Question about Whirlpool Ovens
Oven will not heat but is stuck on broil
Model number GFE461LVQO
SOURCE: kitchen aid oven not heating up
THERE IS OVENSHUTDOWN THERMAL FUSE IN THE BACK THAT WILL SHUT DOWN THE ELEMENTS. I AM LOOKING FOR THE FUSE.
Posted on Nov 25, 2008
kachbibi1
  • 979 Answers
SOURCE: Heating element on upper oven of a wall Thermador Oven
The control switch may be bad on it. If there are 2 elements on the top, they both are not bad at the same time.Check to see if the wires have not burned off the control switch first. Check to see if your breakers are O.K. Turn them both(maybe 3) off and then reset.
Posted on Jan 30, 2009
hbsurfdawg
  • 95 Answers
SOURCE: heating element will not heat
With all that you said, I would suspect an open or faulty element. It is pretty much the most obvious solution.
If you have any electronically ability and you are going to open the oven, use an ohm or resistance meter, check the amount of ohms and use the upper element as a reference for the correct reading.
The element will either read open or good. You can use a light tester also and if the light lights between the two connectors of the elements, then it is ok and look elsewhere.
E
Posted on Mar 02, 2009
  • 8 Answers
SOURCE: Kenmore oven - will not heat on bake / will heat on broil
its your temp sensor. replace it and it should fix ur prob
F2=overheat
is your bottom element connected?
Posted on Jun 24, 2009
SOURCE: My Jenn-air oven won't turn on. It's model number
My Jenn Air 1995 wall oven was working fine until one day the oven and the oven gas burner did not turn ON. I had electricty (make sure you did not trip a breaker) since my front panel LCD and clock was OK. I had a good gas supply.
My oven is an "pilot-less" oven, it uses an electric igniter. Although the "ignitor" was "glowing red hot", the problem is that the gas valve depend on a certain amount of current. If you have a 120V house system, I think the valve needs 3.3 to 3.6 amps to turn on. The current flows through the igniter and then through the valve, as in a same path, like water. So you need an AMP meter to check proper current flow. I read 2.4 amps. I replaced the "glowing red hot" igniter with a new one, Vo"la it was fixed.
Bottom line if you have the oven plugged in OK and you see some life (clock), and you have the gas turned on, most likely the igniter is bad. Second choice would be the oven's thermostat (the temp knob that you turn, say to 350F), or it could be the gas valve.
All three are in same current circuit. The igniter gets the most abuse so I would start there first -good luck!
Posted on Dec 18, 2009
My top oven won't reach temperature. Convection and broil work, bake doesn't. Over a year ago I did a self clean...hasn't worked since. I really need it to work especially with Thanksgiving next week.
It does sound like the element may be bad. The control will cycle the bake and broil elements to even the heat in the oven. if the element is out the oven won't heat well.
Nov 22, 2014 | GE Profile JT952 Electric Double Oven
Whirlpool wgp30801
It is common to have the broil element pulse on or they will send 120 volts to the broil element to even the heat in the oven. Some ovens have a preheat function that will power the broil and bake simultaneously until the oven reaches temperature then the broil element will shut down. If they both stay on red continuously through the entire bake process then something is wrong. Probably a stuck contact on the control.
Feb 12, 2014 | Ovens
When I press to heat oven the broiler comes on, instead
what are we diagnosing here , Dale?
who makes this 'oven' that broils ?
Is this a new oven ?
Ever use this oven before ?
What model number is your oven?
Please give us something to work with here , Dale.
Apr 08, 2013 | Ovens
SLOW HEATING OVEN
you may want to check your broil element
turn the unit on and wait a few minutes
see if you can feel the heat from the upper broiler elemnet
some model use both elements to preheat
i dont have your productiuon number so i cannot be sure with your model
anyway
14-20 mins is the industry standard for a 350 preheat...
Oct 25, 2009 | GE 30" Built-In Single Electric Wall Oven...
I have a Kenmore oven with no directions. We cannot get the broiler to work. Can you tell us how to do turn it on? billiejack69@hotmail.com
Here's the manual for your oven, based on the model number you provided.
http://www.managemyhome.com/mmh/lis_pdf/OWNM/L0522659.pdf
If this isn't your oven, use the following link to enter in your model number to get the correct manual, free.
http://www.managemyhome.com/mmh/ (click on the manual tab)
Hope you find this Very Helpful and best regards!
Here's how to use the broil function of your wall oven:
Press the BROIL pad. (This will
automatically set HI Broil).
lb. While the set indicator is flashing
in the display, press the BROIL
pad again if you prefer to use
Lo Broil. Use Lo Broil to cook
foods such as poultry or thick
cuts of meat thoroughly without
over-browning them.
2. Press the START pad.
3. When broiling is finished, press
the CLEAR/OFF pad.
Aug 28, 2009 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven stays in warm up mode
does broil work? if broil works and bake does not you have a bad bake element. let me know how it goes
Jun 14, 2009 | Frigidaire Ovens
Ge gas oven will not heat but burners work
You will need to check the bake and broil igniters and/or the temperature sensor. A multi-meter should come in handy to verify if these components are good or bad.
Sep 06, 2017 | Ovens
Model # 911-41065
Hey lmount
Your problems seem to be a problem with your oven controller and more specifically it seem to be a problem with the relay on the unit. The contact seem to be welded (stuck) together.
If the contacts for the Broil does not come loose the Bake will not work
Also as the broil will not be controllable as it will always be on
Regards
Sep 04, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Maytag oven will not light
Have you tried to broil or bake? if only one of them work you have a bad ignitor. let me know and we can go deeper
Aug 23, 2007 | Maytag CWG3100A Gas Single Oven
Ovens Logo
19 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
