Question about Dryers
White knight wk767 not heating - Dryers
4 Suggested Answers
dragonsthatk
  • 547 Answers
SOURCE: cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
You must pop off the top of the dryer then remove the front after the front is off you can remove drum .
The belt goes around the drum and the motor pully and under the tentioner wheel after you get belt on replace front and top.
PLEASE MAKE SURE TO UNPLUG FROM POWER THIS IS 220volts AND CAN HURT YOU BAD
Thank You For Useing Fixya
PLEASE RATE ME
Posted on May 02, 2009
  • 3 Answers
SOURCE: wk767 tumble dryer
it is the motor run capacitor it happened to me i bought a replacement in maplins for about £3 or £4.
Posted on Mar 15, 2010
Testimonial: "thanks for the info will try."
  • 494 Answers
SOURCE: WHITE KNIGHT TUMBLE DRYER NOT DRYING?
Here's a few things to check that most people can do on their own. Keep in mind, that if you start taking the unit apart, you need to unplug the unit first. We don't want anyone getting zapped!
1) Obvious things first. If you have a propane gas dryer, make sure you are not out of gas! Go to the tank, lift the lid, look at the % gauge. If it's pointing at 5% or less, you may be empty or about to run out of gas. Order a gas delivery.
2) Another obvious tip. Check your lint filter. It may be so clogged that your dryer can't breathe. Clean it. Using a flashlight, look down into with the filter opening and see if there is a lot of lint still inside. If so, try using a small vacuum attachment and clean out lint. This applies to both gas and electric2_bing.gif dryers.
3) Most gas dryers have either a small access panel in the front or at the very least, a peep hole. Open the panel or pop out the plastic peep hole cover so you can view the igniter. Turn on the dryer and watch for orange glow at the burner. If it does not glow, it will not light the gas burner. You may have a broken igniter and will need to replace it or have a new one installed. If you do it yourself, be sure to unplug the dryer and do not touch the very fragile ceramic piece of the igniter. You can confirm it is broken by locating the broken piece below where it is attached or noting it is missing a piece of ceramic on the igniter.
4) This tip applies to both gas and electric models. Another thing you can do is check for blockage in your vent. Unplug the dryer, and pull the unit out as far as you can to get access to the back of the unit. Be careful not to step on or kink the gasline. Pull the venting off the back of the dryer. There is usually a squeeze clamp holding it on. Clean out lint in dryer and from within the vent tube. Some cheap venting are made of expandable plastic or aluminum and can get squished to the point they restrict air flow. Make sure your vent is not collapsed and doesn't get squished when you push the unit back. Once you have cleaned and reassembled it, plug it in turn on the dryer and watch for ignition. If it lights, go outside to the vent cap and check for lint there and make sure your vent flap opens with the hot air flowing out. Clean and adjust as necessary. If you have a long vent tube like I have on mine, then you should clean it out annually. I use a wind-up toilet snake and crank it around knocking lint loose from the walls of the vent. I can always tell when it needs to be cleaned again, when clothes2_bing.gif no longer get dried in the first cycle. If you are unsure of, or unable to perform this task, then you'll need to hire a repairman.
Anyway, these are just the easy, quick fixes that most homeowners2_bing.gif can perform on their own. If none of these solve the problem, you will need to troubleshoot further or hire a repairman. Hope this helps.
Posted on May 23, 2010
What is the load capacity for a 84 AW white knight tumble drier?
5Kg
White Knight 84AW White Tumble Dryer by White Knight Be the first to review this item
Currently unavailable.
We don't know when or if this item will be back in stock.
  • Construction: Freestanding
  • Control of Drying: Timer Control
  • Display of Remaining Time: No
  • Energy Consumption in kWh at 1400 RPM: 2.5
  • Energy Consumption in kWh at 800 rpm: unknown
  • Energy Efficiency: A
  • Energy Savings Trust Feature: Yes
  • Heating System: Electric (incl. Heat Pump)
  • Height in cm: 85
  • Maximum Loading Capacity in kg: 5
  • Start Delay Option: No
  • Type: Ventilation
  • Type of Loading: Front
  • Width in cm: 59.6
84 aw white knight tumble drier capacity Google Search
Feb 19, 2018 | Dryers
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
Tip
video section
on May 10, 2010 | Abbaka White Knight 44AW Electric Dryer
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
WHITE KNIGHT TUMBLE DRYER WILL NOT GET WARM
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 24, 2010 | Abbaka White Knight 38AW Electric Dryer
White knight tumble dryer CL432WV wiring diagram please
This has lots of diagrams on white knight http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
Apr 19, 2010 | Dryers
Wk767 tumble dryer
Mar 09, 2010 | SNK Knight 43AW Electric Dryer
White knight dryer wk767 (Crosslee) blows fuse when turned on
Probably a problem with the heater element (if mineral insulated metal sheath type), or fluff on wire heater coils if that kind. This is behind the back cover.
Feb 27, 2010 | Dryers
Yesterday the trip switch for the downstairs mains sockets tripped. When i reset it and plugged switched on my White Knight 44AW drier it span as usual but now there is no heat.
Jan 19, 2010 | Abbaka White Knight 44AW Electric Dryer
Cannot get into back of tumble dryer to fit new belt
Hi welcome to Fixya
PLEASE RATE ME
May 01, 2009 | Dryers
Dryers Logo
26 people viewed this question
Top Dryers Experts
