Color coding of canon pixma e510 cartridge - Office Equipment & Supplies
cropp
  • 377 Answers
SOURCE: Error code E5
hi dear
hi dear
may the error code or how many blinking can solve your problem
this is the list of error code
How to clear Error Code Canon printers MP150 MP160
CANNON Printers MP150/MP160 ERROR CODE
E2-2 No paper (ASF)
E3-3 Paper jam
E4 No ink
E5-5 The ink cartridges are not installed or a non-supported ink cartridge is installed ,
or the ink cartridges are not installed properly
E8 Waste ink absorber full, or platen waste ink absorber
full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
try this methode
Methode 1
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting formenu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED
lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
that's all
maybe it can fix your problem
thanks
cropp
Posted on Mar 27, 2008
  • 4 Answers
SOURCE: canon pixma ip4000 color not printing correctly with full inks
In both cases be sure using correct ink. Use of generic ink can lead to leakage of catrridge seats do to crossion from inferrior ink quality (per Cannon). Be sure ink in proper locations - see manual. Run the maintenance proceedures: cleaning then print nozzle pattern. If all colors are not proper after two or three cleanings, perform deep cleaning. Print nozzle pattern after each cleaning. This should clear up problem. If not, print head may need replacement.
Posted on Mar 06, 2009
efs_perpends
  • 1996 Answers
SOURCE: how to change ink jet cartridge canon 'pixma' printer mp160
Please go to this Canon link (click here) and enter the term "ink cartridge replacement" in the search window for a set of detailed instructions (with pictures) on how to replace your ink cartridges.
As you face the printer, with the scan cover open,in position to remove them, the black cartridge goes on your left and the color on the right.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take a moment to kindly rate this post....thanks!
Posted on Apr 09, 2009
realbat2
  • 68 Answers
SOURCE: printer won't accept cartridge
i sure u buy wrong cartridge for your MP450...if u want higher quality, u should buy CL-51 cartridge for colour and CL-50 for black..
fyi, CL-52 can only suitable for IP6210D / IP6220D printer. u can see yourself at this link :
http://www.canon.com.my/section/inkjetPrinter/supplies/
hope this help... ; )
Posted on May 26, 2009
SOURCE: Canon Pixma IP600D - error code 6502
Sometimes the Canon printers which use PG-5BK/CL-8 colour cartridges with chips will give error massages like 6502 or other types of error message to do with the cartridges, which has the orange light flashing and the printer will not work. Follow this procedure which quite often resets the printer and allows it to resume printing.
When error is indicated, turn power switch off so green light is extinguished.
First hold down resume button and then hold down power button so both are held down at same time
When green light comes on, continue holding down power button and let resume button go, then press resume button twice. Then let power button go.
Then press resume button four times, power button should be released before doing this.
Wait until printer settles down, if power is off, turn on. If power will not come on, remove power cord from back of printer, then wait 15 seconds before plugging back in again and turn power on. This normally solves the error problem - if not go through same procedure again.
Incidentally, you may find that if the chips had previously been disabled, the low ink warnings are showing again and they will have to be disabled once more. This would indicate that the above procedure clears the firmware memory of the disabling of the chips, this may be useful if you need some warranty work done on your
printer after the chips had been disabled.
Posted on Jun 10, 2009
How do you set a Canon pixma MG3022 to print only in black ?
You can't. On Canon machines they make you have a full set of good cartridges.
Apr 08, 2018 | Canon Office Equipment & Supplies
Canon PIxma E510 Error code E16
The ink has run out.
Replace the ink cartridge and close the Scanning Unit (Cover).
Installing / Replacing FINE Cartridge(s)
If printing is in progress and you want to continue printing, press the machine's Stop (Reset) button for at least 5 seconds with the ink cartridge installed. Then printing can continue under the ink out condition.
The function for detecting the remaining ink level will be disabled.
Replace the empty ink cartridge immediately after the printing.
Feb 24, 2015 | Canon Office Equipment & Supplies
Canon pixma E510 inkjet all-in-one
You can download the Canon printer drivers from their support WEB site. Please click on this link and select your model printer to download : - http://www.usa.canon.com/consumer/controller?act=DownloadIndexAct
Nov 25, 2012 | Canon PIXMA Office Equipment & Supplies
I need a driver for canon pixma e510
Oct 19, 2012 | Office Equipment & Supplies
Canon pixma ip2772 cartridge cannot be recognized
Pleas help me.
I have a Canon Pixma ip 2772 Printer, I used Original Canon ink Cartridge and it after refill. now i using original canon black and color cartridge but now have a problem. ink cartridge not recognized i used original cartridge 4.. pls. help me immediate
Jul 20, 2012 | Canon PIXMA Office Equipment & Supplies
My Canon Pixma MP160 printer is showing a error 5 code after i just installed a new canon color ink cartridge number 41 how do i bypass the color ink or fix it?
try to remove the cartridge from the printer and then try to print some docx,,, without the cartridge.... an error should say that the installed cartridge is not recognized... just try to print thrice or more then put back the cartridge... this should solve the problem.... thnx..
Mar 12, 2010 | Canon PIXMA MP160 All-In-One InkJet...
Is MP210 and MP240 the same? can i use the same cartridge?
no both are different
Here are the list of cartridges u can use
MP210
PG-30 Pigment Black
PG-30 Pigment Black Ink Cartridge
PG-40 BLACK
CL-31 Color FINE Ink Cartridge
CL-41 Color
MP240
PG-210 Black Cartridge
CL-211XL Color Cartridge
CL-211 Color Cartridge
PG-210 XL Black Cartridge
Nov 28, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Need to know which ink cartridge is compatible
it looks like it is gonna be 13400 thats the code for the cartridge
Jul 06, 2009 | Canon PIXMA MP150 All-In-One InkJet...
1,459 people viewed this question
k24674
jasbo
jasbo
