Question about Refrigerators
The compressor won't stop running
The temperature in the freezer frequently fluxuates
  • 1 more comment
  • kaes1195
    kaes1195 Jan 13, 2013
    It is a ge profile esl22xgpc bs
  • kaes1195
    kaes1195 Jan 16, 2013
    The solution was helpful, but we need more help. Thanks!
  • kaes1195
    Not a profile , but an Eterna, sorry, wrong info.
Sounds like the contacs on thermostat, has welded togher. Compressor will run till it starts pumping liquid frezon, then over heats ,then shuts down till it cools off , and starts all over again
replace thermostat..
Posted on Jan 13, 2013
  • 1 more comment
  • kaes1195
    Thank You! We will try that.
  • kaes1195
    We replaced the thermostat. It was checked and had continuity, but the epoxy
  • kaes1195
    was lifting out so probably did need replaced. Still having the same problem after replacing. The compressor stopped running and it the ice maker dumped ice, then 10 minutes later the freezer temp went up to 20 degrees F and about 10 min later it was up to 30 degrees. Fridge went up to 40 degrees. Now the compressor is running again and it is starting to go down. a little below 20 degrees in the freezer., this is after about 35 minutes. It will go back below zero in time, but this seems like to much fluctuatuin in temperature. Could it be that we also need to replace the thermitstors? Could the seal be bad? I thin the compressor just stays off too long once it does shut off. Any help would be very much appreciated!
kram26
  • 544 Answers
SOURCE: Compressor runs less frequently freezer warms between cycles
if the compressor is running your ref. should be getting cold. Their is a defrost timer but when it is in defrost the compressor shuts off. I think you do have a leak.
any further question let me know.
thanks,,
Posted on Mar 29, 2009
ailia
  • 175 Answers
SOURCE: Compressor area above refrigerator is getting very hot
Check Thermostat.
Proper Cleaning/Defrosting of fridge and freezer.
Proper Placing and Distance from wall.
If your hand bear the body temperature of that specific area then its normal.
Contact technician to verify Freon pressure.
Best of Luck,
Regards:
Hassan
Posted on Jul 27, 2009
rickead1
  • 1998 Answers
SOURCE: Westinhouse Upside down BJ424S-R6 Freezer works
if the freezer is cold and the refrige is warm then you have a defrost problem remove the rear panel of the freezer inside the freezer you will most likely see an ice build up where the condensor is either the fan is not working to blow the cold air into the frige side or the tstat or heater have gone bad. It is very rare in all actuallity for the heater to go bad so it would most likely be your fan which when u take off the panel you can observe if it is working or not any ice build up should be melted witha hair dryer if the fan is running fine then the next step would be to do a continuity check with the fridge unplugged on yr t-stat or thermal relay disc its called both its the small round disc with two wires that is hooked to one of the lines going to the condensor (usually foudn on the left side) check both these and message me back and if you have any further questions message me them back as well and please also remember when this chat is concluded to rank how this opinion has helped in your appliance situation thanks again
Rick
Posted on Dec 27, 2010
imufo2
  • 3773 Answers
SOURCE: Hello : I have a Samsung refridgerator about 8
NOTE: This
is a multi-solution answer since I don't have all the tech from your question to pinpoint your problem
But the solution is in here generically, if you read and study the solutions very,very carefully.
First I would check cold control. Thats where you turn it off, if your temp is not warm. it can
be defective and not shutting off. If your temp is warm proceed with the following.
I would check the fan in the freezer. Listen to see if it is running
It moves air to the ref from the freezer
Then check to see if FREEZER CONTROL is turned WARMER WHICH MAKES THE REF COLDER AND VICE-VERSA. SEE?
The ref. temp should be about 33-35
The Freezer temp should be 0 to 10 Any thing below these temps is overkill and a waste of elect
The higher the number you turn it up to is the coldest
But is probably a common defrost problem The ice build up
is not being melted by the defrost system.The fan can't blow through the coils into the fridge.
Take out back panel of freezer to check for ice buildup. The coils should be clean.
There are three components to a defrost system- a heater,heater thermostat, and a timer unless you have a defrost electronic card.
Its best handled by a Technician but you could possibly do it by taking your model number to the nearest appliance parts store and asking for the parts. They are mostly located in freezer ,behind back panel on freezer coils.except the card which is usually located in ref The parts store will have info
Also check fan undernearh Ref in the rear
Clean condenser coils underneath
Make sure back cover is on the fridge. Some take them off and throw them away.
make one out of cardboard if its gone, using the holes of the old one.
