Question about Hotpoint 18 in. DC26P Free-standing Dishwasher
Stuck on programme
My dishwasher is stuck on one wash programme, I have pressed the cycle end option, but still no joy, it will let me change the wash options, but will not work. help.........
bigg t
  • 640 Answers
SOURCE: dishwasher is stuck on the rinse cycle
make sure the float or metal probes in the unit are clean.they sense water and if anything is on them it will cause a malfunction in the unit.
Posted on Aug 28, 2007
  • 7 Answers
SOURCE: Hotpoint FDW60 problem
you will proberbly find that you have a control module fault.
connection from you heater and or thermostats faulty.
if your heater was open curcuit it would flash fault codes.
Posted on May 18, 2008
  • 525 Answers
SOURCE: Hotpoint BCI450 Programme cycles
I attempted to locate an answer to resolve the issue for you, but you have not provided me with enough information to access my service database. Please observe the TIP below, and post me back and I will be happy to assist you further. Should you require more extensive consultation to help resolve your complaint(s), you may contact me through our premium chat service.
Tip: Always provide the complete information provided on the manufacturers product information data tag, located on the unit, and not in the user’s manual. This will help you acquire a more accurate and expeditious response to your complaint.
Below is a link that will help you with parts and diagnostic procedures that are specifically tuned to your manufacturers data plate information. From this link you can identify your issue and order parts to repair your unit.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jun 23, 2008
SOURCE: DWF 61 wont end programme
After a number of visits by an engineer, who just guessed at what it could be, and then ordered a part, changed the part on another visit, I insisted that a 'senior Engineer' visit, and be allowed sufficient time to make sure the problem had been solved. The senior engineer visited a week ago, and finally diagnosed what I had been saying for six months, " The water heater is not getting hot". The senior engineer visited yesterday and changed the 'HEATER UNIT DWF61' part number MS-1801925 (UK). Just before he changed the heater unit he found an electrical connection disconnected, so it may have been the cause of the heater unit not working, although he changed the unit anyway. All working fine now, so will renew my maintenance policy.
Posted on Aug 02, 2008
SOURCE: hotpoint dishwasher model BFI62
water leaking into base of machine. tip dishwasher back and drain out water. then check all seals intact, i.e. around arms, around salt holder etc
Posted on Feb 03, 2009
  • 460 Answers
SOURCE: Hotpoint BF1620 Integrated dishwasher not working
Lets try the following hope this works
1.- unplug the appliance, isolate it from the electric supply.
2.- Remove the kitchen unit plinth and check inside the inspection panels below the door to see if there is water in the base.
If there is, sponge it out and then try the machine again.
Was this helpful?
Posted on May 15, 2009
0 characters
1 Points
John lewis integrated dishwasher
make this test and fix it. God bless you
Float Switch
The float switch may be hung up and this can cause the dishwasher to be stuck in a cycle.
Timer / Control
If your dishwasher gets stuck in a cycle first try shutting off the breaker for at least 5 minutes if this does not correct the problem you will need to replace timer/control board
Jul 24, 2013 | John Lewis JLBIDWS1804 Builtin Dishwasher
How do i reset my whirlpool adg 7460 dishwasher ? programme seems stuck on end cycle?
Unplug it, move timer to start and plug back in. If it still seems stuck at the end it is almost certainly the timer. If it starts as normal, suspect the drain pump or pressure switch
Apr 22, 2012 | Dishwashers
Hi I have a Whirlpool dishwasher ADP5740, Condenser. My grandson pressed the start button before I had set a programme, now the light is stuck on the pre-wash and the start light is flashing and it...
If you have a reset or cancel button try that. Look in your manual for a reset
procedure or troubleshooting section. It is just stuck in a cycle and needs to be reset
or cancelled.
Marty Mouse just a housewife.
Jun 05, 2011 | Whirlpool 24 in. GU3200XTP Built-in...
Cannot program a cycle at all,
Contact the service provider. It could be pad problem or other circuit problem.
May 24, 2010 | Electrolux EWDW6505GS Fully Integrated...
Dishwasher stuck in cycle
I have a similar problem, did you find the cause of the problem?
Jan 13, 2010 | Dishwashers
Belling IDW 603 dishwasher
You can cancel the programme at any point by holding down the last button on the right hand side for about 10 seconds until it clears (its the same button you use to get it going again when you open up the door).
Mar 05, 2008 | Belling 24 in. IDW603 Built-in Dishwasher
Dishwashers Logo
Top Hotpoint Dishwashers Experts
Mike Cairns
Mike Cairns
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
