-assemble.
Jan 06, 2010 | Delta Model 470: Signature Kitchen...
Mitsubishi rp vs 70707
Do you know if this is what the problem is? If its color problems or convergence alignment then:1. THE CONVERGENCE CAN BE RESET BY PRESSING "MENU 12596" TO ENTER THE CONV MISC. MENU THEN "8970" TO RESET.
Jul 28, 2007 | Mitsubishi VS-70707 70" Rear Projection...
Moen 3175 Legend One Handle Shower Faucet With trol Pressure Balancing Valve.... Logo
Top Moen Plumbing Experts
john h
Donni Steen
Don Numinen
Don Numinen
Are you a Moen Plumbing Expert? Answer questions, earn points and help others
