Question about Kenmore 22422 Top Load Washer
Kenmore 70 series suddenly leaking?
Checked all connections, nothing apparent ?
    Genius:
  • 1,669 Answers
Don't just check the connections. Pull them off! The chances are there is a cracked end area or a tight bend that caused the crack that needs to be found.
Posted on Jan 13, 2013
Amigaman
  • 248 Answers
SOURCE: kenmore series 70
  The whole cabinet comes off on this washer.  Too remove you need to remove 2 screws in console.  These may be in back on the right and left ends of console or may be in front on each end.  If you can-not find them they might be hidden under plastic end trim.  They are located in front of console on both ends.  To remove pry them up from the inner lower edge and peel towards outside of washer.  Then remove screws and shake console back and forth while pulling up.  Console will hinge back.
   Remove to gold colored clips with screwdriver prying at front.  Make note of the position of these clips.  Unplug lid switch harness and pivot cabinet back and off.  The usual spot for a leak is the pump.  Check for stain coming from area on pump where motor shaft enters.  The pump can be removed by taking off the 2 clips.  Also check small diameter hose that enters side of wash tub in back side.  Make sure this is attached to tub.
Posted on Oct 23, 2007
SOURCE: kenmore 70 series won't turn on
Sounds like the fuse may be gone. If your front panel comes off it may be in there.
Posted on Jun 02, 2008
TheMobilian
  • 8220 Answers
SOURCE: 70 series kenmore washer won't agitate help model #82873120
No wash, no spin read THIS
Spins, pumps, won't agitate right: check THIS out
Posted on Mar 27, 2009
  • 64 Answers
SOURCE: Kenmore 70 series washer: leaky water pump
NEW WATER PUMP
Posted on Aug 31, 2009
  • 1937 Answers
SOURCE: My washing machine (Kenmore 70 Series) does not spin
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number (###.#######) and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
Following is a description of how to release the console for access to the pins.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=137
This is a Whirlpool PDF on how these washers operate. It has a diagram on jumping the switch as well as a detailed section on how the transmission works.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
It also has a troubleshooting guide.
To bypass the switch, you only have to disconnect the power to the washer, tilt the console back, unplug the switch and using an short piece of insulated wire, jump the two outermost contacts on the connector coming from the console and plug the washer back in.
Following is a description of how to gain access to the console and how to remove the cabinet if necessary.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=131&osCsid=913ba652cd504fb162f87d892bcb427b
With the jumper in place, try to re-start the washer.
If it works, the Lid Switch is a relatively inexpensive part.
If the problem isn't in the switch, and the Timer continues to move, the problem is likely in the transmission.
We had the same problem:
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode.
Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt (a 1/2" socket extension works well).
You don't have to remove the drum.
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside.
Remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission.
Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main
agitator shaft), remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, or the main spin gear is damaged the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
As an aside, fixing ours cost less than $30 including 80-90 weight gear oil vs. $170 for a new transmission.
Posted on Jan 12, 2010
Kenmore heavy duty 70 series model 110-8237012
probably your drain pump leaking it has a seal right where it attaches to motor,,,,mine is leaking there but haven't replaced it yet! lol
Feb 27, 2010 | Kenmore Washing Machines
Kenmore series 70 squealing and leaking water
Enter your model number (###.######) and you'll see a list of major sub-components with diagrams and parts.
It sounds as if your pump is bad.
See the following illustrated description of how to access and check / replace the pump.
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=16&newsdesk_id=134&osCsid=8eaba8b07483055c9c0f23bd2274f0a8
Dec 11, 2009 | Kenmore 22422 Top Load Washer
My kenmore series 70 washing machine is leaking water from under the front of the machine. i've checked the drain hose and it seems to be OK. what else should i check
http://appliancejunk.com/forums/index.php?topic=5191.0
Use the link above to access the drain pump. It is the cause of your leak.
Nov 25, 2009 | Kenmore 22422 Top Load Washer
Kenmore Heavy Duty 70 Series Leaking in the back
If you bought a new washer and you still have a leak, i guess it was not the washer but where it drains into. Sink or stand pipe has a leak. unless you are useing the old drain hose from your old washer. Dry up everything and look for the sorse of water with a bright light when the washer drains .
Nov 22, 2009 | Washing Machines
Kenmore series 70 washer leaks during rinse?
the was exhaust hose is either plugged or cracked. also check the drain it is put into as this sometimes will be puleeged with fabric from the clothes you wash
Jul 10, 2009 | Kenmore 22422 Top Load Washer
Kenmore series 70 tip loader washer is leaking
your just seeing the water that is leaking dureing the wash cycle unplug washer there will be 2 screws on the header panel 1 on each side take them outgently pull header panel to you then flipupunplug wiring harness thas to the cabnet there will be 2 clips 1 on each sideuse a flat screwdrive and pry back they will come out tip cabnet back to you the whole thig will come off look at the pump in the front it has a weep hole in it see if it has been leaking from there
Jun 27, 2009 | Kenmore 22422 Top Load Washer
Kenmore 70 series won't turn on
Jun 01, 2008 | Kenmore 22422 Top Load Washer
Kenmore 22422 Top Load Washer Logo
21 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
