Question about iRiver iFP-795 MP3 Player
IRiver Music Manger not recognizing iRiver player when connected
Iriver music manager is not recognizing the iRiver player when connected. The Music Manager is dislplaying "Not connected" though the plyaer is accessible as a Removable Drive
  • Anonymous Apr 14, 2009
    I have the same problem. I have tried just zbout every combination of connecting the IFP-795 and starting the Music Manager software. I even deleted the MM software and downloaded a fresh copy from the iRiver website. The firmware is version 1.24, and I have the latest firmware update ready if I can ever get the MM software to recognize the darn thing is connected to the computer. BTW, the player does show up in the computer's Device Manager.
  • 3 Answers
OK, this problem was driving me almost to tears with frustration but have managed to bodge-solve it so hope this helps!
Right click My computer and select Properties.
Click on Hardware tab.
Click on Device Manager.
Hopefully there is a yellow question mark symbol against Iriver T30 listed under other devices or portable devices or something.
Right click this then select Update Driver.
Tell it that you are going to manually update the driver yourself.
Eventually you will have to select what type of device it is - select portable device.
Now click on MTP device and click next to install the driver.
Hopefully now it is recognised by XP in My Computer....
Good luck
H
Posted on Jun 23, 2009
  • harryfox Jun 23, 2009
    After you select 'update driver', choose
    After you select 'update driver', choose 'install from a specific location' and then 'don't search, I will choose driver to install'...
  • 3 Answers
First make sure you have the right drivers installed, you're hearing the "new device connected" sound when you plug it in, it's listed as recognized under device manager, and the only problem seems to be that iriver music manager isn't recognizing it.
If everything is working except for the music manager, then try holding down the "fast-forward" button at the same time that you connect the cable to the iriver. You probably want to keep iriver music manager loaded, to see if it's recognizing the player while you test this; try attaching/detaching the device several times, while you're holding down fast-forward and while you aren't, to see if that's enough to fix your problem.
I have no idea why it works when it does, it's an ugly kludge, but it seemed to fix the problem for me, and saved me from having to buy an entirely new flash mp3 player to replace this ancient one.
Posted on Mar 01, 2009
Next time when you connect your IFP-795 and your computer recognizes the new hardware, let the Wizard install it (even though you have already done this previously). You should not need the install disc anymore as the necessary files were previously installed on your hard drive. This worked for me, hope it does for you as well.
Posted on Feb 09, 2009
  • silentq Oct 19, 2010
    This sometimes works, but not always. I've had this problem since the beginning when using this device on a Win 95 machine. Since then, I've migrated to two different Win XP laptops, and neither one can consistently connect Music Manager to the device. Pathetic. I'll try the fast-forward button advice.
I have an ifp 790 iriver player. I have Windows 7. Iriver music manager does not work on Windows 7. I tried the compatability factor on Windows 7 and it does not work. Please help me! I need to be able to...
What type of Windows 7 do you have? Is it 32-bit or 64-bit? If you have 32-bit, then iRiver Music Manager should work. However, if you have 64-bit, it will not work, according to a phone call I made to iRiver several months ago. I had the same problem as you, and so I called iRiver and that is what they told me, and then I exchanged my 64-bit computer for a 32-bit computer and now the iRiver Music Manager works.
Sep 25, 2011 | iRiver iFP-790 MP3 Player
I need desktop app to manage music for iriver
Support for the iRiver IFP-899 is on next site:
http://www.iriver.com/flash/index.asp?code=0302
MANAGER connection type
In the second column next to GO, enter the word manager or select POPULAR KEYWORD.
On the page right side a list shows up.
Select the iriver music manager to see the information how to download and install the software. The manager for the computer matches the manager firmware in the player.
Need more help ? Just post a comment.
Dec 26, 2009 | iRiver iFP-899 MP3 Player
Where can I get the driver and music manager for my IFP-799 ?
iRiver IFP-799 is a IFP-700 series player.
Making transfers to the device can be done in either UMS or Manager mode.
UMS firmware matches with seeing the player as a removable disk in Windows Explorer and is also used for updating firmware, using iRiver PLUS software.
Manager firmware matches with iRiver Music Manager software.
