Question about Cuisinart Dcc-1400 Coffee Maker, Brew Central 10-Cup Thermal
Cuisinart dcc-1400 has leaking heat element and just need place to purchase new element. No one seems to sell this item. Does anyone know where this part can be purchased ,cuisinart.com does not sell this part or any repair parts for coffee makers, only accessories.
  • 19 Answers
SOURCE: Cuisinart Coffee Maker DCC 2200
The user manual is a free pdf download from the cuisinart web site.
Posted on Jan 19, 2008
SOURCE: Cuisinart Coffe Maker has no power
Talked to Cuisinart tech support today and they told me to unplug and leave it for 2 hours... that resets it to the factory defaults. Worked for me...
Posted on Feb 19, 2008
  • 4 Answers
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
Posted on Nov 15, 2008
  • 13 Answers
SOURCE: Cuisinart coffee maker turns on but will not brew.
Well, you could try unplugging for an hour. Sometimes that helps, but these have been having a lot of problems (but don't ask their customer service that, they can't admit it but I'm pretty sure they all know it!). I would say call customer service anyway if it's under 3 years old (800-726-0190) after you've unplugged it and let them know what's going on (model and serial # are both located on the bottom of the unit, stamped in the black part). If it's under warranty they can offer you a replacement and from what I hear Cuisinart has been getting in new coffee on demand units (like the one you have) that have fixed the problems. They're on back order right now though, so there will be a wait. Other than that, I would say you don't have many options, unless the store is willing to take it back, because this one is pretty much a goner. Not the first time I've seen it. :(
Posted on Aug 28, 2009
mastermaid
  • 502 Answers
SOURCE: Cuisinart Grind & Brew DCC 490
ask manualfox.com, they have it.
Posted on Jan 01, 2011
It leaks from the bottom of the coffee maker
The heating element in these is underneath the hot plate. The water gets to the heater through two short pieces of hose, and sometimes this hose leaks. Sometimes the connection between the hose and the heater leaks also.
If you are so inclined, you can take off the bottom plate and replace the hose pieces, or try to tighten the connections to the heater.
Mar 19, 2010 | Cuisinart DCC-1200 Coffee Maker
Where is thermal fuse in cuisinart dcc-1200 it needs replacement
The Cuisinart DCC-1200 doesn't appear to use a thermal fuse but instead seems to use a NTC Thermistor. Like thermal fuses this is clipped onto the bottom heating element and has two yellow fine lines leading to the control board. It should measure ~220k Ohms at room temp and drop its resistance to <20K ohms as water boils. This Thermistor looks and behaves a lot like a Vishay NTCLG100E22245B [220KOhmn] which is available through DigiKey [BC2467 part number; $0.52]
Dec 21, 2009 | Cuisinart DCC-1200 Coffee Maker
I cannot brew one pot after another. It seems that the heating element will not cool off so it will not trigger the fresh pot to brew.
Do you turn off the pot before you refill the reservoir to brew the second pot? The heating element should not have anything to do with triggering the second pot. Turn off the coffee maker, change/refill the coffee, refill the reservoir and turn the pot back on. This works on my Cuisinart.
Dec 10, 2009 | Cuisinart DCC-2000
Water is leaking out the bottom
You MUST return this product or throw it away! This is a problem seen often and the biggest risk is electricution. The hold tank for the fresh water is leaking and it is leaking water into the area housing the heating element for the caraf as well as the pump and a few other nasties.
This is a very serious problem. Do not try to fix it. A new unit is much better than either getting shocked or burning your place down.
Dec 04, 2009 | Cuisinart DCC-1200 Coffee Maker
Heating element/brewer tube leaks, Where can I get a new one?
Take the old one to any hardware store and match it up with a hose that is approved for potable water.
Aug 16, 2009 | Cuisinart DCC-1200 Coffee Maker
Need instruction manual for cuisinart dcc-2200 coffeemaker
they have your user manual free , all you have to do is save this pdf file to your computer
http://www.cuisinart.com/share/man/528_man.pdf
Feb 04, 2009 | Cuisinart DCC-1200 Coffee Maker
Cuisinart replaced the coffee maker. It was still under the 3 year warranty so Cuisinart told me to take it back to one of the stores that sells Cuisinart coffee makers because the store I bought it at was going out of business.
Nov 21, 2008 | Coffee Makers & Espresso Machines
Buy new coffee jug?
Replacemet pots for the DCC-KE12 coffee makers is Cuisinart DCC-1200PRC 12 cup replacement pot.
May 03, 2007 | Kenmore DCC-KE12 Coffee Maker
Cuisinart Dcc-1400 Coffee Maker, Brew Central 10-Cup Thermal Logo
129 people viewed this question
Top Cuisinart Coffee Makers & Espresso Machines Experts
880runner
Level 1 Expert
Michael Galve
Michael Galve
Are you a Cuisinart Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
