Question about Versacheck VersaInk-nano Universal Refill Kit - Black - MICR Compliant
Versaink not being read by check scanners - Versacheck VersaInk-nano Universal Refill Kit - Black - MICR Compliant
My 2011 Dodge Avenger will not read any diagnostic machines.
certain scanners will not work on dodge or ford cars
they require a different protocol to run the scanners
take it somewhere else with a scanner that can read dodge products and get the code readings
Jun 26, 2017 | Dodge Cars & Trucks
I want my scanner to read qr barcodes
Check your scanner type? You will need 2D barcode scanner to read QR code (or any other 2D symbol). You may use HR200 by Newland.
Apr 18, 2012 | Symbol LS2208
My girlfriend has a versajet m400 printer. Is the
Yes the cartridges are correct. Black is 34MS/Mx and Color is 35 or 35S, full details below..
  • 1.0 x Cartridge ( Color ) - VersaInk 35S ,
  • 1.0 x Cartridge ( Black ) - VersaInk-nano 34MS
Combo Cartridge Pack here: 5b1f12c.jpg
Good luck.
thanks for using FixYa.
Jun 23, 2010 | G7 Productivity Systems VersaJette M400...
What black ink is used in the versajette m300
Hi
It is 34MX Black Ink Cartridge and you can click on here see click the links 2 there for you.
also I belave that lexmark made the printer so maybe you can get from them the ink.
http://shopper.cnet.com/peripheral-accessories/g7-productivity-systems-versaink/4014-8309_9-33365115.html
And this one
http://www.microcenter.com/single_product_results.phtml?product_id=0264279
Feb 07, 2010 | G7 Productivity Systems VersaJette M300...
Error Message Reads: Check Scanner Unit E01-31
try checking the scanner cable . look through the glass back right . you will see a usb cable.. check both ends.. if there connected properly and you still get the error.. you need to replace the whole scanner unit
Oct 14, 2009 | Panasonic Panafax UF-9000 All-In-One Laser...
Pages scanned are backwards (read right to left and all letters are backwards...as if holding up to the light and trying to read from the backside)
Pls check if the 'mirror' option is on in the software setting. The scanner 'reads' normal way always.
S. Mohan
Jul 14, 2009 | HP ScanJet 8270 Flatbed Scanner
Out of original Versajette Ink
Not,. Also you need the original versaink.I think because it is specilly designed for checks.
Feb 15, 2009 | G7 Productivity Systems VersaJette M300...
My scanner is not reading umax astra4400
is it a new one ? if its a new one there will be lock back side of scanner. try to locate it and unlock, if its not a new one check whether lamp is moving or not.
Dec 12, 2007 | Office Equipment & Supplies
Versacheck VersaInk-nano Universal Refill Kit - Black - MICR Compliant Logo
56 people viewed this question
Top Versacheck Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Versacheck Office Equipment and Supply Expert? Answer questions, earn points and help others
