Question about Canon F-603 Calculator
Removing exponent from canon F-603 to operate in normal mode
When I multiply 12 by 12 my answer is 1.44 to the exponent 02. I do not understand this. Can I set to the normal mode?
2 Suggested Answers
  • 43 Answers
SOURCE: manual for canon f-603
try this link:http://www.manualowl.com/p/Canon/F-603/Manual/71396
Posted on Feb 20, 2012
What is most common power problem?
If by power, you mean exponents, there are several rules.
Multiplication with the same base - add the exponents
Division with the same base - subtract the exponents
Exponent to an exponent - multiply the exponents
Negative exponent - 1 over the same number to the positive exponent
Zero exponent - anything to the exponent 0 is 1
Good luck,
Paul
Jan 26, 2016 | Casio ClassPad 300 Calculator
How do i get a negative exponent?
I don't have this calculator, but let's give this a shot and see if it gives us the correct answer.
Let's try 10 to the exponent -2. The rule for negative exponents is to put 1 on the top and the term with a positive exponent on the bottom. In this case, it would be 1 on the top and 10 to the exponent 2 on the bottom, or 1 / 100 or 0.01.
In the calculator, enter 10, hit the x to the power of y key, left bracket (, the negative key (-), 2, the right bracket ), and finally the = key. You might not have to enter the left and right brackets, but I like to enter them to understand what I enter in brackets is the exponent.
Let me know if it works and if you have any other questions.
Good luck.
Paul
Sep 13, 2015 | Canon F-502 Calculator
How do you simplify the exponent on the calculator?
I assume 13m/2 is the radius of the sphere and you are trying to calculate the volume of the sphere.
The first thing we have to think of is BEDMAS, the order of operations, as some calculators do them correctly, while others do not. Let's be safe and do the BEDMAS manually so we know we will get the correct answer.
B - brackets - enter 13/2 in the calculator - hit enter
E - exponents - with the answer from the first line in the calculator, use the hat key (^) or the y to the x key to raise this to the third power (exponent 3).
M - multiply - with the answer from the line above, multiply this by pi or use what you are instructed to use or use 3.14159, then multiply by 4 and divide by 3.
You should have your answer.
Good luck.
Paul
Jul 12, 2015 | Office Equipment & Supplies
What is the answer to to this (x^5)^3(x^3)^4
We have to follow BEDMAS, the order of operations, where brackets are first, then exponents, followed by division and multiplication, and finally addition and subtraction.
Also, we have to use the exponent law of an exponent to an exponent, we multiply the exponents with the same base.
If we forget this, we can always do it the long way.
(x^5)^3 = (x^5)(x^5)(x^5) = x^15
Similarly, (x^3)^4= (x^3)(x^3)(x^3)(x^3) = x ^12
Now that we have done the exponents, we can multiply x^15 by x^12 and get x^27.
Good luck.
Paul
Oct 05, 2014 | Office Equipment & Supplies
I need to understand how to divide a binomial.
Let's take 2x^2 - 10x +12 and divide it by x-2.
__2x_-_6____________
x-2 ) 2x^2 - 10x + 12
2x^2 - 4x
- 6x + 12
- 6x + 12
0
How many times does x go into 2x^2. Put the answer, 2x above the 2x^2. Next mulitply (x-2) by 2x and put the answer under 2x^2. Now subtract that answer from 2x^2 - 10x and we get -6x (-10x - (-4x)).
How many time does x go into -6x. -6 time. Write this above the line and put the answer above the -10x. Next multiply (x-2) by -6 and put the answer under the -6x. Subtract and we get 0 and we are done. If we want to check our answer we can multiply (x-2) and (2x - 6) and we should get 2x^2 - 10 x + 12.
Good luck.
Paul
Oct 03, 2014 | Office Equipment & Supplies
My TI-84 plus calculater is giving me all my answers in exponent form. like i typed 9+12 and the answer was 2.1e1. does anyone know how to fix it ? and is there anyways to do it without going in programs...
