Question about Bosch 24 in. SHU43 Built-in Dishwasher
I actually don't know what type of Bosch I have. I know that is a problem, but maybe you can still help. It has a simple panel that says: Pot Scrubber, regular wash, quick wash, rinse and hold. When I turn on quick wash, sometimes it says 38 min. 45 min. 56 min. We want to keep it at 38 minutes and we don't know why it varies. If we have to open it mid-cycle, it switches to a higher cycle time. How do we set it for 38?
  • 54 Answers
On a Bosch dw, it has a light sensor to sense soil in the water.. if the control feels that the water going through the sensor is not clean/ or clean it will add or minus time..one thing you can do is make sure that your drain line from dw to sink drain is cleared of debris.. also, make sure you clean the filter at bottom of dw and make sure its reinstall correctly if you haven't already do so.. if your dw finish the cycle and come out clean, then the time on your dw is fine,, but if it don't finish and come out dirty.. then, it could be something other, but don't know til I get the full details on problem.. help this will do it for ya.. good luck.. mike
Posted on Jan 23, 2009
Bosch dishwasher smells burning rubber
Certainly could be a pinched wire in the door panel. I would remove the panel and see if anything is pinched or being interfered with like the rinse dispenser solenoid.
Dave
Jul 04, 2017 | Bosch Dishwashers
Bosch 2604320913 Carbon-Brush Set
No If the saw is running the brushes must be working. Maybe the front end grease has dried causing too great of load on the motor. if not the motor must be defective (lost a winding in the feild) don't know how much you paid but unless its worth is greater than $150 I sugest buying another
Sep 18, 2012 | Bosch 2604320913 Carbon-Brush Set
I have a compaq SR1630NX. I cannot turn the computer on. The green light in the back is on so there is power. I think the switch is bad as it feels broken does not click any more. can I get a new one. What...
Hi Sandy, It might just be that the power button is depressed or that the part that holds the button has been moved back too much.
What I did was remove the power button from the machine, checked the connections to the motherboard and removed then replaced the actual power button from the plastic that's holding it against the front panel of the computer. (it's a gray plastic square that has a black power button) Check that the button depresses when you press it now. For me, it turns out the plastic part that holds the power button was pressed back too much. Removing and then putting it back and pushing it all the way to the front (the actual gray box), fixed the problem for me. Just check that the button from the plastic front panel and the actual button (gray plastic with black lever) are actually working and make contact. Maybe try using it a bit without the front panel?
I hope it may be as simple for you as it was for me. If you do this, just don't forget to remove all power from the machine and remove the plastic front panel from the case. Good luck!
Aug 18, 2011 | HP Compaq Presario SR1630NX PC Desktop
My vol knob. The sounds cuts out sometimes. When i turn the knob a few times the speaker works fine. Its as if the pot is a little dirty or something. The repairman said the vol pot was sealed and he...
  • First thing I would do is check for cold soldier joints. Over time them pots get bumped and the joints heat up and crack and go bad. Of ten times a little heating up of the soldier points to the board will fix this problem.That's suspect one.
  • There is a resistor in them pots that bias the current so that when you turn it the sound gets louder or quieter. Most often when they go real bad the resister inside the pot is to blame.
  • You can spray some electronic contact cleaner on them. Just don't use WD40 or and lubricant type stuff or you will ruin the circuitry.
  • You may need to replace that pot too. It's not so hard. Just a few spots it makes contact on the board. Just make sure you use the same rated one. Pots are not a one size fits all.
  • Here is a little exploded diagram in case you want to check for yourself. http://www.audiorentalslosangeles.com/EON15G2.pdf
  • If you have a warranty then I advise letting JBL deal with it for free. If you don't then this fix can be done at home.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 27, 2011 | JBL EON 15-G2 Powered DJ Speaker With EQ...
I bought a brand new AIM electric kiln last fall. I did the initial burning off but have never fired with it yet. I am afraid to and even though it's band new, had never gotten a manual with it. In...
Why don't you try a simple test glazing or pot firing, something you don't care if you lose and see how it goes?
I assume it has a place to set the temperature? If so what is the problem? Just make sure the kiln is away from any flammable objects and watch the kiln while it is running (don't leave it unattended).
You should probably never run it unattended.
Hope this helps.
Jul 23, 2011 | AOL Instant Messenger
Gorenje EI44A1-T34 or EI44A2-T44 Dear Sirs,we have the oven for quite a while,but never used the oven part of this induction oven. And therefor didn't bother too much with the blinking light showing...
I hope you have found already solution for this... Anyway this may help others: press buttons 1 and 2 together and release. Then use jog wheel to adjust time. Wait 5 seconds and you're done. Gorenje manual sucks, no info about oven controls. I managed even to set on oven child lock (key symbol), only way to take it off was to remove fuses from electric board of our house!
Jun 24, 2011 | Ovens
Hi, we have a Bosch washer model WFK 2401, in which we just replaced the door latch assembly and drain pump, and now it seems the electrical panel is going out. Since yesterday, when we push the...
Check with the repair man but I bet he didnt plug the panel back in all the way when he repaired it,maybe wanting another call. check it out
Feb 15, 2011 | Bosch WFK 2401
Its the only sparkplug i have managed to find here in philippines that fits my engine, just wat to know if is suited for my car before i have to look abroad
get on the net to find out more,NGK, Nippondenso,or Bosch will be fine usually higher price better longer lasting plug,i dont think theres any major advantage
Apr 21, 2009 | Subaru Impreza WRX STi Cars & Trucks
How do you thread a SInger Sewing machine 2623
hi! there,
you can show some actual bobbins winder and threading go to internet explorer and type the address of "www.youtube.com" then on search type "sewing machine".there is a slide show for sewing instruction.just click the slot and it play the video showing what you want.regards don' t forget to rate me.
Apr 09, 2009 | Sewing Machines
Bosch 24 in. SHU43 Built-in Dishwasher Logo
202 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
