Question about HP NB199UA Pavilion Notebook
Pavilion DV4 screen wont turn on.(Overnight problem)
My Pavilion DV4 screen wont turn on. I can see the screen if i put it in light but it doesnt turn on.(Backlight) If i open the lid/screen at a 45 degree angle then the screen works perfect but anymore and the screen stays without back light. It works perfectly and tested it out on an external hdmi monitor and it displayed there but not on device monitor. The leds next to caps and numbs lock arent blinking so i gues its not a hardware issue. Help Please!?!
  • HP Master
  • 5,660 Answers
Since you have graphics on an external monitor, the problem is the Video Cable, or inside the Display Assembly.
http://h10025.www1.hp.com/ewfrf/wc/product?product=3860431&lc=en&cc=us&dlc=en&lang=en&cc=us
This is a general example of a Video Cable, (Display Cable - HP), for an HP Pavilion DV4 series of Notebook PC,
http://www.ebay.com/itm/NEW-ORIGINAL-HP-PAVILION-DV4-LAPTOP-LCD-VIDEO-CABLE-DC02000IO00-486878-001-14-1-/281038275215?pt=US_Laptop_Screens_LCD_Panels&hash=item416f2fc28f
Mouse over to enlarge
The Video Cable connects to the motherboard in an area under the Keyboard, (About where the Fn key is), routes up along the motherboard, then routes up through the left Hinge, and into the Display Assembly.
From there it connects to the screen Inverter (Display Inverter -HP), and back of LCD screen.
It also connects to the LED backlight.
Either connections are loose, or the Video Cable (Display Cable) is damaged.
If the sheath of the cable shows apparent visual damage, so may be the tiny wires inside. (Stretched/Broken)
Connections CANNOT just be visually determined if they are loose.
You MUST physically check EACH connection.
Tightening connections does no good?
Perform a continuity test with a multimeter set to OHM's, on every wire in that Video Cable.
Have an assistant gently wiggle the cable in the middle, and check for an intermittent reading on the multimeter. Indicates broken wire if intermittent reading shows.
OR,
Take Video Cable to the nearest small computer store, and have the resident tech check it for continuity. Should just be a couple of bucks.
Use an ESD wrist strap, and connect it's alligator clip to a good ground source. (Electro Static Discharge)
Average cost is around $3 to $6.
Here is the download page for the free Service Manual, from HP Support,
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?cc=us&dlc=en&lang=en&lc=en&product=3860431&
Scroll down, click on -
HP Pavilion dv4 Entertainment PC - Maintenance and Service Guide
Page 92 (PDF page at Top) for motherboard side of Video Cable (Display Cable - HP)
Page 80 for LCD screen, and Screen Inverter (Display Inverter - HP), and LED backlight.
Page 82 has false statements.
Remove the display assembly:
1. Locate the wireless antenna cable (1), and remove from path (2)
Should be;
Locate the DISPLAY CABLE (1), and remove from path (2)
2. Disconnect the wireless antenna cable from the system board (3)
Should be;
2. Disconnect the DISPLAY CABLE from the system board (3)
Somebody was on crack that day.
The wireless antenna cable information that follows, is correct.
Video Cable (Display Cable) is on the Left side.
Wireless Antenna wires are on the Right side.
For additional questions please post in a Comment.
Regards,
joecoolvette
Posted on Jan 13, 2013
tparsenault
  • 170 Answers
SOURCE: HP Pavilion dv4 not booting up, has blinking caps and scroll lock
Compaq and Hp are having issues with several models, My wife just got hers repaired free out of warranty. Go to copaqs website, look up your model and see if it is one they are offering free one time repairs on. Wife's computer was doing same thing, they replaced the motherboard. Took about 2 weeks round trip . Good luck
Posted on Feb 02, 2009
  • 788 Answers
SOURCE: hp pavilion dv5 wont start. the monitor remains
This unit should still be in warranty. If out of the first year warranty, HP has extended the warranty program for Video issues for a extra year from date of purchase.
Register your unit with HP, if not already and email customer care and log your video issue, ASAP.
I hope this has helped you.
Posted on Oct 07, 2009
SOURCE: I have an hp pavilion dv4- 1430 us that won't turn on
I had the same problem with my hp pavilion dv4 1430 and to fix it I just took out the battery and unplugged it from the power adapter and pushed the power button and waited for a few minutes I put it all back together and started it up and the screen turns right back on.
Posted on Mar 30, 2010
niazi2015
  • 38 Answers
SOURCE: My HP Pavilion DV5-1002AU Laptop is not starting,
this model have 3 provlem one vga problem one processor problem & one bios last time i solve the problem vga
Posted on Feb 20, 2011
joecoolvette
  • 5660 Answers
SOURCE: My HP pavilion DV4 will turn on but not display
AC adapter (Charger) removed from the laptop, remove the Battery. Wait 1 minute then reinstall the Battery.
Post your findings in a Comment.
Regards,
joecoolvette
Posted on Jun 18, 2011
Hp pavilion DV4 won't start up
It doesn't start at all. Can you see something on screen ? Have you tried to remove the battery and charger and press power buton for 30 seconds ? And put back the battery ? Try also to check RAM Memory
Oct 14, 2012 | HP Pavilion dv4-1280us Notebook
I have a hp pavilion dv4-1430us entertainment note book my problem is that i left it without use for about 2 months then when i went to start up the laptop i couldnt and still cant see the screen it is...
do you know what BIOS is?
when you turn on any PC BIOS runs, first. (before Windows boots)
it prompts you with text "hit F10 to enter setup" or ESC key.
if that is dim and the brightness keys are dead (max = dim)
the CCFL are dead now. as all are those old.
first they go yellow, then dim then dead.
DV4 is old and has CCFL backlamp tubes that most now are dead
after 20,000 hours of usage.
the list of used Laptops or monitors not to buy or own.
http://www.pcdied.com/monitors.html#CCFL_list
the parts are not cheap nor is the labor to do this.
gander this.
https://www.ebay.com/sch/i.html?_odkw=hp++dv4-1430us+++screen&_osacat=0&_from=R40&_trksid=p2045573.m570.l1313.TR0.TRC0.H0.Xhp++dv4-1430us+ccfl.TRS0&_nkw=hp++dv4-1430us+ccfl&_sacat=0
Mar 03, 2018 | HP Pavilion dv4-1430us Notebook
Hp dv4-1145go is experiencing flickering on the screen[Taskbar] area
if u can do it try to open the screen cover remove the LCD screen clean it then fix it if possible do not put the screw very *** if docent work then u have to change the screen the problem may be the LCD screen
Dec 07, 2010 | HP Pavilion dv4-1145go Notebook
Jan 09, 2010 | HP Pavilion dv4-1140go Laptop
My Hp pavillion dv4 notebook pc's screen is flickering quite badly. It happens every few seconds and everything seems to jump up and down once and go back to normal. Tapping or hitting screen or any part...
Flickering is a back light issue, jumping around would be caused by the screens reaction to a bad inverter and so would the backlight as well. So flickering backlight and jumping would be a inverter issue causing both problems so I would replace them both.
Thanks if you like my adivice please rate it with the thumbs and leave feedback!
Dec 19, 2009 | HP Pavilion dv4000 Notebook
HP NB199UA Pavilion Notebook Logo
1,038 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
