Question about MixSonic MS-989 DVD&Karaoke Player Multi-region
Need a replacement remote control for Mixsonic Ms989 multi-region
Where to order a replacement remote control for mixsonic MS989 multi-region.
Samsung DVD recorder SH855M how do I get it to play multi region? Many thx
Power on player with no disc in tray.
1. Press the Repeat button on your remote control
Don't confuse with the Repeat A-B button
2.If your player was purchased in Region 1:
Press the buttons 2, 9, 3, 3 and 4 on your remote control, in order one at a time
If it was purchased in Region 2:
Press the buttons 5, 7, 5, 3 and 8 on your remote control, in order one at a time
For Region 3 players:
Press the buttons 5, 6, 7, 3 and 2 on your remote control, in order one at a time
For Region 4 players:
Press the buttons 7, 6, 8, 8 and 4 on your remote control, in order one at a time
For Region 5 players:
Press the buttons 5, 3, 8, 1 and 4 on your remote control, in order one at a time
For Region 6 players:
Press the buttons 2, 4, 4, 6 and 2 on your remote control, in order one at a time
3. The numbers 01 or similar current region code will be displayed on the top left of your onscreen display
4. Press the 1 button on your remote control for region 1, 2 for region 2, and so on, or 9 for multi-region playback
NB: The above step may be time sensitive and need to be performed quickly
5. Open your DISC tray and leave open for 15 secs.
6. After 15 seconds have elapsed, power off your player and the DISC tray will be closed and player shut off.
7. Power on player and it is now set to the new region code you chose in step 4 above
Mar 10, 2010 | Televison & Video
I inherited a dvd player from a family friend when he died but he no longer had the book for me to code it as it is not a multi region dvd.
Could you please give me the brand and model of your unit so I can further assist you. Thank you.
Feb 05, 2008 | Televison & Video
I have a mixsonic 1088 that won't recongnize the CD or DVD
yes, you might have to have checked out by a tech, if it's a teal good player it might be worth the repair. This problem is usually caused by a defective optical unit or an open transport connector cable.
Dec 30, 2009 | Televison & Video
Please find me a dvdplayer with vga port
My Yamakawa 288 with VGA out was discontinued a few years ago. I know that doesn't help you but Overstock is selling a MixSonic MS-1088(it comes in black or silver) with VGA out. I can't vouch for this player since I've never owned one. There also a few DVD players with VGA from a company called Vocopro. Again never played or even heard of these players before but Yamakawa players don't take up too many shelves in people's entertainment centers either. The MixSonic might be worth the $70 plus gamble.
Apr 08, 2009 | Televison & Video
Samsung P480 dvd player- To Play all region dvds
how can I play *.mp4 files in samsung dvd player model no P480?
Mar 11, 2009 | Televison & Video
Samsung HR733 making multiregional
NB: Do not confuse this with the Repeat A-B button
2.
3. The numbers 02 or similar will be displayed on the top left of your onscreen display
5. After 15 seconds have elapsed, power off your player and then power on your player
Sep 27, 2008 | Samsung DVD-HR734 DVD/HDD Recorder
I need to change region code for goodmans GDVD200CDGM
Region Code Hack: GOODMANS GDVD-200-CDG:
To convert this player to Multi-Region
1. Open the disc tray.
2. Place a region 1 disc in the tray, but don't close it.
3. Press the buttons 0, 1, 2 and then 3 on your remote control in order, one at a time.
4. Press the play button on either your remote or the player.
To return this player back to Region 2 only and its factory default settings
2. Press the Zoom button on your remote control.
3. Press the Retu To return this player to Region 2 only (alternative method) rn button on your remote control.
4. Your player should now go into Standby mode.
5. Press the Power button on your remote control.
i). Open the disc tray
ii). Place a region 2 disc in the tray, but don't close it
iii). Press the buttons Return and then Play on your remote control in order, one at a time
Aug 21, 2008 | Goodmans Televison & Video
Need to change my Crown CDV 1100B player to multi region, have tried recommended options from other sites, but to no avail. This what I've tried so far. 1) Press set up 2)press 1369 (which was...
a) Press SETUP button on the remote control to display the setup
screen
b) Press "1369<<<>" on the remote control ( "<" = left navigation
button; ">" = right navigation button)
c) A new item "VERSION" is added on the menu
d) Select thr VERSION item and press SELECT button to enter
e) Press the right navigation button ">" on the remote control to
change the region code
f) Press SETUP button again to exit the region code change mode
Note: Region code 0 is "all region code".
OR
1.press eject to open the draw.
2.type 9-8-1-7.
3.press select to go through regions.
4.change to region 9 for multi region.
5.press eject to close the draw.
OR
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the 8, 4, 2 and 1 buttons on your remote control, in order, one at a time
3. Press the Enter button on your remote control until the hidden menu appears
4. Select 1 for region 1, 2 for region 2, and so on, or All for multi-region
5. Press the Open/Close button on your remote control
To alter the Macrovision settings on this player
1. Press the Open button on your remote control to open the drive tray
2. Press the 4, 5, 6 and 1 buttons on your remote control, in order, one at a time
3. Select Enable to enable Macrovision, or Disable to disable Macrovision
May 03, 2008 | Televison & Video
I need to unlock the region code on my Samsung DVD SH853 (region 4) so I can play all region dvds. Any help much appreciated.
May 01, 2008 | Televison & Video
Setting region codes to code 1
*To convert this player to Multi-Region
1. Open the drive tray
2. Press the Setup button on your remote control
3. Press the buttons 1, 9 and 9, in order and one at a time on your remote control
4. Select the Region option from the menu and change to a specific region or all regions
To convert this player to Multi-Region if the above does not work
1. Press the 7 button on your remote control
2. Press the 6 button on your remote control
3. Press the Select button on your remote control
4. Highlight the Region option and press 1 for region 1, 2 for region 2, and so on, or 0 for multi-region playback
5. By visiting the next page of this hidden menu, you may be able to disabled Macrovision by setting an option to 0, although this particular setting does not survive power off
6. Press the Setup button on your remote control
Done!
Oct 18, 2007 | Pioneer DV-373 DVD Player
MixSonic MS-989 DVD&Karaoke Player Multi-region Logo
66 people viewed this question
Top MixSonic Televison & Video Experts
Electro Med Services...
Are you a MixSonic Televison and Video Expert? Answer questions, earn points and help others
