Question about Sewing Machines
Pfaff expressions 3 feed dogs will not raise when switch is moved right
Manual says, to raise feed dogs move switch on front of machine to the right. This does not work. Feed dogs will not rise.
  • david conway Jan 15, 2013
    Thanks SewTechWayne, solution worked temporarily - Am assuming need to manually raise dogs will continue until cam sorted.
    Genius:
  • Sewing Machines Master
  • 1,669 Answers
If the switch feel very easy to move then the linkage to the feed dogs is off somewhere. The machine will need to be opened and checked where and what.
Posted on Jan 13, 2013
SOURCE: feed dogs
I was having trouble with this too, but found more help online...you have to switch the dog feed back to 'up'....then turn the needle wheel toward you....the feed dog should snap back into place :)
Hope this helps :D
Posted on May 01, 2009
SewTechWayne
  • 186 Answers
SOURCE: Raising and Lowering the feed dog on Janome 4900 MC
These machines are known to have this problem. The feed lift cam has a groove worn in it that won't allow the feed dogs to come back up. It is on the lower shaft and needs to be replaced. You can get the feed dogs back up by taking off the needle plate and lifting them up manually while turning the hand wheel. They should stay up until you drop them again.
Some people will not replace the cam and live with it.
good luck!
Posted on Feb 08, 2009
SOURCE: Feed Dogs won't feed fabric.
I can not find the screw. does anyone have a picture of where the screw is?
Posted on Jun 03, 2008
madelinesalo
  • 59 Answers
SOURCE: machine runs only in reverse and feed dogs go up and down
adjust the wheel of your machine
Posted on Apr 03, 2010
SOURCE: janome memory craft 7500
the machine comes on , its on auto but the foot pedal does not make contact.
Posted on Feb 19, 2011
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
I lowered the feed dogs for the first time to free motion quilt. Now I cannot raise them. Moving the button to the rights has no effect at all.
Some machines need the dial put in a certain position, try moving it about as you try to move the feed dogs. The presser foot must always be up.
Nov 02, 2015 | Sewing Machines
The piece that moves the fabric is down ( as nedded for embroidery) it should be up for conventional sewing, please help me.
look in the operation manual for the feed dog lever and push it to the up position so the feed dogs will come up..
Jun 06, 2015 | Sewing Machines
Bar that sewng foot is attached to for raising & lowering suddenly will not drop sweing foot all the way down to plate. Any suggestions on how to fix?
Perhaps you accidently moved the switch that enables free hand embroidery? It's up and under next to the pressor foot lever. Slides forward and backward. Forward the pressor foot will go all the way down to the feed dogs. Slid back and it keeps the foot up off the feed dogs but allows the thread tension to work properly. It would be easy to accidently move it when operating the pressor foot raise/lower lever.
Aug 31, 2014 | PfaFF Sewing Machines
How to set 2140 for free motion sewing
Which model are you using? Creative 4.5?, On the newer machines it drops automatically once the embroidery attachment is hooked up. On older Creatives v2.x there is a slide lever in front of the presser foot on the front.
Sep 26, 2012 | Sewing Machines
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link mechanism.in addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Fabric Won't Move
I don't have this machine, but any machine I've had that you can lower or raise the feed dogs had the switch in the bobbin area. Mine is on the right side when you flip down the little door. It moves up and down to move the feed dogs. good luck
Dec 29, 2008 | Euro-Pro Shark 60 - 384
Feed dogs
Hope this helps :D
Mar 18, 2008 | Sewing Machines
Sewing Machines Logo
287 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
