Question about Samson MDR6 Mixer
How to obtain a service manual or schematic for a Samson MDR6 mixer? Thanks.
One channel has a bad hum. It can't be heard when that channel's fader is at minimum and it increases as the fader is brought up.
    New Friend:
  • 18 Answers
Check ac source, most samson produck uses 240 Volt
Posted on May 14, 2013
    New Friend:
Check integrity of cabling and circuitry delivering the signal to the fader or to the amplifier (VCA or op-amp etc) it is controlling. Doesn't sound like an earth or supply problem as hum is under fader control, i.e. not prevalent under all conditions. An ac supply problem is not gong to affect just one channel unless it is happening somewhere close to the fader / level control circuit.
Posted on Nov 25, 2014
How to connect a samson s mix 5 channel mixer
It depends on what you are trying to connect. The XLR would be a professional type microphone, it does not have phantom so a condenser mic will not work. The other inputs should match your stereo equipment. The output goes to your amp.
The Samson S-Mix is a miniature, rugged 5-channel audio mixer with 4-line inputs and a single XLR microphone input. The line inputs are comprised of two 1/4" phone and stereo RCA phono connections. Each input channel has a rotary volume control and the outputs include stereo RCA phono connectors and 1/4" TRS phone headphone output. The S-Mix is powered with an 18 volt AC adapter.
Mar 28, 2014 | Samson S-Mix Miniature Audio Mixer
Garbled sound
Much more info is needed.
Sep 29, 2013 | Samson MDR6 Mixer
I HAVE A NUMARKKMX01 MIXER WHEN I PLUG THE RED RCA JACK IN TO THE MIXER I GET A LOUND HUM
What is plugged into your Numark mixer when this happens? Try disconnecting ALL audio inputs to your mixer, turn mixer volumes to zero and see if the hum is still present. Adjust the volume and check if the hum you mentioned returns. If it is still heard, try new cables between the mixer and amp...if not then start reconnecting inputs until the hum is heard again. It's a process of elimination but not that difficult to find the source of your problem.
Oct 31, 2012 | Numark Industries Numark DM 1200 Mixer
Hum from Samson XM610 Powered mixer
hi, my samson xm610 have a problem even i tern off the voluem of each chanel still have a sounds be fore is not just like that.. can you help me
Aug 27, 2012 | Samson Xm610 Powered Mixer
Speaker humms only. what causes that?
Incorrect connections or volume settings.
• In powering up, mixer first then amp
• In turning off , amp first then mixer
If hum still persist, without the mixer connected
then speaker amp may need servicing.
Jul 31, 2012 | Samson Auro D415A Speaker PA Active
How do i hook up my mixer to a samson s.com plus compressor
Use INSERT cables to insert into the MAIN's. This will compress the whole level going to the mains.
Aug 04, 2011 | Samson TXM16 16 Channel Powered Mixer,...
How do I connect my samson amp to my samson MDR10 mixer?
on the mixxer, use the "mix" "L" and "R" outputs. use 1/4 inch instrument cables, and connect the mox L and R to the amp's "channel 1" and "channel 2 inputs". always turn the mixing board on first, and the amp second- when turning off turn off the amp first, and turn off the mixer second. start with the mixer levels at the lowest, with the amp levels about 1/2 to 3/4 up. slowly raise the mixer channels first and then the mixer main volume until you have an adequate volume.
Mar 09, 2011 | Samson SX1200 Amplifier
Samson MDR6 Mixer Logo
585 people viewed this question
Top Samson Audio Players & Recorders Experts
Michial Gueffroy
 Grubhead
Grubhead
Jerry Umali
Are you a Samson Audio Player and Recorder Expert? Answer questions, earn points and help others
