Question about Toshiba 50H72 50" Rear Projection Television
Pictue problem Of all of sudden my Tv stopped working correctly. When you look at the picture(no matter in tv mode, dvd, in menu's, etc..) it looks like you are drunk. The picture has a wavy look and the colors are distorted. You can watch it f you really want, but it really llok like the top and bottom 40% are distorted and that small middle section look normal. Anyone have any ideas of what can be wrong???? thanks for your help!!!
  • Kevin bed Jul 08, 2007
    1 additional note- it seems to be the red colors that are the issue. When the Direct tv screen saver comes on and its all blue, the screen saver looks normal.
  • 398 Answers
One of your convergence output IC's has burnt out and needs to be replaced. When the IC that handles the Red Vertical (RV) channel goes bad then a small low-value resistor usually burns out with it and the red color will sag inwards at the top and bottom. If you have no experience in repairing and realigning convergence circuits then allow a qualified tech to handle it for you.
Posted on Jul 08, 2007
SOURCE:
My panasonic dvd player will not show the whole screen when in dvd mode
Hi
First make sure your Panasonic has 16:9 TV mode selected within its menu. Then try chainging the picture size on your TV. You didn't say what model TV you have. On my Samsung you would press the menu key then select picture, scroll down and select picture size. From hear you can select 16:9, wide zoom, zoom, 4:3. Try looking for picture size and selecting 16:9 on your TV.
Jun 03, 2014 | Sony RDR-HXD860 DVD Recorder/HDD Recorder
My TV all of a sudden turned white and grey.
First, try to play DVD on your tv to determine if the problem is on TV itself. If the TV looks fine on DVD you have cable box connection problem if not you have faulty t-con board not bulb etc.
T-con is the responsible for colors and image graphics.
Dec 10, 2012 | Vizio VS42LF 42 in. LCD HDTV
Suddenly no sound is coming from the tv
Unplug set and or a box if used for a while and plug back to let units reboot.
Look in menu to see if speakers are switched on or off.
Look to see if a DVD etc connected to a rear input has sound or not.
May 29, 2012 | Toshiba Televison & Video
I transfered from watching my sattelite tv to watching a dvd using the tv control. The dvd sound worked ok, but I couldn't get a pictue. Then I tried to watch tv again, but the vidio would not come in,...
Just in case, here's the 108-page user's manual for your TV:
http://www.hdtvsolutions.com/pdf/MIT_WD-52525_WD-62525_WD-52725_WD-62725_Manual.pdf
Yor "NetCommand" TV remote is a wondrous thing, capable of throwing off anyone.
When the 'Device Selection Menu" is dispayed, and only when the device icon is highlighted,
does the key work, and it also only works when the remote is in "A/V Receiver" mode -
not in "CABLE or DBS" mode, nor "VCR" mode, nor "DVD" mode.
So, (1) set the NetCommand remote to "A/V Receiver" mode
(2) bring up the Device Selection Menu, using the key on the remote
(3) highlight the Satellite receiver input icon (highlighted with a Yellow outline)
(4) press GUIDE on the remote, to swap the analog digital setting.
Also displays ChannelView for Antenna 1 and Antenna 2 - you may have accidentally
set the TV to get its input from the wrong Antenna.
If your TV has lost memory of its DBS source, you may have to re-teach the TV (using the remote)
that the DBS (Digital Broadcast Satellite) input exists, and to which input its connected.
Refer to "Edit NetCommand, Add an A/V Receiver", pages 39-45 of your Owner's Manual.
Jan 31, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Coular picture not showing.
Check your region settings. NTSC, PAL etc. Select the correct one. Check whether in DVD mode color is OK.
Check MENU settings through remote.
Jul 21, 2010 | Sansui TDC2075 20 in. TV/VCR/DVD Combo
The tv seems really dark.57in theatrewide hd toshiba
Go into the tv menu and select the Preferences menu and set your picutre preference from Theater to Normal. The TV is currently in Theater mode, wich is for viewing with no lights on in the room. Switching it to normal lightens the pictue a lot.
May 27, 2009 | Toshiba 57H81 57" Rear Projection...
VCR/DVD & Samsung TV: "weak or no signal"
Take the VCR remote, check VCR output settings ( scart1, scart2 , RCA) and signal format (PAL) etc
Jul 26, 2008 | Samsung TX-T3093WH TV
DVP642 DVD Player is only working in Audio mode
Mine does the same. Cannot get a picture using the Yellow RCA output. Use an S-video cable if you can - it should still work. If you get a black and white picture using the S-video output, go to MENU > VIDEO page and change the output from PyBywhateveritis to S-video and the color will come back. I only found out mine was broken when I needed to use the s-video cable for something else and tried switching to the Composite Video (RCA) to no avail no matter how many cables or TV inputs I tried.
Mar 15, 2008 | Philips DVP642 DVD Player
Picture settings messed up!
Loose cable or wrong setting. Channel, input type, etc. Also. make sure the audio isn't plugged into the video input [either end]
Dec 03, 2007 | Toshiba 27AF45 27" TV
How do I change the aspect ratio?
on the rca tv's its on the remote hand unit ,might be called zoom - or pictue, picture size.etc.if you can't do ti with the remote enter you menu on the tv set and look for it .
Nov 24, 2007 | Proscan PS32500 32" TV
Toshiba 50H72 50" Rear Projection Television Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
