Question about Tools & Hardware - Others
How to load the infoguard electric stapler - Tools & Hardware - Others
How do I load the stapler?
No you don't. We answer most things here.
If the stapler is like any of these
http://www.amazon.com/s?ie=UTF8&page=1&rh=i%3Aaps%2Ck%3Abostitch%20staple%20gun
You push the back in slightly to unlatch it and then drop it down a bit and the staple pusher comes out completely.
Jan 28, 2016 | Heavy Duty Stanley Bostich Heavy-duty...
The spring that loads the staples for stapling broke in half where can I buy a new or used one
  1. Panasonic AS-300NN-A Panasonic Commercial Electric ...
    electricandbatteryofficestaplers.julietshop.tk/panasonic-as-300nn-a-panas...Mar 19, 2015 - Commercial-grade electric stapler with 25-sheet capacity features jam-free operation, auto-reverse, adjustable stapling position and LED status ...
Jul 11, 2015 | Panasonic As 300NN A Commercial Grade...
Infoguard shredder SX-102 runs in reverse but not forward
Shredders have a manual switch for reverse..... if you have tried this, then there could be a possibility that the switch has dust of paper in it and the contacts not making contact for the reverse cycle... or the switch is faulty. If you have any electrical knowledge, you can do a test with an ohm meter for continuity in the reverse mode.... or remove the switch and blow it out with an air compressor. If you mess with electrical, ALWAYS REMEMBER TO UNPLUG THE SHREDDER!!!
Good luck.........
Jul 14, 2014 | Achiever CCS5000 Shredder
Swingline optima 40 how do you open and close the stapler?
Swingline heavy duty staplers provide the power to staple up to 120 pages of 20-lb. paper easily and consistently. The all-metal construction of these staplers makes them an indispensible office tool. However, the way to load staples into a Swingline heavy duty stapler differs from the method for loading most other manual staplers and can cause a little confusion.
Difficulty:Easy Instructions
    • 1 Remove the follow block at the back of the stapler by pushing the mechanism in, lifting the block up over the holding hooks and sliding it out from the stapler. The follow block is the spring-loaded mechanism that holds the staples in place within the stapler.
    • 2 Load the heavy-duty staples into the staple tray.
    • 3 Replace the follow block by inserting it back into the stapler and locking it into place over the holding hooks.
Read more: How to Load a Swingline Heavy Duty Stapler ' eHow.com http://www.ehow.com/how_5822366_load-swingline-heavy-duty-stapler.html#ixzz1bVwG5bBn
Oct 21, 2011 | Swingline ® High-Capacity Heavy-Duty...
We have a Swingline 690 electric stapler in our office. We are unable to get the stapler to work after loading staple cartridge. We followed the directions and made many attempts to load. There does not...
I had the same problem with my 690. This is what worked for me.. I simply pulled out the staples from the cartridge a little further than the suggested tear-off point, and the machine was able to start working. Hope this helps!
Mar 30, 2011 | Swingline Portable Electric Stapler
Got a black and decker electric stapler given to me but no manual so can't find way to load it. It is a cat. no. 9700 stapler
Look at the back of the staple gun just under the electric cord and you will see a 1/2 loop of spring steel sticking up from the chrome base. Push it down lightly and toward the front of the stapler - when it is all the way forward lift the loop it while in the forward position and while up - draw it back and the will come out of the staple gun.
Sep 29, 2009 | Black & Decker Tools & Hardware - Others
Tools & Hardware - Others Logo
197 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
