Question about QPS Q-see QC444 Video Surveillance System Digital Video Recorder - H.264 Formats - 500 GB Hard Drive
Can't get no video with my qc444 i can see the menu screen and cam 1,2,3,4 but no picture
Doesnt turn on i don now why?
Check your power supply to the DVR it's more than likely bad
Feb 26, 2014 | QPS Q-see QC444-411-5 Video Surveillance...
Tv screen resolution
Check your menus. There should be one menu that allows you to resize the picture to the screen size. (Most likely a submenu in the video menu).
Jun 14, 2017 | Samsung LNT5265FX 52 in. LCD Television
How can i use my cam on my notebook even not on line?
Many notebook computers come with a built-in camera that enables you to take photos and do video chats with friends and family. These devices also come with built-in software that allows you to turn the camera on from your Start Menu and customize the picture and sound quality. Although doing a video chat isn't quite the same as being there in person, it is the next best thing.
1.Click on the Start Menu in Windows in the lower left corner. Go to "Programs" and locate the webcam software that came with your notebook.
2.Click on the program and a new window will appear. The camera will start up and you will appear in the window.
3.Adjust the video and audio by going to "Tools" on the menu at the top of the screen and then "Options." You can change the contrast, brightness, hue and saturation here. You can also change the microphone settings.
I hope you may find it very helpful. Thanks.
Aug 25, 2011 | Samsung Cameras
I'm trying to take pictures from my Eee pc computer's e-cam and put it on yahoo, how do I do it?
There should be software provided for the camera, check the list of programs in the start menu. Once you've found the software, there will be a utility for taking pictures and recording video. Usually the pictures are saved somewhere in my documents, but if you can't find them, there will be a setting somewhere in the webcam software that will tell you where they are being saved to. once you have the picture you want, open yahoo messenger, click 'messenger' in the top menu, then click 'my display image' and tell it where to find the image you want to use.
May 29, 2011 | ASUS Eee PC 900 Notebook
Cnt activate webcam
  1. Instructions
    • 1 Open your browser and download Dell's Integrated Webcam Application.
    • 2 Run the installation once the download has completed, following the on-screen instructions.
    • 3 Restart your computer when prompted to do so.
    • 4 Open the program with which you want to use the cam (e.g. Yahoo! Messenger, AIM, Skype).
    • 5 Open the program's preferences (usually found under the "Tools" menu).
    • 6 Locate the "Video" settings. Most programs will have a tab labeled "Video" where you can adjust these settings.
    • 7 Select "Dell Integrated Webcam" under the heading labeled "Select Video Device" (or something similar).
    • 8 Establish a video chat with a contact to ensure that the webcam is working. If using a program to record your video, attempt a trial recording.
May 10, 2011 | Dell Inspiron Mini 1012 Netbook...
How can i turn on my web cam
If there's a built-in utility,
1. Open the start menu
2. Type "cam"
3. If a utility comes up, use it.
If not, then there's no built in program to use the web cam. You can use third-party software like Skype to use the web cam for video chat.
May 08, 2011 | HP Computers & Internet
No picture and when vga plugged into computer the screen keep blanking out
VGA is a high capacity video cable requirng for computers to have an enormous pixel density to capture to display beyond to another set devices. Usually with VGA cables, each devices computers, televsions, DVRs have to be high defination devices. Recent innovatons are all enabled to functions with VGA, only requires ascertaining the methods of connections. For example, VGA cables performs with capacities that disallows for the TV or computer to be connected to several devices that also request amount of extensvievss in pixel definitions.
Feb 14, 2011 | QPS Q-see QC444 Video Surveillance System...
I have QC444 and I can't seem to get it working over the internet. I have Dlink 524 and opened up ports 83 and 37777. 80 used by another device. I am using Windows 7 and have opened up port 83 and 3777 in...
These units may have a firmware problem with Internet connectivity. After a week with their Tech Support They were unable to help me get it to send Emails and or FTP outbound. Although I was able to view the Video remotely.
Try setting TCP port to 37777, UDP Port to 37778 and HTP port to 83
Also, Be sure to enter at least one working DNS address.
Make sure the IP address of the DVR is in your Network. Make sure the gateway is set to your DLink's LAN IP Address.
Make sure you forward port 83 in your router to the IP address of your DVR. Check your router logs for any remaining issues.
Jan 09, 2011 | QPS Q-see QC444 Video Surveillance System...
Web cam
In msn live click on show menu then tools option for cam setup
If that don't work click again show menu then actions then video then show my webcam or start video conversation.
If taht does'nt work then I would assume it's something in your camera setup itself
Jan 11, 2009 | Acer Aspire 5610-4648 Notebook
I have a Canon zr950 mini DV cam corder and when I connect the DV cable I do not see the picture on the preview screen on the PC. Drivers installed and it recognizes the cam.
I just discovered that this is the same reason I could not transfer the video for my cannon ZR950 the menu options on the cam has a setting to turn tv on and off
Aug 07, 2008 | Canon Cameras
QPS Q-see QC444 Video Surveillance System Digital Video Recorder - H.264 Formats - 500 GB Hard Drive Logo
57 people viewed this question
Top QPS Home Security Experts
Christian Krentz
Christian Krentz
Softlister
Softlister
Are you a QPS Home Security Expert? Answer questions, earn points and help others
