Question about Dryers
No heat and will just keep running
I have a Whirlpool gas dryer (model LGR6620PT0). It's about 3-4 years old. It will run, but gives no heat at all. I took the back cover off to clean up lint, and it wasn't too bad. The dryer's timer will count down, but never complete. It seems stuck on the last minute and will just run forever. One other odd thing I noticed was that if I put the timer knob on a high heat setting, it feels as though the timer starts. This happens without even turning it on. No other setting causes the timer to act in this manner. If it's plugged in and you turn the knob onto a high heat area, you'll feel the knob vibrate a bit as if it were running.
The dryer is new enough to try and fix it, and I could really use some guidance. I have no experience working on dryers, but used to work on color laser copiers, so I'm capable of taking a machine apart. Any help you can provide is appreciated
  • dangagen Jan 30, 2009
    I can't seem to find my voltmeter, but I did pull the venting system apart and cleaned it pretty well. It had a good deal of build up. I followed appldoctom's advice and taped the leads together to bypass the fuse as a quick test. I only ran it for about 2 minutes, but I once again had heat, so this is definitely tripped.
    My wife mentioned that the last time the dryer did have heat, it was very hot. Now it could be because the vent system was somewhat clogged, but I'm guessing the internal thermostat (next to the thermal fuse) is likely faulty. Would that be a fair assumption? I don't want to just replace the fuse to simply have it blow again because I didn't put out the extra 20 bucks or so for the internal thermostat.
    Sergeant:
  • 311 Answers
Lets see hear,..when your dryer starts do you hear two clicks or one.the first click is the motor centrifugal switch the second is power going to the gas valve and energizing the coil.if only one click.you need to check the fuse in the back of the dryer .its white ,i call it a missile and it has two wires too it .you can put those wires together and isolate with tape and if problem unit will run.if that was the problem you need to make sure all venting is clean also inner dryer air channels,but it sounds like you checked those.if two clicks your ignitor may have failed.you check that with a volt meter 110 volts i hope that gives you somthing to run with . God bless ,tom
Posted on Jan 23, 2009
  • Thomas Malailua
    Thomas Malailua Jan 30, 2009
    the thermal fuse will open because it gets too hot inside dryer.this will happen if the venting is blocked.imagian heating up to 180 degrees fast with out much place for that heat to go if you have any doubt on your home ducting dry a load with out ducting[it wont hurt a thing],time it .then connect ducting with same type of load .time it.if longer home may still be blocked.also older dryers did not have that fuse it wont hurt to dry a load.if it was my dryer and ducting and dryer air ways clean i would not replace thermo next to fuse unless running very hot.200 plus ps the operating thermo could malfunction,but it was rare. God bless ,tom
My dryer is about 7 years old...it runs but no heat isnt spewing out....and it only works on the "timed" settings......Its a Roper super capacity.....model number RGX5634KQ2....serial...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
Check out this tip that will give more details…
Gas dryer not working gas dryer not heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
Check out this tip to see the things that can fail to cause your electric dryer not to work.
Dryer Troubleshooting Electric dryer wont heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Aug 23, 2010 | Whirlpool Dryers
My 4 1/2 year old electric Whirlpool dryer runs
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
heatman101
Apr 26, 2010 | Whirlpool WED5100SQ Front-Load Electric...
My dryer runs but don' heat up. It's about 15
If you have a gas dryer then here is a tip that I wrote about that problem...
If you have an electric dryer, check out thet tip for electric dryers at the bottom of the gas dryer tip...
heatman101
Mar 29, 2010 | Whirlpool Dryers
Dryer runs well but will not heat up and dry
You need to clean your dryer vent and make sure there are no obstructions.
Jan 02, 2010 | Whirlpool LGB6300 Gas Dryer
Dryer only heats when empty
Replace the 2 coils on the burner valve . Without model number , cant give you part number .
Jul 28, 2009 | Whirlpool LGR5636L Gas Dryer
WHIRLPOOL GAS DRYER MODEL LGQ9030PQ1 DRYER RUNS BUT NO HEAT
I would be suspect of the timer. Same thing happened to mine.
Rotate the timer manually a few degrees and see if the dryer operates properly. If so, replace the timer, a simple thing to do. Cost is about $75.00 and available from SearsPartsDirect.
Reply your findings and I will help you more.
Jan 23, 2009 | Whirlpool Dryers
Dryer still wont heat
you could remove and bench test the theromostat. my kenmore would not complete the circut to heat at all with a faulty thermostat. Just use a jumper wire to bypass it and test it THERE WILL BE NO SHUT OFF COULD HEAT UP TOO MUCH IF LEFT RUNNING.
Dec 19, 2008 | Whirlpool LGR5634L Gas Dryer
My dryer will run but won't heat
you either need a new heating element or limit switches
Nov 02, 2008 | Whirlpool LER8648P Electric Dryer
Whirlpool Gas Dryer - Model LGB6200KQ1 Serial # mm2105815 Heat comes and goes. Can heat fine for a few loads then stops. Then starts again. Any ideas
Sounds like it is running Hot, Clean you venting out and make sure the weather hood outside is not blocked.
Vacuum out the lint filter area.
Your dryer also may have worn seals, how old is it? 10 to 12 years running a load a day average? it may be time for a new dryer or rebuild yours.
Jul 10, 2008 | Whirlpool Dryers
Dryers Logo
152 people viewed this question
Top Dryers Experts
