Question about Toshiba 32HLC56 32 in. HD-Ready LCD Television
I lost the picture, I still have sound. videos and games work it is only tv
Wii was being used. We went to switch back to TV mode and now only get blue screen or black screens. You can here the TV show but no picture. Games and videos still get pictures
  • 3 Answers
SOURCE: No Picture
It's the Y-Sustainer problem. However, they normally change the Y-Sus and Z-sus boards at the same time. It's a costly repair.
Posted on Apr 06, 2008
freetek
  • 5568 Answers
SOURCE: Completely lost the picture and sound. All that
You didn't mention from where your signal originates and that clue screen is common to many sets and means it is seeing no input signal.
The set would seem to be functional, otherwise you wouldn't be seeing the input selection menu.
While it is possible that the RF section/tuner (that handles the signal coming in) has failed, these are pretty solid.
If you have another set or can borrow one to connect to whatever source you have (antenna, cable, satellite) to see if a signal is, in fact, there.  As an alternative, you could connect your own signal source; VCR, DVD player, or, as it offers, HDMI or a PC and set it to whichever input you have supplied with signal.
Posted on Mar 30, 2009
falter
  • 245 Answers
SOURCE: Hiturned on TV and have a blue picture, how do i
go to menu and setting.. and adjust color... or set tv back to factory setting.......
all this settings will be on disply under menu
Posted on Nov 20, 2009
  • 5 Answers
SOURCE: Video stopped working. I get audio but no picture.
Sounds like the tubes may have went out.
Posted on Jun 05, 2010
SOURCE: my toshiba 22cv100u screen is black when I have tv on, i have sound but no picture
your backlight may be out....I working on one with same problem...the transformer on the backlight inverter board went bad, its about 12 dollars on ebay....but in your case, would require some troubleshooting to determine if you have the same problem. there is an access panel on the back of the tv, under that is 4 connectors, they are high voltage out to the backlight lamps. you would need a volt meter to determine if the lamps are bad or the board
Posted on Mar 15, 2012
Just bought an led tv .my wii was fine with tube tv now its controls are delayed.can it be fixed
The lag comes fr0m the digital picture processing.
Most televisions have a video game mode which can adjust the delay in rendering video from games. See if your television has a video game mode.
If not, a number of games that depends heavily on timing have a "Calibrate" mode to adjust to the delay on the TV. This is most common in rhythm games like Rock Band or Dance Dance Revolution. Look for the calibrate mode.
You can Google "Wii lag " for more info.
Aug 09, 2011 | Nintendo Wii Console
Wii game hooked up to new Sharp LED tv. TV is color and the wii is in black and white.
Usually this is either a cable or a mode issue. First make sure that you have the correct cable connections. (Composite video cable to a component video jack is one possible cause of the problem.) Component video cables are not included with the set but will give better results. However, composite video in from the wii's composite video out should give good results.
If you are using HDMI or component video cables, then go into the Wii video menus to select the correct mode for your tv. Check your TV manual and the Wii setup guide for details on the mode (resolution, etc) you should be using.
If the problem persists, try new video cables and make sure that they are fully seated on both sides. Try switching inputs if you have several available.
I hope this helps.
Jan 22, 2011 | Nintendo Wii Console
Wii has sound but no picture
just try to replace a new audio video cord first,
Jun 19, 2010 | Nintendo Wii Console
Connected to tv but no Wii screen when we switch
Was trying to use the component option on the screen, as this had the red, yellow and white plugs shown. Eventually tried all the other options and found that it was plugged into Video 1! Works perfectly. Should try all the options on the TV!
Feb 01, 2010 | Nintendo Wii Console
There is no picture or sound
Fiend your solution direct from nintendo. Here is your solution....
http://www.nintendo.com/wiiconsole/prob676ijt65/solution
afafggg4
Jan 03, 2010 | Nintendo Wii Console
Installation of wii
I had the same problem on a 32" rca crt. It worked fine, power was cut during electrical work and when it came back, "unusable signal." I went into the menu, then channel, then video input source. had to change it to the correct input "s-video in my case" Then it worked. GOOD LUCK!
Feb 14, 2009 | Nintendo Wii Console
I have video but no sound from the TV
hi there send it back to nintendo the sooner the better here is there phone number for them to collect it and repair
> Nintendo UK
Quadrant
55-57 High Street
Windsor
SL4 1LP
Tel: +44 (0)870 6060247 (Calls charged at National Rate)
Fax: +44 (0)2392 383 444
Registered at
Companies House, Cardiff, (31st January 2001)
Company No. FC022968
Branch No. BR005889
Managing Director
Satoru Shibata
if you need any othere phone number or address ill be happy to post it up for you cheers
Thanks From Me and FixYa
Feb 02, 2009 | Nintendo Wii Console
Has sound but no video picture for game playing
try changing the av to another channel or if you have access to a front panel or side panel on the tv set, try using this for your av leads 'red' 'yellow' and 'white'. Also check that the av lead is correctly inserted into the back of the wii
Oct 25, 2008 | Nintendo Wii Console
Nintendo Wii box light is on but no picture or sound from my tv
sometimes just sometimes tvs are funny, some tv's call it a "input select" others call it a "mode" or simply "input" and some dont have any they just want you to goto channel 2 on the tv and go back one more channel.
ushally all these modes are listed on the remote.
is it the origional remote? or is it a universal remote.
try those things above look over the remote again see if anything resembles any of that and if not
list the make and model of your tv and if your using a universal remote we will be able to figure something out for you.
Aug 12, 2008 | Nintendo Wii Console
Toshiba 32HLC56 32 in. HD-Ready LCD Television Logo
29 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
