Question about Boating
How do i remove lower unit on 1973 50hp johnson
3 Suggested Answers
SOURCE: how to remove the lower unit on a 35hp Johnson outboard yr 2000.
if you haven't fixed this already, take the pastic water pick up covers off there are two joiner nuts in there undo them, there is a plastic cone on each end take them off and it will slip through. I own the same model and year outboard.
Posted on Jan 13, 2010
  • 159 Answers
SOURCE: lower unit removal for johnson 225 hp outboard
Yes
Posted on May 19, 2010
Testimonial: "ill give a go in the morning thanks again"
After running my johnson 4hp 2s for a couple of hours in the bay it starting giving a strange noise and then cut out.i managed to get it started again but coudnt get above half speed.
Hey Pete.. this sounds serious.... will it rev up while in neutral? If it revs freely and high.. the power head should be ok.. if it will NOT rev up freely and high.. STOP - you are causing more damage..
Check the compression with a good gauge..it should be 125psi minimum.. with no more than 10 psi difference between any two cylinders.. DO this WITH the THROTTLE WIDE OPEN...
Can you turn the propeller by hand while it is in neutral?..Of not.. this is the problem.
Shop Evinrude Outboard Parts Johnson Outboard Parts
Lower Unit Replacement Rebuilt Lower Units Aftermarket Lower Units
REMANUFACTURED LOWER UNITS
https://www.boatengine.com/lower-units/remanufacture
Refurbished Lower Units for Yamaha Mercury OMC Johnson Evinrude
Jul 09, 2017 | Cars & Trucks
I have a 50 hp Johnson outboard or do I disconnect the shift linkage to get the lower unit off
have a look at the videos
How to remove the lower unit on a outboard engine - YouTube
? 3:24
https://www.youtube.com/watch?v=R6wVMc8GD0w
Mar 29, 2015 - Uploaded by Greg Drinkwater
How to remove the lower unit on a 1989 Johnson 88 SPL Help me remove lower unit. Johnson 90 hp ...
Johnson 50hp Outboard Lower Unit - YouTube
? 2:15
https://www.youtube.com/watch?v=DnU7vKcJkeE
Apr 9, 2016 - Uploaded by Stacy Wyoming
Removing Bearing Housing From a 50 HP Evinrude - Duration: 2:15. Brandon's Garage 274 views ยท 2:15 ...
how to remove lower unit on johnson outboard - YouTube
? 0:47
https://www.youtube.com/watch?v=_ygxZSxU6-I
May 24, 2016 - Uploaded by 2222buster2222
How to remove your lower unit on a 1984 Johnson Outboard 70HP.
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump ...
? 24:26
https://www.youtube.com/watch?v=Hv8gXqsO2fg
Jun 3, 2015 - Uploaded by Ralph Pierre
60 HP Johnson Evinrude VRO Lower Unit Removal and Water Pump Service. ... Just bought a Bass Tracker ...
50 hp Johnson outboard remove lower unit Google Search
Jul 07, 2017 | Johnson Boating
Where do I disconnect the shift linkage to take the lower unit off of a 1983 Johnson 35 hp. I disconnected it behind the water inlet but lower unit will not come completely off/
there are about 5 bolts that need removed .one is kinda hidden under the little circular steering skag , and there will either be a link on the shifting rod midway down or the entire rod will need unhooked at the top. neither place being easy to get to . good luck
May 16, 2014 | Boating
I have a 1998 Johnson 130 hp outboard motor. Have already taken lower unit off but can't get it apart. Is there a secret to taking the lower unit apart? I would like to have a diagram.
Here is a site where you can purchase the service manual to repair your outboard motor:
http://www.tradebit.com/G/manuals/-/0-0-johnson+130+hp
Jul 13, 2011 | Computers & Internet
How do I check the oil level in the lower unit of a 70 hp Johnson outboard?
remove the bottom drain screw first then place a tube of the proper lower unit oil in it. then remove the top screw and gently squeeze the tube of oil and when full it will slowly come out the top drain hole. when it does replace the lower plug first then the top plug second. make sure the seals are in good shape and plan on changing the oil in the lower unit yearly for proper maintainence. make sure you buy oil designed for your particular type of motor. good luck.
May 29, 2010 | Boating
I need lower unit lube capacity for johnson 200 horse power out board
there is none listed . you fill them from the bottom plug with the top plug removed . when lube comes out the top hole it's full . put top screw back in which will not let oil out the bottom then put in the lower plug
Apr 10, 2010 | Boating
How to remove the lower unit on a 35hp Johnson outboard yr 2000.
Dec 30, 2009 | Boating
9.9 johnson want open up
Is it a reconditioned lower unit?
What sort of oil did you put in the lower unit?
Sounds like there is some drag in the lower unit causing the engine to bog down. It will work fine on a stand in neautral however.
How does it go in reverse on the lake? Can you get full throttle?
Jul 24, 2009 | Boating
Disassemble 88 SPL Lower Unit
I dont have a diagram to send you, but if you take the model number and serial number to you local Johnson/OMC dealer they have all the diagrams and have even photo copied them for me to use
Boating Logo
53 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
