Paper guide of duplex unit is not working porperly
  • 1,326 Answers
What make & model do you have???? It makes a difference, is a Ford the same as a Fiat????
Posted on Jan 14, 2013
4 Suggested Answers
  • 149 Answers
SOURCE: read out says remove the jammed paper from the
the duplexing unit is under the fixing feeder frame unit..... have only worked on one NP before and it was much like the IR5000 all you need to do is pull out the tray under the fixing frame assemble
Posted on Jun 14, 2010
wrinaldo
  • 185 Answers
SOURCE: im looking for part# of a paper guide that also
This part you described is sold as part of the Left hand Upper Cover assembly wrinaldo_0.jpg
Also check the black plastic 054K24053 Left Hand Upper Chute assembly, that holds the transfer roller.wrinaldo.jpg
Whit Item, Inc
Posted on Nov 02, 2010
SOURCE: false jamming at duplex unit
IT THE BIPASS ROLER THAT IS NOT PICKING THE PAPER
Posted on Jan 10, 2011
How do i remove the paper from the duplex unit when there is no paper there
You could have a broken actuator or the spring came of. I would check all areas for paper not only the duplex area. I've seen paper jams in other areas show a different indication on the display.
Sep 21, 2014 | RICOH - PRINTERS Ricoh Aficio Sp C430dn -...
Samsung SCX6345n duplex doesn't work - paper concertinas
There is a duplex unit guide in one of the maintenance kits that should be replaced periodically. They warp over time. Its the one that "floats" on the side door with the green ground wire attached to it.
Aug 31, 2012 | Samsung SCX6345N Color Copier
Hi there. Our Canon ImageRUNNER 3235i has been skewing papers about for months. Service techs can't seem to find the problem as it is sporadic. Any suggestions?
These can be a quite pain, this copier when it works it works it fine, but when it doesn't works it doesn't work with style.
Please give me more info, where the paper is skewing? in duplex assy or before or after the fixing unit or while going out of paper drawer...?
I had a problem that paper was skewing in duplex and I've chaneged the duplex vertical roller axis.
Sep 20, 2011 | Canon ImageRUNNER 3235i Black and White...
Just got this used canon imagerunner 330s. It seemed to be working OK but now wont finish powering up and displays an E051 code. Can I clear or bypass this? What does this code indicate? Thanks, Keith
Error code E051 indicates there is a problem with the movable paper guides in the duplex unit. Check that the rear connector for the Duplex unit is clear of paper or toner
Feb 16, 2011 | Office Equipment & Supplies
Sharp ARM237 crooked prints and jams w/double sided printing only.?????????
this will be an issue with the duplex rollers check where it is jamming is it in the duplex unit if yes then check the duplex rollers for wear worn rollers will cause scews also check there is no torn pieces of paper stuck in the guides of the duplex
a good thing to do is to get a thin piece of card stock slide it into the duplex manually and frred it where the paper path goes on the duplex from beginning to end and it will push out any thing in the path
Jan 20, 2011 | Sharp AR-M237 Digital Copier
Duplex jamming of copy paper
Clean the rollers and clean the clutches mounted in the duplex cover to the rear of the duplexer Also the fuser mite be bad the fuser inter connects with the duplexer
Apr 01, 2010 | Minolta DiALTA Di183 Copier
Ricoh Aficio 2022 jams duplexing only
no you have to clean it the sensor, or you have to check the briege unit
Mar 18, 2009 | Ricoh Aficio 2022 All-In-One Laser Printer
Oki C9300 - paper keeps jamming in the 2 same places, reads either 383 paper jam or non paper sense error. All drums and tonners are new, paper is loaded.
your getting a 383 paper jam, find paper in two different places.
See if it's a duplex related problem. print single sided documents, if that works, try printing two sided documents (it'll be the duplexer) if it only fails while printing duplex.
Also, check the back door. Make sure the back exit tray is closed all the way.
You can also have a paper jam in the duplex unit (open the front door), the duplex unit slides out the front. You can easily remove the duplex unit and run the printer without it.
Oct 20, 2008 | Office Equipment & Supplies
Panasonic DP 2500 J81-J82 paper jam
Check the sensor lever spring and cable on top of dual path guide (on top of fuser unit) also if the door stopper has been broken there is a good chance the door may be slightly deformed in which case a gentle adjustment may be reqd. check on the diverter solenoid there should be NO spring attached to the white guide. that is supposed to be removed when the adu option is fitted.
Mar 03, 2008 | Panasonic Workio DP-2500E Copier
Duplexer problem
First, the machine always prints the first page first. Make sure you have the right driver (4 plus and not 4)and check the settings in the device settings of your printer driver on the pc. Also make sure the duplex unit is for the 4 plus and not the 4.
May 17, 2007 | HP LaserJet 4 plus Printer
14 people viewed this question
jasbo
jasbo
