Question about Kenmore 15218 Mechanical Sewing Machine
Bobbin wont catch
I have the same problem . I can not catch the bobbin thread and it will not sew. model 12492 zig zag kenmore sewing machine. please help. maggsj
    President:
  • 2,976 Answers
Try flipping the bobbin. The thread must come off in a certain direction to work properly.
Posted on Jan 23, 2009
Thread breaks when zigzagging but straight stitch ok
Check that the bobbin thread is not pulling the top thread down when zig-zagging. If so, the bobbin tension may be too tight.
Also, there could be a burr or nick somewhere that is catching the thread when zig-zagging. Wraps very fine fabric around your finger (silk, old hosiery, etc.) and run your finger around the needleplate and underneath. If there is a snag somewhere, the fabric should catch on it. Generally, carefully sanding with a fine emery board or sandpaper can smooth it.
Jan 04, 2017 | Sewing Machines
Machine zig-zags but why does it leave a straight seam?
not catching the bobbin thread every time .
Nov 30, 2015 | Sewing Machines
How to thread childs singer zig zag sewing machine
You didn't give the model name for the machine; however, if it's a Pixie or Pixie Plus, you can download the user's manual that shows you how to thread it and wind a bobbin from the Singer Sewing Machine site. The number listed above your question is not a legitimate model number; it might be a serial number.
Feb 01, 2015 | Singer Zig Zag 727198 Sewing Machine
Sews straight when on zigzag
it's possible the zig zag gear or cam could be worn or damaged
and the machine should be checked to see for sure what's happened.
Nov 29, 2012 | Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
I'm sewing a zig zag stitch and the underside is a perfect zig zag and the upper side looks like it should be the underside....how can I fix this so that the beautiful zig zag is on the top?
FIRST > Make sure your bobbin case is threaded correctly...
NEXT
For normal straight sewing the top tension should be around 5, for zigzag or satin stitch you need to lower your upper thread tension a bit. Try it at 4, if it still pulls your bottom thread to the top try it at 3 etc...
Jan 15, 2011 | Euro-Pro Deluxe 7130 Mechanical Sewing...
I have a Singer Special Zig Zag Model 418. I can
More than likely you have a broken vertical shaft gear.
When you turn the handwheel you should see the sewing hook moving under the bobbin case.
If not, take it to a sewing repair person and it should cost somewhere around $100 to repair.
Aug 20, 2009 | Sewing Machines
Singer 457 Zig Zag Sewing Machine not catching bobbin thread.
There are manuals avilable online to purchase for the singer machines, SOrry I was not able to locate a site that has them for free.
.... http://sewingonline.co.uk/singer-manuals.html
Aug 16, 2009 | Singer Quantum XL-5000 Computerized Sewing...
Zig zag stitches are not holding
When ever a machine is jamming up the bobbin thread, it is a result of your top tension. It is either set to low (under 4), or the thread has come out of the take-up lever. Check your threading, fromt he spool pin, down to 2 and up to 3. Three is the take up lever. From the take-up lever down to 4. Set the thread behind the thread guide and thread the needle form front to back. Low quailtu thread 9dual duty or all purpose) can also create this problem.
thanks,
Bonnie
Aug 24, 2008 | Kenmore 15516 Mechanical Sewing Machine
Kenmore 15218 Mechanical Sewing Machine Logo
295 people viewed this question
Top Kenmore Sewing Machines Experts
Tally Girl
Tally Girl
Derek Massey
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
