SOURCE: CODE ERREUR L4 DANS UNE PHOTOCOPIEUR SHARP 5316
L4 mean this copier main motor is not move or run.
First time, Open your copier back cover and check any gear is broken,solve it .Or clean all mechanical which one jam.If you are not a technician so you call a service Engineer who are qualified this Brand.
SOURCE: MON PHOTOCOPIEUR AFFICHE LE CODE
L6 = Polygon Motor Lock Detection
Polygon motors are not serviceable items.
Try switching the machine off/on. If the code doesn't clear then you will need to get the motor replaced. Quite often the motor will have made a screeching or rattling noise before it fails.
Hope this helps
SOURCE: CAnon xerox Machine IR 2318
Hello, unfortunately it appears you need to replace the fuser film (probably the upper roll). I wish I had better news. Good luck!!
SOURCE: ma photocopieur shar 5516 marque
H4 error indicates the fuser is faulty and should be replaced.