When needing the Music Manager go to next site and enter the word
manager in the second column next to GO:
iriver music manager ( Ver. 3.21 ) shows up: click the item and read
the instructions for download and installation.
How to update the player's firmware
in MSC mode:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=47
in Manager mode:
http://www.iriver.com/flash/popup/flash_pop.asp?board=faq&code=252
Dec 25, 2009 | iRiver iFP-799 MP3 Player
I'm looking for for a driver for i-river MP3 IFP-790 and can't find anything right on the web. would appreciate it if someone could direct me to a download link, tnx
IFP-790 can be accessed in UMS and Manager mode:
UMS mode
For firmware upgrades iriver PLUS3 must be used.
Download iriver PLUS3 going to this site:
http://www.iriver.com/index.asp
Click Support on the left side.
Select Download in the second column.
Select "Download iriver PLUS3" in the page: allow download (when blocked / sometimes download has to be repeated).
The size of the iriver PLUS3 download is 59.3 MB.
iriver PLUS3 can also be used for music transfers in UMS mode.
Manager mode
For Manager type connection the iriver music manager must be downloaded and installed.
Go to the support site:
Select Support in the first column.
Enter the phrase 'music manager' and click GO:
download 'iriver music manager (Ver 3.21)' [ 28 MB].
Sep 29, 2009 | iRiver iFP-790 MP3 Player
I can't find a software for my iriver model-ifp-790
try this: http://iriverinc.com/support/ultra/700.aspx (copy n paste into search bar)
>>click on: iriver music manager for PC
OR
if you have MAC computer click on: iriver music manager for MAC
>>then click on: iriver manager 3.16
>> click on RUN NOT SAVE -even though it says click on SAVE, it WILL NOT WORK
>> it will then begin installing
>>click on: RUN a second time if nessecerly
>> then click on the iriver icon on your desktop and plug your mp3 player into your computer
hope this helps! :-)
Jul 11, 2009 | iRiver iFP-790 MP3 Player
IFP 790 + Windows Vista
OR
Jun 10, 2009 | iRiver iFP-790 MP3 Player
IRiver iFP-180T drivers
you must download the iriver music manager from their support site. the music manager automatically installs drivers via info on their site...
iriver Music Manager V3.21
Supporting models of iriver music manager is iFP-Series
(Manager mode ) and N10.
If you want to switch connection mode (iFP-Series only)
from MSC to Manager version,
please click here.
(Device Driver included and automatically installed)
Upgrade Features
-. Compatibility with Windows vista.
Here is a way of how to transfer music files from
your PC to your device by manager.
Jan 03, 2009 | iRiver iFP-180T MP3 Player
Computor doesn't recognize iriver iFP-895 mp3 player
What's your operating system?
These are the steps that helped me resolve a similar issue I had:
1) Find a computer with Windows XP (ServicePack2)
2) Intall iRiver Music Manager 3.16 from http://iriverinc.com/download/iRiver_Manager_v316sp.exe
3) Download the Firmware update for your player from http://iriverinc.com/download/ifp800/IFP-8XXT.HEX to your Desktop
4) Start the Music Manager and connect your player to the computer. (The XP should recognize your player; and the Music Manager should show the "connected" status)
5) In the Music Manager, click on Tools => Upgrade Firmware, then select the file from your Desktop. NOTE: The upgrade process takes 4 -5 minutes.
After the firmware update, Windows Vista and other PC's should recognize your player.
For additional info, see Jan Karlsbjerg blog at http://www.jankarlsbjerg.com/blog/archives/2007/03/26/ums-firmware-for-iriver-ifp-89x/
Dec 22, 2008 | iRiver iFP-895 MP3 Player
Deleteing voice recording
If you can connect it to a PC with XP on it, and have an iRiver Music Manager; once your device is recognized, you will be able to manually manage files on your iRiver, including deleting any voice recordings on it.
Oct 30, 2008 | iRiver iFP-895 MP3 Player
iRiver iFP-795 MP3 Player Logo
1,646 people viewed this question
Top iRiver Audio Players & Recorders Experts
Steven Wander
Steven Wander
Mohamed Ismail
Mohamed Ismail
Are you an iRiver Audio Player and Recorder Expert? Answer questions, earn points and help others
