Question about Delta Innovations 18 Series Monitor Thermostatic Tub and Jetted Shower Faucet Trim
Delta 18 series tub facet leaks
Tub facet continuously drips
  • Jennifer Jan 13, 2013
    I think it is series 18 faucet, but not too sure. How can I properly identify the model?
  • 3 Answers
The possible cartridges you can replace are listed on this pdf
http://www.deltafaucet.com/media/SpecSheet/DSP-B-R18000_Rev_A.pdf
Posted on Jan 13, 2013
I purchased a13/14 series shower combo kit instructions say not to install tub spout and valve assy.more than 18" appart
I believe they are saying valves no more than 18" apart or valve to tub spout. But not the Shower head outlet, since the shower is part of the tub spout system? But you can verify at the store you purchased from, or the MFG customer service. It would help MFG understand their instructions are a bit ambiguous.
Mar 28, 2015 | Delta Home
How to repair dripping faucet delta 1962 US PAT 3056418
I've the tub spout leaking problem. How do I fix it? Tks!
Apr 02, 2012 | Delta Plumbing
I have a Delta Tub/Spout Pull Down Diverter that has a pretty persistent drip. The HOT and COLD handles are turned off and seem to be as tight as they can be. After doing some research online I believe...
If your Delta RP17453 Pull-Down Diverter Tub Spout stops dripping after 5 minutes, your ok. If it never stops dripping, you need to replace delta faucet cartridge(s) behind the handle(s). This is were the water turns on and off and stops the water flow to the tub spout.
Delta faucets are some of the easiest to repair, and parts are usually available at any hardware store or home center. If you have a two handle faucet, replace both delta seats and springs and stems. If you have a single handle Delta faucet, replace the entire cartridge.
Jan 26, 2011 | Delta Faucet Delta RP17453 Pull-Down...
How to fix a dripping Delta Monitor shower controls?
Turn off the water, disassemble the control and replace all rubber pieces and damaged plactic, if any.
Sep 21, 2010 | Delta Monitor 13 Series Chrome Trim...
Facet still leaking after replacing the RP4993G part.
Make sure the area below where you replaced that part is free of scale and is not damaged in any way. Scuffs, scale and dirt will caused your leaking.
Sep 13, 2010 | Delta Faucet Delta 470-BL-DST Signature...
Leaking form shower facet also leaking from
id say your tub spout or shower pipe is leaking and running down behind remove both and replace teflon tape see if it stops
Mar 14, 2010 | Home
Water drips in tub after washing is completed! kenmore 80 series
Check the solenoids at the water inlet valve. They can be tested using a multimeter or ohmmeter. Check for continuity. A lack of continuity indicates a faulty solenoid. I will attach a photo for reference. A bad solenoid will permit water to leak through to the tub. Hope this helped and best wishes.
Aug 30, 2009 | Washing Machines
Leaking Delta bathroom facet
Is this single handle?If so, you need a allen wrench to take handle okk.But come to think about it you get the tools with the repair kit.
Mar 13, 2009 | Plumbing
Delta Innovations 18 Series Monitor Thermostatic Tub and Jetted Shower Faucet Trim Logo
87 people viewed this question
Top Delta Home Experts
Mike
Donni Steen
john h
Are you a Delta Home Expert? Answer questions, earn points and help others
