Question about Ovens
Need operating instructions Algor AKL 471 fan oven
Algor fan making noises
switch off main wall switch check how free the blade spins if tight needs a drop of oil on bearings if able to access them or may be worn out check blades are not rubbing on part of cover or side.
if a small drop of oil is put on a screwdriver may access if spins free then test.
Oct 16, 2014 | Ovens
How do I set the clock
our algor oven clock keeps making a noise all the time and we cant find out how to stop it in our manual
Jan 04, 2013 | Ovens
How do i get inner glass door off ignis akl905 to clean it
Simple . for the ignis AKL 950 OVEN. Takes two minutes.
1/ get a 7mm socket or spanner.
2/ open door flat, no need to take off.
3/ bottom of glass, both left and right are two black plastic brackets , with a 7mm bolt through them. Undo bolt both sides.
4/ remove plastic bracket, just lift out.
5/remove door , clean.
Put back on, refit brackets and tighten bolts.
Job done.
Takes two minutes. Just remember which side of glass faces inside. think both sides same, but could be wrong.
Hope this helps. sid . derby..
Feb 14, 2011 | Whirlpool Ovens
Manual for algor oven model no akl797/1x
here is a place to request any information for your product
http://manualsmarket.com/search.php?cmarque=ALGOR&modele=AKL797/IX
i beleive they charge for immediate download.. but if you lost it .. this may be the only answer other than sending to the company for the manual.
gl
Jan 02, 2011 | Ovens
Hi I need the operating instructions for an aeg cooker pnc 944 185 047. ive set the time but I cant work out the timeing settings it keeps switching off after about 20 mins and turns its self back on...
hi you can get instructions fron serviceforce.co.uk . follow the instruction link and enter pnc no. however i think your problem is a controling stat for the cooling fan if the fan does not switch on the oven overheats the cabinet and switches off like you describe. its located in the wiring loom behind the control panel. the part is 899661927356-9 costs circa £26. hope this helps
Nov 21, 2010 | Ovens
Delonghi esf461st built in fan oven. No operating instructions. What does the middle knob do? It has 4 settings, one for the light one for the grill and 2 more, which must relate to the oven function. One...
The setting with the fan is fan only function.
The setting with the fan and circle is for fan and element for heating the oven.
Please rate my solution.
Thankyou.
Jan 13, 2010 | DeLonghi Ovens
How to clean roof of AKL 828 /1x
Buy a can of oven cleaner suitable for use in electric ovens and follow the instructions on the can. Its basically spray the aerosol foram and wait then rinse off or preheat the ovena nd do the same and depends on the brand that you buy. It is a bit smelly but does the job! Most supermarkets and domestic appliance stores stock these products.
Sep 29, 2009 | KitchenAid Architect Series KEBC208KSS...
Glass outer oven door panel
check sears parts.
Phil
Jun 10, 2009 | Ovens
AKL 888/01 ELECTRIC OVEN IGNIS STARTS FOR ABOUT A MINUTE THEN STO
hi did you every get this problem resolved as i am now having the same issue?
Thanks Mikala x
Mar 31, 2009 | Ovens
Ovens Logo
75 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
