Question about Poulan 14" Chainsaw
How do i tell what "type" of Poulan Model 1950 saw I have
  • Poulan Master
  • 2,239 Answers
The type no. should be on the ser no. plate 1-8 there are small changes between the type no.s but they are all model 1950, is this the machine that you inquired about the sprocket? as that was not the model quoted in you first question!!!!
Posted on Jan 13, 2013
  • 666 Answers
SOURCE: I have inheirited a Poulan counter vibe 3400 it
Go to m-and-d.com then parts diagram then illustrated parts online then parts look up then select oem poulan then poulan then saw then look at list of models you will find 3400. Have worked on one or two of the 3400 and they seem to be a fairly good saw for home use.
Posted on Apr 07, 2009
dontbother10
  • 2220 Answers
SOURCE: I need t find an air filter for poulan 306a chain saw
I got 1 hit for your filter, if you haven' already give them a try "Poulan air filter 530023046"
http://www.lawnmowerpros.com/Poulan-Parts-Search.asp
Lou
Posted on Sep 05, 2009
dontbother10
  • 2220 Answers
SOURCE: I have a Poulan Pro pole saw model sm446e. For
Without seeing the saw and pole we cannot answer your question.
Posted on Sep 23, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Poulan Woodshark Model 1950 and the oiler
1) Check the oil holes in the bar to make sure they are not plugged. The bar can be mounted either upside down, or right side up, so make sure to check both sides.
2) With the bar removed, start the saw and watch for oil to come out of the side of the case/body.
3) If no oil is coming out the side of the saw, inspect the oil pump worm gear and drive spring. The spring is driven by the chain sprocket/drum. The clutch will need to be removed to inspect.
clutch removal as follows
Outboard drums (drums on the outside of the clutch) are held on by a nut or e-clip.
Inboard drums are held on by the clutch which is threaded onto the crankshaft. And there is the challange.
***NOTE all chain saw clutches have LEFT hand threads, so, rightey loosey, lefty tightey. (just backwards from everything else)
*** NOTE #2: DO NOT USE AN IMPACT GUN
this will most certainly shear the flywheel key or damage the flywheel !!!!! (after 35 years, you can ask me how I know that, LOL)
1) Use a piston stop to hold piston from moving: THIS IS A MUST !!!
Ok, so you do not have one, let's make one.
a) remove the spark plug
b) insert a piece of recoil rope into the cylinder hole, leaving a tail to remove it by. (rope, large shoe string, anything that is soft, that is aprox 1/4 to 5/16 in diameter to place into the spark plug hole to help the piston to stop it's travel by filling up the empty space. Just make sure you can remove it later)
c) secure the saw (extra set of hands may be needed) and with a suitable wrench on the clutch center, rotate the clutch to the right until piston comes to a stop. With a hammer, tap the wrench to aid in rotation. This can be very difficult, and may take several taps.
d) after removed, inspect and grease the drum bearing before re-assemlby.
e) upon re-assembly of clutch, tighten by hand only, NO hammer required. The force of the chain will tighten the clutch.
f) remove the rope, and re-install the spark plug.
Posted on Dec 01, 2009
  • 221 Answers
SOURCE: need to know how to connect the gas lines from the
The lines should be connected to push fuel into the carburetor. The output (overflow) of the carb is routed back into the tank. So, two lines in the tank, one is an overflow (return) and the other is the suction. On the primer one line from the tank and the other to the carb. Connect so as to "push" fuel into the carb when the primer bulb is pushed.
Posted on Jun 16, 2010
How to tune the carb on 1950le poulan chain saw
H I ONE quarter turn L one turn then adjust the idle.
Oct 10, 2014 | Oregon Poulan/Poulan Pro 12" Chain Saw...
How to connect the fuel lines for Poulan Model # 1950 Chain Saw
The following link should be very helpful:
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
A link to a Poulan model 1950 Type 7 follows (may not be your saw, there are 7 different Types and 2 Woodsharks (LE))
http://www.ordertree.com/modelinfo/PWE/1950-Gas-Saw-Type-7/75.1950-Gas-Saw-Type-7.1.59.1.html
If you have more questions or need additional help please reply below and I will get back to you. HTH & Good Luck.
Lou
Thank You for using FixYa.
Jul 22, 2010 | Poulan 14" Chainsaw
My poulan Wood Shark mod.1950- Dosen't seem to be oiling.I've cleaned everything you can clean and I can't find the oiler adjustment.Is there one?
A link to a Poulan "1950 Gas Saw Type 7" can be found below, (I did not see an oiler adjustment screw) follows (may not be your saw):
The IPL (exploded parts list) for your saw is the only detail for the Oil system and is sketchy at best. Oiler components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
Poulan.com (all models)
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
Oil System Plugged:
  1. Remove the clutch cover, bar, and chain, clean the bar groove, any holes and passages on the rear of the bar (both sides, consider rotating the bar), if equipped with a sprocket nose ensure it rotates easily at least one complete revolution. Clean the saw oiler hole and channel. Insert a blunted, hooked piece of wire through the oil filler hole and pull the hose in the oil tank out. Pay attention to the screen or filter on the free end (clean or replace, difficult to determine serviceability). Start the saw and see if it oils when revved up (oozes down side of saw). If yes reassemble your saw. If no, continue with 2.
  2. Work your way through the linkage (use IPL to identify components and locations) cleaning and replacing any defective parts as you go. Carefully check the hoses for cracks especially at bends and connections. If equipped with an oil pump it is usually behind the clutch (clutch is a left handed thread). Please make extensive notes & some digital pictures will help during reassembly.
If it does not oil on completion of 1 it is most likely a bad oiler or worm gear (see IPL).
Lou
May 02, 2010 | Garden
I neen repair manual for a Poulan Pro SM4218AV.
Hi Lou; great name.
What are you trying to repair? The correct IPL and some thought works for most things.
Poulan "PP4218AV Type 2" IPL follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/PP4218AV-Gas-Saw-Type-2/75.PP4218AV-Gas-Saw-Type-2.1.59.1.html
If this is not your saw you can find the correct one here:
Poulan.com
Reply below with some additional detail of what you are looking and we will continue. HTH
Lou
I was born May 1950. Which of us has been Lou longer?
Feb 17, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
What is the breakin period for a poulan 1950
I would say a full tank of fuel, but there really is not any " break in" time stated in maual.
Feb 06, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan chainsaw repair manual or routing new fuel lines, deterriorated from E10 use.
What you request to the best of my knowledge does not exist. You may find this helpful. Had you provided a model and serial number it would have been more helpful.
Typical fuel system and couple of suggestions:
The IPL for you saw can be found here:
The IPL (exploded parts list) for your saw is the only detail for fuel line routing and it is sketchy at best; components are listed but may be on different illustrations.
Poulan.com
If I can be of further assistance you can reply below. I hope you found this most helpful.
Lou
Jan 30, 2010 | Poulan Garden
Poulan woodshark 1950 gas to oil ratio
Thats and old saw, you have to run those very rich usually 20:1
Aug 12, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Poulan 14" Chainsaw Logo
284 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
