Question about LG 47 in. Flat-Panel LCD HDTV
Lg 47lw5300 has thick colored lines - LG 47 in. Flat-Panel LCD HDTV
My picture all of a sudden gets darker. How do I fix it
read the book! sum 1 else is suffering the same problem, google this and look for a you tube video. lol.
Jul 22, 2014 | LG 47lw5300 47-inch 1080p 120hz Cinema 3d...
Corel Draw 8 - Can you the color of the underline below the text be changed, a different color than the text?
right click for the any color u need change the underline color and F12 for line thickness (punch F12 and open new dialog box select 1, 2 what ever u want give thickness value then click ok or enter )
Jan 28, 2013 | Corel Draw 8
Why do bright colors bounce on my lg tv?
I had this issue on a 40" Seiki TV. I turned off the 120hz setting and also the Noise Reduction settings in the Menu and it stopped.
Jan 12, 2013 | LG 47lw5300 47-inch 1080p 120hz Cinema 3d...
Mines a LG RZ42PX11 it intermittently gets a black vertical line down the middle of the screen.
Hi I have a LG RZ42px11 there are 6 vertical thick black lines running down the middle off the screen, when cold the TV seems OK but if it has been on for around 10mins or on standby the lines stay on screen.
Thanks.
Douglas.
May 13, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
LG HT502 wont recognize hdmi cable. it says hdmi
go into the video setup menu, and select HDMI set up and select "ON" that should do it
Jul 15, 2009 | LG LHY-518 System
Dead screen
this would be due to a convergence issue either in the color wheel or the ballast. It is probably a balast that will need to be replaced.
Mar 31, 2009 | LG Televison & Video
Thick color lines on screen
Hi ,Sorry, this is not a solution. I have a question about your line. Is it transparent? (can you see through if the picture is bright)Does it remain there all the time if you change inputs? My LG 42" just had a blue transparent line appear on the right side of screen. Tried a few trouble shooting things w/ no change. About 1 hour later it went away. Did you find a solution and what was it?
Sep 05, 2007 | LG 42PX5D 42 in. Plasma HDTV
LG 47 in. Flat-Panel LCD HDTV Logo
60 people viewed this question
Computer Repairing
Computer Repairing
