Question about Nordic Track Exercise & Fitness
Hi, on my c1800 im seeing jug ' in my time display and ever so often the machine is beeping but no response to get started.
Brushes are properly placed
    Genius:
  • 1,669 Answers
Try this website, please:
http://www.livestrong.com/article/410922-the-controls-are-not-working-on-a-nordictrack-treadmill/
Posted on Jan 13, 2013
Lg intellowasher wd1074fb
When you see the DE error code, it means a "door error". This is a sign that either the door is not shutting, locking or opening. Most of the time, this is a simple fix and service is probably not needed. Check for something stuck or lodged in door. Check door gasket. Check door latch.
May 13, 2014 | Washing Machines
Running machines broken
Dear Sir:
Please adjust, clean very well, and tigh the connector from Reed switch see the diagram attached.
2) Tight the flexible cable from keypads + connector from display board vs lower board.
After your fix it RUN the software calibration for diagnosis +trouble
sincerely. God bless you
Apr 20, 2012 | Exercise & Fitness
I have one biostar motherboard.. MCP6P-M2. . the system is no display no beep on P.O.S.T... Im not sure if the processor or motherboard is faulty,, can you help me?? thanks
First replace the RAMs and check.
If the RAMs are totally useless, you will hear beeps. But there are times when the computer won't start or beep due to RAM errors.
Believe me, I'm talking with several years of experience.
Sep 12, 2011 | Biostar MCP6P-M2 Motherboard - v6.0,...
There is an EE code. The machine just beeps.
EE
Remove your washer from the power source if you see an "EE" error code, where the first E is missing the top part of the letter. Your washing machine has a serious malfunction, and you must contact a technician.
A bit odd that as error code EE does not exist for washing machines, it's a refrigeration error code. Unless of course part of the display (led) has been damaged and the code isn't displayed properly.
Hope helps.
Jun 27, 2011 | Washing Machines
Delonghi Magnifica Coffee Maker the milk is not frothing properly - there's lots of steam & very little milk being issued from the spout We clean the milk jug each day, have adjusted the plastic tube...
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Sep 04, 2009 | DeLonghi Coffee Makers & Espresso Machines
C1641 intermittent beeps and won't start up
Is is possible that the RAM you put in was not sited properly. Just check it to see if it is right. You might need to troubleshoot by removing one peripheral at a time. Try removing the keyboard, and turn it on and see what happen. If same, mouse, network card, etc until you find the issue.
Jul 23, 2009 | E-Machines C1641 PC Desktop
Machine will not drain water or spin
hi..Most washing machine have a drain filter that can become
clogged over time.Front load washers typically have a small
removable panel about the size of a half sheet of paper on the
bottom front of the machine.the filter is inside.
check it out..
thank u..
kindly rate my response..
May 09, 2009 | Hotpoint Aquarius WF210 Front Load Washer
I get a series of about 8 beeps when I turn on
hi,
usually 8 beeps means that the issue with the mainboard chips as well as processor.When u turn on the machine then check for the blinking of the lights on k/b if they are blinking then processor is fine and issue with board.
Feb 17, 2009 | EliteGroup K7S5A Pro Motherboard
I have the HAIER HW-C1260TVE-U washing machine, and for some reason it won't do the spin cycle? at the end of the programme in says something like "UNB END". Any ideas?
Hi Mate;
Just had the exact same problem with the spin cylec and now its stopped completely, I was getting ERR 7 on the display, its telling you that there is something wrong with the motor.checked the motor and found that one of the Carbon Brushes was sticking/Stuck, Just 2 phillips head screws and the carbon brush is out, mine had a bit of melted plastic/casing snagging the Carbon brush, i just jusd a bit of fine sand paper to clean the Brush, put it all back together and lo and behold everyting works.
Hope this helps
Listed below are all the error codes:
Display messages:
Err1: Error message. Door is not properly shut 20s after program is started.
Correction: Shut the door properly.
Err2: Error message. Drainage error, water not emptied within 4 min.
Correction: Clean the filter and check the drain hose for blockage. If error still exists, please contact the maintenance personnel.
Err3: Error message. Temperature sensor is not properly connected or damaged (display at the end of a program).
Correction: Contact the maintenance personnel.
Err4: Error message. The heater may be broken or the desired temperature is not met within the specified time due to an overloaded laundry (display at the end of a program).
Correction: Reduce the load and restart, or contact the maintenance personnel.
Err5: Error message. The required water level is not reached within 10 min, or the water level exceeds the protection value.
Correction: Check to see if the tap is turned on and the water pressure is correct. If error still exists, contact the maintenance personnel.
Err6: Error message. Motor speed error. It may be not properly connected or damaged.
Err7: Error message. Motor overheat protection or is damaged.
Err8: Error message. Water level exceeds protection value.
Regards
Bull
Jul 29, 2008 | Washing Machines
Exercise & Fitness Logo
49 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
Electro Med Services...
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
