Cannot connect to internet>>>
I disabled my high speed or LAN connection and enabled it again, from then the internet is not connecting and the internet LED light remain red...please help!!!
  • 2,072 Answers
Power off your modem and router
Wait for about 1 minute
Power on just the modem and let it cycle through it's tests (about 1 minute)
Power on the router and let it cycle through it's tests.
Sometimes you need to repeat this a couple times.
Posted on Jan 14, 2013
  • virajith4cha
    virajith4cha Jan 14, 2013
    i did this since 2 weeks, but nothng happened..
  • Justin
    Justin Jan 14, 2013
    Did you verify the WAN connection is enabled on the router. Do you have an Ethernet cable from the WAN port on the router to the Ethernet port on the modem? Try plugging in a computer directly into the mode to verify the modem works.
SOURCE: Unable to connect via LAN with wireless router NETGEAR WPN824
I recently experienced this on laptop and desktop, using a lynksys wireless. I was able to go into each system to network connections, and tell it to connect. I haven't had a problem since........hope this helps you!
Posted on Dec 24, 2007
  • 287 Answers
SOURCE: LAN led light alway on and flashing
Reset the router:
While the router is powered on press and hold the reset button for 5-10 sec. Release the button and wait until the router boots up (1 min).
If this does not work then you can try this
Try setting it into recovery mode and loading firmware:
Unplug power cable from the router and press the reset button. While holding the reset button plug the power cable in. Continue holding the reset button untill you will see LEDs on the router flashing rapidly.
You should be able to log into the router - you will see a prompt to load firmware. The firmware is available on our WEB site: http://www.dlink.com.au/tech/
Note - suggest you d/l the firmware BEFORE you reset router
Posted on Jul 06, 2008
  • 35 Answers
SOURCE: Problem connecting to Netgear WNR854T Gigabit edition
The WNR854T will downspeed to 10Mbps on its ethernet ports so speed should not be a problem.
Suggest you try crossover ethernet cable between router and dsl modem.
Regards Brian, UK
Posted on Mar 20, 2009
marked
  • 6487 Answers
SOURCE: AT&T 2WIRE 2701HG-B connection problems
This is a problem with the firmware of your device so the first thing that you can do here is to do a firmware update on it to correct the problem, you can get the firmware from your ISP of the manufacturer of the device...
Posted on Sep 10, 2009
Testimonial: "Thx, so whats the firmware, and can i get it from AT&T?"
SOURCE: I have DIR-600 and a LAN connection(always
u have to setup the router in it's settings... by entering 192.168.0.1 into the browser and use username : admin ... without password
Posted on Dec 11, 2010
I can't connect to WiFi. Any advice?
Is the wifi enabled, can you see any wifi networks? If not, make sure wifi is enabled, if there is button on laptop to disable/enable wifi connections, swich wifi on.
Check from control panel -> network (network and sharing center in Vista/Win7) -> change adapter settings. If wireless lan adapter disabled (grayed out).
Jun 04, 2014 | Computers & Internet
I was browsing with my digisol dg-bg4011n,when i disabled the connection and enabled it again its not working..i mean the internet LED light is not turning green...Please help,I'm in big trouble..
try a fact resest should be a pin set hole in the back take a pin/paperclip tooth pick Press & Hold for 10 sec that should reset rotuer to factory defaults. That may help if not unplug router from power & unplug wan ethernet or unscrew wan coax for 30 sec if that still dont work call your internet service provider they can do remote reboots that may help
Jan 13, 2013 | Computers & Internet
How to enable Motorola MC3190 to access internet through LAN
Do you have Wireless Fusion on your machine?
If so, Enable Radio-->Scan for your WLAN-->Connect with a profile. If all settings are correct, and still can't get it associated, try disabling 802.11d from Wireless Fusion Menu-->Options-->Regulatory-->uncheck 802.11d.
Mine works after disabling this. Hope it'll work for you
Feb 07, 2012 | Zebra Symbol MC3190G Handheld Mobile...
Acciring network address but wont conect cant get ip address
try to disable the LAN by clicking Start > Control Panel and then click Network Connections . Then right click Local Area Network connection then click disable. Restart the pc and do the same thing except you will enable the Local Area Network. Check if you will have internet connection..
Apr 09, 2011 | E-Machines M2350 Notebook
Internet connection
Dear Sir,
plz folow this step
For XP-> go to your control panel -> click under network connection -> right click on Local Area Connection and disable it -> right click again to enable it back.
For Vista-> go to your network and sharing center-> click under manage network connection located on the left hand side -> right click on Local Area Connection and disable it -> right click again to enable it back
if the probelm not solved then give IP address manualy for internet above same processdure
Apr 08, 2010 | Acer Aspire One PC Notebook
Internet connection won't register on compaq laptop
You must go into "Internet Connections" and enable your ethernet/ LAN connection. It is advised to disable the wireless connection in the interim. Thank you, Dana
Feb 15, 2010 | Computers & Internet
No lan connection
You can enable it again, just goto control panel, open network connection, there will be local area connection icon, Right click on it and click on enable.....
If there is problem again use motherboard cd and install lan card drive again...
Feb 11, 2010 | Intel D915GAG Socket 775 Motherboard -...
The computer does not show the internet connection in the monitor. Before I reinstalled the windows it shows the message: no connectivity or limitated connectivity. The comcast modem was damaged so they...
Even though it does not show the connection on your monitor, the connection may still be working. Did you post this problem from the same computer? If yes, then you are fine.
Dec 29, 2009 | Dell Dimension E510 PC Desktop
Wireless does not show up in Network Connections
Did you try - after switching on the "antenna switch" or WiFi hardware - to "Enable" the WiFi adapter, under (XP) Start - Settings - Network Connections - LAN or High-Speed Internet - Wireless Network Connection? (select, right click and select Enable)?
p.s. Once your WiFi hardware is recognized (by Win XP) there is (should be) always a "Wireless Network Connection" in your Network Connections, enabled or disabled, active or not.
May 21, 2008 | Toshiba Satellite M45-S331 Notebook
Plugged ethernet cable innto laptop from cable modem and nothing
Click Start / Control Panel / Network Connections.
Your Ethernet status should show under LAN or High Speed Internet. It might be disabled, in which case, right click & ENABLE.
Let me know how you get on.
Jan 10, 2008 | Dell Latitude C640 Notebook
Computers & Internet Logo
David Payne
David Payne
