Question about Buffalo Technology Computers & Internet
HD-CE500-EU driver HD-CE500-EU - I have no driver for this, have just installed Windows 7, and save all my files on the above type of Buffalo hard-drive. I just need a driver really! Cheers
  • Buffalo Tech... Master
  • 27,725 Answers
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution Note: it will find all of your outdated drivers
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps.
Posted on Jan 14, 2013
Crankstart
  • 696 Answers
SOURCE: buffalo drivestation 500 gb wont start
Certainly we can help,
This generally means you have a hardware failure in the drive or enclosure. The simplest way to test which is to have a hardware tech move the drive into a new enclosure and see if it works.
This will void your warranty if you do it, so, if the drive is under warranty and there are no files you consider valuable on the drive, call the manufacturer for warranty support.
If you value the data more than the drive is worth then take it to your local hardware vendor and ask them to test the hard drive in a new enclosure. Good odds it will work this way but if not you may need the help of a data recovery specialist.
In North America I use Armor-IT, if you are in a different region and the new enclosure fails to garner results, comment back with your region(Country, State, City) and I will supply you with the closest reputable facility.
Chris
Posted on Jul 09, 2009
zzptichka
  • 95 Answers
SOURCE: My external hard drive is unreadable
Does you drive make any sounds like these? If yes you have a mechanical problem and you should get a specialist to work on it. If not - try to remove the drive from USB casing and connect it directly to your PC or put into another USB enclosure. This should help if the problem is with the enclosure itself and not with the drive.
Posted on Dec 30, 2008
bob_computer
  • 3153 Answers
SOURCE: remove all programs and encryptsion software from buffalo minista
I devised these simple steps that tend to remedy quite a few issues with most portable / external hard drives (though not always)
BUT the section that may be of interest to you is just after step 5.
A few things to check but assumes USB and Windows for other interfaces / operating systems similar steps may be adapted to suit.
1. Ensure it is connected directly to the computer to a USB 2.0 port not a USB 1.0 port as this can have effects on performance and reliability
2. Use only the cables that came with it NOT one that fits that may have been lying around or is longer. Not all USB cables are equal even though they should be)
3. Do not connect through an external USB HUB unless that hub is USB 2.0 AND has its own power supply.
4. Use ONLY the power supply that came with it if it has an external power supply
Don’t use any other unless you know it has both the same voltage and current rating e.g. 12V 500mA anything rated below that would not work properly.
5. Always use the same port for connecting your devices. Some devices do not like being switched about. If switched they may want to install software / drivers again.
If you checked and fixed anything there and still have issues carry on reading.
Go to your control panel and then administrative tools, select Computer Management.
Now select Disk Management and expand the window.
Your drive should be listed here, if not then you need to check your computer hardware has not got any issues before proceeding.
If your drive is listed and says healthy then right click on it an select Properties, click Tools and then Error Checking, Check now, tick the two boxes and then Start.
This will attempt to fix most minor / common errors on the drive. It may also ask you to restart which is fine. Allow it to finish its work or you could corrupt the drive. If all went well you should be able to use it normally again.
If you drive was listed but did NOT say healthy then right click and select Format. Choose NTFS as the file system and do not tick any boxes you do NOT want quick format. Again start and let it do its thing. When it is done restart your computer and you should be good to go.
If you still have problems with the drive you might want to look at other areas.
Posted on Aug 23, 2009
SOURCE: Can't access Buffalo HD-HB250U2-WR 250gb Ext. Hard
I think I have the answer, plug your cable in. If windows 7 shows the message unknown device don't remove the usb. instead turn the switch on the back of the external hard drive off for a few seconds then back on. Windows 7 should then for some unknown reason find the correct drivers and your buffalo hard drive will now work. This worked on mine.
Cliff
hotdesignerwear.com
Posted on Jul 26, 2010
Damilare
  • 358 Answers
SOURCE: When I connect my Buffalo HD-CE1.0TU2 - EU to my
Hello karen_vdm,
It is possible that the hard drive was not initialized and you might need to do it manually.
Try and do this:
Depending on your operating system,
Right-Click on 'My Computer Icon', then select 'Manage'. When you get to Computer Management
page, Click on Disk Management on left hand side, This will display ALL the disks installed on your
system, either partitioned or not partitioned, formatted or not formatted.
Then go to the ones that are hidden, not created, or not displayed, right-click on it, then you'll see
different actions that you can perform.
Also, in some instances, what you just need to do when you get to this page is to assign a new,
distinct, drive letter apart from the ones already in use on the system.
To do this, just select "change drive letters and paths" on the disk management page and give your
new drive a new letter apart from my of the ones being used on the system.
This will automatically bring out the hidden drives.
Hope I have helped you out.
Goodluck and thank you for using Fixya.
Posted on Dec 26, 2010
HD-PNT1.0U3R-EU driver
Possibly an issue with your PC's USB ports as well. Plug something else into that specific port to see if it will work. If not, then it's an issue with the motherboard.
For drivers, contact Buffalo.
http://www.buffalo-technology.com/en/support/
May 05, 2014 | Buffalo Technology 1tb Ministation Plus...
HD-PE500U3/BK-EU does not work
Compatible
Windows 7 (32/64 bit), Vista (32/64 bit), XP (32 bit), Mac OS X 10.4 or later (*2)
You could download and use TrueCrypt. It's free and has very strong encryption. http://www.truecrypt.org/
Jan 01, 2013 | Buffalo Technology Buffalo MiniStation...
I can,t record t.v on my buffalo Hd-lb1.otu2 uk external harddrive on my Panasonic tx-p55vt30
the hard drive MUST have a certain type of file to record(save) and your file may NOT be compatible check specs and then you might find answer
May 28, 2012 | Buffalo Technology DriveStation Computers...
PRINTER SAY NOT CONECCTED TO COMPUTER
purchase a mac laptop and it will connect easily
May 04, 2011 | Lexmark X5495 Printer
I want All-Drivers download for my Satelite A300-1EC system Unit in case of Re-formating and upgrade to Windows 7
Dear Fred
http://eu.computers.toshiba-europe.com/innovation/jsp/supportMyProduct.do?service=EU#tab3;
enter the specifications and download all
Thanks
Gagan
Mar 19, 2011 | Computers & Internet
Will Buffalo Model HD-PE250U2 work with Windows 7 OS? Regards sandra
Yes, it is a "plug-and-play" device, and Windows XP/Vista/7 support "plug-and-play" devices.
Dec 31, 2010 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
I backed up all my files when I switched to Windows 7 from XP but I don't know how to retrieve my data.
when saving files from any OS two methods come to mind 1. using windows to back up files . and 2. using
a redundant static drive ( a HD without an OS installed
or an external HD without an OS installed ) , since you used windows to back up your files you'll have to find them in Documents , they will be listed as the old user IE ; "Tom's Computer" if you didn't use the same user name ( name of computer ) you'll find it tricky to
apply the old data to the new OS , note that some programs wont work with windows 7 if 64 bit because the drivers that run the programs will not install into
windows 7 , most manufacturers are hurrying to update the drivers to windows 7 since 7 is no long in its infancy .
Jan 14, 2010 | Computers & Internet
This might be problem with the cable. Try using another cable.
Sep 02, 2009 | Buffalo Technology (HD-HB250U2) 250 GB...
Computers & Internet Logo
267 people viewed this question
Top Buffalo Technology Computers & Internet Experts
Prashant M
Prashant M
hellics
Level 1 Expert
Are you a Buffalo Technology Computer and Internet Expert? Answer questions, earn points and help others