Press MODE, highlight "NORMAL" on the first line and press ENTER. Optional: highlight the desired item on the second line and press ENTER. Press 2ND QUIT to exit the mode screen.
Aug 28, 2014 | Office Equipment & Supplies
Demonstrate how to multiply two binomials
Try to seek these: By using the suggested format:
Suggested su
  1. Adding and Subtracting Binomials
    • 1
      Arrange each term in each binomial in order of degree from greatest to least. The degree of a binomial is the exponent attached to the term. For example, 4x^2 is a second degree term.
    • 2
      Multiply each term in the binomial that is being subtracted by -1 to turn it into an addition problem. For example, the problem (8x^2 + 8) - (x^2 - 2) becomes (8x^2 + 8) + (-x^2 + 2).
    • 3
      Combine like terms. In the example problem, the x^2 terms are combined and the constant terms are combined, yielding (8x^2 + 8) + (-x^2 + 2) = 7x^2 + 10.
    Multiplying Binomials
    • 4
      Understand the F.O.I.L. method. F.O.I.L. is an acronym standing for first, outside, inside and last. It means that you multiply the first number of the first binomial by the first number of the second, then the numbers on the outside (the first term of the first binomial by the second term of the second binomial) and so on. This ensures that both numbers in the first binomial are multiplied by both numbers in the second.
    • 5
      Use the F.O.I.L. method to multiply the two binomials together. For example, (3x + 4)(3x - 4) = 9x^2 +12x - 12x - 16. Notice that -12x is the product of the outside terms and -16 is the product of the last terms, 4 and -4.
    • 6
      Simplify. There will almost always be like terms to combine. In the example, 12x and -12x cancel out, yielding the answer 9x^2 - 16.
    Dividing Binomials
    • 7
      Use the distributive property to divide both terms in the binomial by the monomial divisor. For example, (18x^3 + 9x^2) / 3x = (18x^3 / 3x) + (9x^2 / 3x).
    • 8
      Understand how to divide by a term. If you are dividing a higher order term by a lower order term, you subtract the exponent. For example, y^3/y = y^2. The number part of each term is handled like any other division problem. For example, 20z / 4 = 5z.
    • 9
      Divide each term in the binomial by the divisor; (18x^3 / 3x) + (9x^2 / 3x) = 6x^2 + 3x.
May 10, 2014 | Computers & Internet
What is prime factorization?
"Prime Factorization" is finding which prime numbers multiply together to make the original number.
Example : What are the prime factors of 12 ? It is best to start working from the smallest prime number, which is 2, so let's check:
12 ÷ 2 = 6
Yes, it divided evenly by 2. We have taken the first step!
But 6 is not a prime number, so we need to go further. Let's try 2 again:
6 ÷ 2 = 3
Yes, that worked also. And 3 is a prime number, so we have the answer:
12 = 2 × 2 × 3
As you can see, every factor is a prime number, so the answer must be right.
Note: 12 = 2 × 2 × 3 can also be written using exponents as 12 = 22 × 3
Jun 22, 2011 | Computers & Internet
It still gives me an incorrect answer. In the calculator I am trying to solve: 1.0*10 -14power / 3.3 *10 -12 power. The answer it gives me is 3.03 *10 to the -27 power. That is an incorrect answer. The...
Apparently you're calculating 1x10^-14 / 3.3x10^12
Note the positive exponent on the denominator. Make sure you use the (-) key to enter a negative exponent.
Sep 12, 2010 | Casio FX-115ES Scientific Calculator
6+22)/ 2-12 x 3
Just follow the order of operations. 1. Parenthesis 2. Exponents 3. Multiply and Divide in order from left to right, and 4. Add and subtract in order from left to right. I'm assuming you are missing the left parenthesis before the 6 (.
(6 + 22) / 2 -12 x 3 =
28 / 2 - 12 x 3 =
14 - 36 =
-22
Oct 28, 2009 | The Learning Company Achieve! Math &...
Canon F-603 Calculator Logo
53 people viewed this question
old marine
old marine