.I'm including my article on Refrigerator Repair for your help and convenience.;
Please click or copy and paste into browser for Article
http://www.fixya.com/support/r5816737-fix_refrigerator_psychologically
If
you need more help go here:
http://www.applianceaid.com/procedures.html
MORE
TIPS AND TRICKS:
STOP PAYING FOR EXPENSIVE WATER FILTERS FOR YOUR REF. DO THIS====
http://www.fixya.com/support/r9962087-stop_paying_high_price_refrigerator
WATER SPLASHING IN FREEZER AT ICEMAKER
THE FILL TUBE IN BACK OF REFRIGERATOR CAN SLIP
AGAINST THE FILL RESERVOIR CAUSING A PARTIAL BLOCKAGE
OR BECOME CLOGGED WITH ICE.
REMOVE THE ICEMAKER AND INSPECT THE FILL TUBE.
RUN WATER IN TUBE TO ELININATE BLOCKAGE AND CHECK
TEMP IN FREEZER. IF TEMP IS BELOW 0 DEGREES, THATS
OVERKILL AND USUALLY A WASTE OF ELECTRICITY TO KEEP IT THAT COLD, NOT TO MENTION THE FILL TUBE FREEZING UP
Thanks for using fixya
Leo Ponder
imufo2
Please VOTE FOR ME AND GIVE ME YOUR TESTIMONIAL IF POSSIBLE, IF THIS WAS HELPFUL
ITWILL BE MUCH APPRECIATED.
Posted on Sep 07, 2011
machinetech7
  • 1344 Answers
SOURCE: Freezer alarm goes off even though the freezer temperature is below -20C. The compressor runs continuously.
From the sound of it the temperature control is bad. I'm only stating this because if the cold control (temperature control) isn't converting the temperature to electrical signal properly, the machine will constantly run trying to reach the set temperature the cold control is set at. Question, is there a digital display showing the temperature or did you use a meter or thermometer to check it, and how is the temperature set, by a digital control or a dial, rheostat or any other type of manual control?
Posted on Jun 22, 2012
How frequently should the compressor run on a fridge?
Hello;
My name is Peter. I am a retired field service refrigeration technician.
The model number provided does not register. Your model number is located on the inside wall of your fresh food section.
Your freezer is your only source of cooling. It will meet its setting before meeting the refrigerator temperature.
The normal setting are -2 to +2 degrees F. for the freezer and 35 -40 degrees F. for your fresh food section.
Your freezer will go about 10 degrees F. above the set temperature. Then when it reaches 10 degrees F. below the set temperature the compressor will kick in.
You have condensing coils either under your unit or a canister in the back which gets ride of the heat. When the condensing coil is plugged up with dust, this could affect your cooling by as much as 40 degrees.
I do not think this is your total problem.
Feel the face of your separator wall between your freezer and fresh food section. Is it hot?
Your problem is your condenser fan in the lower right back of you unit is burned out.
So, you can not dissipate the heat.
Remove the lower back cover. Take a common household fan to blow air under your unit.
Your compressor is running to make up for the heat that the condenser fan can not dissipate.
Feb 27, 2015 | Electrolux Refrigerators
The freezer won't keep normal -10F temperature, but stays at -35F to -40F at all times
Thermostat or start relay is defective and causing the compressor and fans to run all the time. Here is a manual for all models=> HERE
Sea Breerze
Feb 10, 2013 | True 49 cu. ft. / 1388 liter Commercial...
It freezes but won't stop
as long as the compressor is running on your freezer the longer the fan runs has to too cool the compressor . . .thermostat problem
Jan 11, 2013 | Boating
My Fridgidaire upright Gallery freezer is freezing my food but the appliance seems to be constantly running and the temperature control on the outside is reading 29 Celsius when it obviously isn't
Hi Susan Abboud - Modern freezers have increased storage capacity and keep more even temperature that may require the compressors to run longer but use less energy. Was the unit disconnected previously for any reason? If so, freezer requires a minimum of 4 hours to cold down completely. Confirm that the temperature control is not set too cold and that the door is not being open frequently. A dirty, cracked, worn or poorly fitted door gasket can allow warm air to enter the unit causing it to have to run longer to remove the warm air. Leaks in the door seal will cause freezer to run longer in order to maintain desired temperature. Cleaned the gasket, if it is too damage then it will need to be replace. You can check and see if the door seal is bad by, placing a dollar between the gasket and cabinet. Check to see if the door is being blocked by anything stopping it from closing properly. If nothing is stopping the door then replace gasket. Keep in mind that there should also be at least 4-6 in of air space on all sides of the unit. If freezer is built in or has items stored on top that cover the unit, the can cause long run times, high temperature in the freezer and premature failure to the unit. Do not block the toe grille on the lower front of the unit. Sufficient air circulation is essential for the properly operation of your freezer, about 3 inches around the unit.
