Question about Cobra CPI-2575
Cobra inverter overload
Overload
    Genius:
  • 1,669 Answers
Check out this manual:
http://search.aol.com/aol/search?&s_qt=sb&q=Cobra+cpi-2575+instruction+manual&tb_oid=07-01-2013&s_it=amonetizetest1-ie&tb_mrud=07-01-2013&tb_uuid=20130107163427450
Posted on Jan 13, 2013
Cobra power inverter is blinking "default". Why?
I don't know the model you have but green usually means it's on an working. Red means you have a voltage overload or it got to hot an needed to shut down until it cools off. Hope this helps
Mar 12, 2017 | Cobra Electronics - Others
I replaced the 35amp fuses with 40s in my 1550 cobra power inverter will that cause the olp code to pop up
The olp overload refers to Watts and the fuse is monitoring Amps! The rule is replace fuses with the same or lower but in this case it isn't causing the olp!
Oct 22, 2014 | Electronics - Others
My cobra 1500 watt inverted doesn't come on wen I
You may not have adequate input voltage. And unless you are hooking up to a forklift battery, the battery will not have adequate current delivery capability for any more than a few seconds at full power of the inverter.
1200 Watts is 100 Amps. 1500 Watts is in the neighborhood of 130 Amps.
Jan 17, 2012 | Cobra Electronics - Others
I had a monitor and xbox 360 power supply plugged into the inverter. It has been working for at least 2-3 months now just fine. Then all of a sudden, it turned off. I unplugged it and thought maybe it...
  • First thing I should ask is have you tried to plug something else into the inverter to see if it is the inverter or a surge messed up your monitor and X-Box?
  • When you say turned off do you get a solid red light when the inverter is on and you are trying to get your X-Box and monitor to work? A solid red light means voltage overload.
  • A blinking red light means you are having a current overload.
  • If the internal alarm on the inverter goes off and shuts down with a red light this means you are having a voltage shortage.
  • If the red light starts to blink this is a temperature overload.
  • Keep in mind that this inverter will start automatically back up as soon as what ever issue it is detecting is resolved. There is no fuse to check inside.
  • If your inverter shuts down from thermal overload then wait 15 full minutes before trying to turn it on again.
  • If you don't have any blown fuses and no burned wires make sure that if you are using over 150 watts and hour you go right to the battery rather than a cigarette light adapter as the stress can burn them wires connecting to the cigarette lighter up.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Jul 13, 2011 | Cobra Electronics Cobra Cpi-480 400w Power...
I have a 900 watt microwave when i turn my microwave on it blows the fuses in my cable what size fuse do i need
hi there, if you're using your power inverter to run your microwave oven isn't it? surely it is not advisable to plug this appliances for this really consume a lot of power...and eventually overload your PWR Invrter..if you use you power inverter in diff. load like lightings or a small dvd plyer and runs smoothly...is your microwave has no deffect if plug in wall socket and still blown the fuse...you have a deffective microwave oven..every time you replace the fuse w/ same type or ampereage and still blown you have a shorted power supply...try to bring your microwave oven in service center...nice day..
Feb 12, 2011 | Cobra 2500w Power Inverter
M/n cpi 1575 I've had my inverter installed in my
it indicates an overload situation
not enough information provided as to voltage supplied to the inverter and the voltage of the grinder
examples are for 110 volts ac with a current draw of 4.2 amps the wattage is 462 watts or for 240 v ac with 4.2 amps the wattage is 1008 watts assuming that it is 240 volts and the inverter has a maximum ate of 1000 watts then it is overloaded and circuit protection is cutting in
check the wattage of the inverter and the wattage of the ac units you use and if there is not a 25% difference in favour of the inverter then it is an overload situation
Jul 27, 2017 | Cobra ® Power Inverters
Can A cobra inverter be plugged in to 115AC for DC 12volt output
in a word no!,,,,it cannot and you may blow it up if you hook it up to the 115ac volt supply,,,in side it there is a switch mode power transistor,,that bumps up the 12 volts to 115 volts it only works the one way,,that is 12 volts dc in and 115 volts ac out,,,,
Feb 22, 2010 | Cobra 2500w Power Inverter
Power inverter
There are 8 40A fuses inside this unit. In the following pics you will see a bank of 4 and another bank with 3 of the 4 removed. I'm currently working on mine as it will cost me more to ship and have Cobra repair than I paid for the unit ($133 to repair). Good luck with your problem
Jun 18, 2009 | Cobra 2500w Power Inverter
2000 watt cobra inverter keeps saing olp, overload
2000w means is out off rang load 2000w plus then alarm beep have running.
Mar 24, 2009 | Cobra CPI 1000 DC to AC Power Inverter
Cobra CPI-2575 Logo
270 people viewed this question
Top Cobra Computers & Internet Experts
richie46
john h
Are you a Cobra Computer and Internet Expert? Answer questions, earn points and help others
