Question about HP LaserJet 3052 All-In-One Printer
Hp3052a cleaning process failed
Printing slow, little to no color
2 Suggested Answers
  • 1768 Answers
SOURCE: HP Photosmart c7280 Color isn't printing right.
check the print cartridge contacts see if they are blocked. It may be a clogged print head.
Posted on Apr 07, 2010
Why does processing job take long?
the print file detail may be multi-layered may be too much information in print job- your printer memory may not be adequate, you may be printing through a slow network, you may be printing through an older print server which is as slow as parallel port printing or you may be printing through your parallel port which is slow.
Dec 27, 2013 | HP LaserJet 5500dtn Color Printer
My printer goes through the motion of printing but the paper comes out blank. I've an hp deskjet d2360 and there is ink in it
Possibility cartridge print head dry.
Solution 1:
Do a clean process
cartridge automatically. Press START - Control Panel - Printers and Faxes - HP Deskjet d2360 right click and select Printing Preferences - Select the Color tab - select Printer Services - select Clean cartridge, wait for the cleaning process is completed - Perform Test print. If the print test results, has good graphics, press Finish. If the graph is not clear or drop out, repeat the cleaning process once again.
Solution 2:
1. Open the cover printer, cartridges will move to the middle position.
2. Remove the cartridge (be careful, do not touch the element cartridges or print head by hand), then stick the tip cartridge (print head) to clean water
3. Then, attach the print head to a tissue paper. If there is a tissue paper used in ink (black cartridges, black block lines, and color cartridges, three color red yellow blue lines), means the flow of ink to the print head is normal. If the
tissue paper no trace of ink, attach back into the water, repeat the above process.
4. After process is complete no.3, clean the cartridges with a tissue paper (careful, do not touch the element cartridges or print head by hand, because it will damage the cartridge). After cartridge clear of the water, insert the cartridges into printer.
Sep 24, 2011 | Office Equipment & Supplies
Removed empty color ink cartridge. Replaced with new one two weeks later. Color ink will not flow at all. How do I correct this problem?
Sometimes even new cartridges can fail even more so if the cartridge was refilled.If you haven't already, remove the cartridge and try to seat it again.
To determine if the cartridge set can produce the correct basic colors, run the "Clean The Print Cartridges" function under Services in the printer driver properties. The cleaning process will produce black, cyan, magenta, and yellow if both cartridges are good. If one or more of the colors is missing:
1. A cartridge has failed or is empty.
2. The print nozzles may be plugged, i.e. dried out or not being cleaned properly by the service station.
3. The cartridge and carriage electrical contacts may be dirty.
4. The printer may have failed.
If there is an incorrect color, the ink is mixed inside the color cartridge.
-- Do not continue until you have worked through any issues revealed above. --
After establishing that the printer is capable of producing the basic color set, print from a software application. If you are not getting the expected colors, consider these possibilities:
1. The software is not configured properly.
2. Uninstalling and reinstalling the printer driver.
3. The printer may have failed.
Go to this web page for more information.
http://h20015.www2.hp.com/en/document.jhtml?lc=en&docName=bpa00224
If this step doesn't work you can try the steps at this link:http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=bpa02019
Jan 30, 2011 | HP DeskJet 820Cse Printer
Prints pink ink only can't get it to do black...
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Jul 14, 2010 | HP DeskJet 895cse InkJet Printer
Only prints in yellow color
The printer must be able print all colors in order to execute the alignment. Part of the alignment process involves scanning printed colored (all colors including yellow) bars. See the web page below for a sample of the printout. I suggest that you clean the carriage and cartridge electrical contacts with a cotton swab moistened with water. If you still fail to get yellow, test the cartridge in another printer. ping me for the make of printer, anyways if it an HP series refer to the website below
http://h20015.www2.hp.com/en/document.jhtml?lc=en&docName=bpu00657
May 01, 2009 | Computers & Internet
HP K5400: Y and B color are failing printing
Turn Off Your Printer Remove K&Y Printhead from your printer. Put the Printhead in the bowl in the same Position As in the Printer And Pour Little hot water in the bowl till the printhead is half dipped in the Water. Leave in for 15-20 Min. after that Clean the Printhead with clean clothes.. Must Ensure that no Water is in the Circuit of Printhead. leave the printhead for 30 min. After that put Back in the Printer. You will Get the Better result than ever BUT PLease Donnot use clean Printhead Utility immediately after this process use after the Day. If it Doesnot Work Then Clean the Printhead in Hot Water Several Times.. Do not Remove Printheads Regularly From Your Printer..
I Have the Same Printer And Suffered Same Problem A Month Ago with Yellow Colour...
Apr 29, 2009 | HP Officejet Pro K5400 All-In-One InkJet...
The new ink cartridge is not dispensing its color.
Have you tried a cleaning cycle? If not, try one (right click the little printer icon in the bottom right corner of the screen and select head clean). Now run a nozzle check (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three
cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print.
If these actions produce no positive results, or if you have already done lots of head cleans with no result, and you're sure you have a good ink cartridge properly installed, then you can try soaking the print heads for 24 hours (or more), as follows. Turn the printer
on, and as soon as the print head moves pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way.
Look inside the print head parking area on the right and you will see a rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head fully into its parking position so that the cup full of fluid comes up over the print head. Leave this for at least 24 hours, then try a head clean again. Repeat this process again if necessary.
If still nothing, it looks like you may have a failed cyan print nozzle I'm afraid, or some other internal problem. This will require checkout by a Technician. Make sure you compare the cost of repair with the cost of a new printer!
Nov 18, 2008 | Epson Stylus C84 InkJet Printer
Printer
The cartridge needs cleaning. There are several things you can try. Using a wet paper towel, you can wipe the gold portion of the cartridge to try and draw out ink, or you can dunk the entire cartridge in warm water for a couple minutes or so (I have done this with success). The process is more clearly explained here:
http://www.usainkcartridges.com/faq.html
Jan 17, 2008 | Computers & Internet
Black ink won't print at all
Run the cleaning process a couple of times.  The printhead might have gotten sucked dry.
Oct 30, 2007 | Brother MFC 210C All-In-One InkJet Printer
HP LaserJet 3052 All-In-One Printer Logo
60 people viewed this question
Seeker5211
Seeker5211