Nov 22, 2012 | Frigidaire 20.6 cu. ft. / 583 liter...
Freezer won't get below 30 degrees at the highest setting, food won't freeze.
Possible that the gas pressure is down to low gas or leak on the system. Also it can be due to faulty thermostat, faulty compressor if the compressor is working all the time and reaching the set temperature. Also if the compressor is not cutting off this must be a suspect.
Aug 24, 2011 | Kelvinator Freezers
I have a sub zero 361rfd. The freezer portion is no longer cooling, however the fan still runs. Also, The refrigerator is set to the coolest temperature but I suspect it's not sufficiently cold....
Check the temperature setting Assure that there is enough room for air flow in the freezer or freezer Check for air flow restrictions in vents Test the temperature control Clean the condensor coils Check the door seals Test the door switch Test defrost heater Test defrost timer Test evaporator fan Check for a clogged drain tube Check for refrigerant leak Freezer is too cold
Check the temperature setting Test the temperature control Freezer is noisy
Hissing and popping is normal, it is the defrost heater. Check that the freezer is level Check the drain pan Check the condensor fan Check the evaporator fan Inspect the compressor mounts Freezer runs continuously
Defrost the freezer Clean the condensor coils Check the door seals Freezer starts and stops frequently
Clean the condensor coils Check the outlet voltage Test the condensor fan Test the compressor relay Test the overload protector Test the compressor motor Freezer does not defrost automatically
Test the defrost timer Test the defrost heater Test the defrost thermostat Freezer has an unpleasant odor
Remove spoiled food Clean freezer interior with a solution of h Clean freezer interior with a solution of hot water and baking soda Clean the door seals Remove breaker strips and check for wet insulation Water on floor outside of freezer
Check the drain pan If you have an ice-maker, check the water supply hose going into and coming out of the water inlet valve Water inside the freezer
Check for a clogged drain tube If you have an ice-maker, check freezer and ice-maker for level
Hoping that this will help to solve the problem....
Aug 18, 2011 | Refrigerators
The freezer on my refridgerator wont stop running. I can hear it running and when it seems like its going to go off, it turns right back on again and again. I have a GE. Not sure of the age. Doesn't...
Hello and Welcome to FixYa!
Well, by the details, you quoted, it seems, either the main power supply is loose and needs to be tightened up. Also, do make sure, that the compressor run Capacitor is working properly, is not leaked or faulty or loosely connected. Moreover, there is a possibility that the thermostat unit (That controls the switching of the compressor/ heater and other temperature details) is not working properly and kicking the compressor frequently. Hope, now you got a wider picture of the possibilities, you need to start with. Feel free to ask, more details, or any question regarding the query. Hope to hear from you Soon..
Concerned.
Aug 11, 2011 | Refrigerators
Kenmore 253. 9287413 Can't get the freezer to get cold enough. Freezer alarm keeps turning on and the temperature is only 25 degrees inside. Temperature alarm light stays on all the time. Quick freeze...
You can fix this, just follow the procedure given to enable get back your refrigerator going,
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
I hope this will help in solving the problem......
May 10, 2011 | Refrigerators
Freezer not cold.
Test defrost heater
Test defrost timer
Test evaporator fan
Freezer is too cold
Freezer is noisy
Check the drain pan
Defrost the freezer
Remove spoiled food
Check the drain pan
Hope this will help in solving the problem.....
Oct 07, 2010 | Frigidaire Refrigerators
Freezer stopped working.
It might be the compressor making the noise.If it is,the compressor will start/stop frequently.This means that it is tripping on overload due to mechanical damage.Only way to solve this prolem is to replace the compressor (if the freezer is still in a good condition).
Regards
Andre Nagel
Mar 25, 2010 | Whirlpool 20 cu. ft. / 566 liter Upright...
Refrigerators Logo
82 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
