Question about Emerson Audio Players & Recorders
I have a 9222 electro brand turntable i need transformer what output
Dont know what size input or output
  • Emerson Master
  • 5,113 Answers
Transformers are safety parts and should only be replaced by excat parts or those by the maker. I advise you to contact the maker of the turntable.
Posted on Jan 14, 2013
How to Repair a CD Player on a Electro Brand Model 9222 Turntable AM/FM Radio with CD Player
not really repairable none of them are unless the laser itself died byut even then it isn't really repairable the only way would be to find the same type of unit and swap out the good cd player with the bad one but rather than go thru that just buy a new or nice used one no sense rebuilding this junk they really were throw away units it breaks/ you trow it out simple easist cheapest way out...buy another one used and be happy
Oct 16, 2014 | Electro Brand Nostalgic Stereo CD Music...
Pluging in a turntable
I dont understand why you would want to connect a turntable into your phone. Can you explain?
Mar 30, 2008 | Audio Players & Recorders
I have jvc compact componentsystem model hxz 77d
Well you use the wrong topic. I assume you want sound via your aux-input to come out of your little system. Then you need the turntable to be on consumerlinelevel , so you need to buy a pre-amp which comes between your turtntable PHONO-output and connect the tt(turntable) output first to the input and then use the output from the Pre-amp to go to the aux in. Don't do a thing if you hdave a higly expensive turntable.
Sep 11, 2014 | Audio Players & Recorders
Why Brookstone message chair not working?
Check and see if there is fuse. Use volt meter to check power input and if power output from transformer.
Jun 01, 2014 | Crosley CR-84 Turntable
I need to know the secondary output voltage of power transformer.
If the primary of the transformer has failed it doesn't follow that the main power supply parts are also faulty. However since the transformer is a safety part you need to replace it with the same thing.
However it seems from this website that transformers are not expensive compared to a new deck, so a look around here might solve the problem.
Mar 10, 2014 | Numark ttUSB Turntable
I have a turntable with a connect that has a double male (large size) connector but a Base which wants a single small male to fit the AUX input. Is there an adapter I can use?
I assume you mean that the turntable uses 2 RCA output jacks and the Bose shelf system has a 3.5 mm AUX input jack. Since you have the RCA audio cable, get a RCA F/F to 3.5 mm adapter. Here is a link to one: http://www.cyberguys.com/product-details/?productid=21319&rH=1601 . If you want to just have a single cable, RCA M/M to 3.5 mm M audio cables are available, http://www.cyberguys.com/product-details/?productid=2706&rH=1095 . If you have 1/4" outputs on the turntable, you need to get a different adapter or use a combination. I don't know of many vendors for the 1/4" adapters these days.
I hope this helps.
Dec 15, 2013 | Bose Audio Players & Recorders
I cannot get the audio from my electro brand turntable (L2650) to work thru my Sony DVD Home Theatre System DAV-DZ170.
would you please try to explain how did you connect it to each other ?
and which input you have used on DAV-DZ170 ?
does your DAV-DZ170 have any "PHONO" input ?
it is important to know the existing connection to offer acceptable solution..
Thanks.
Jun 22, 2011 | Audio Players & Recorders
I need the input voltage for ac adapter for my GE 98903 2.1 Pro Speaker System
The AC adapter input voltage is 120 Volts AC as it plugs into a wall outlet. I suspect you want to know the output voltage of the transformer. If you have the old transformer the output voltage is listed on the transformer top. May be hard to read but it is there. This system is also sold under then brand name Jasco. The Input voltage of the system should also be printed next to the power connection or on the speaker itself.
Nov 11, 2009 | Cars & Trucks
Onkyo TX-SR706; Turntable output only from one speaker
Try some troubleshooting to check whether its the turntable or the the receiver.
What happens if you exchange the output cables of the turntable from left to right. Does the problem shift?
Does the sound changes from left to right speaker?
Similarly try on the inputs of the Receiver.. does the problem shift...?
This way you will be able to isolate the problem, whether with the receiver or the turntable....
Let me know, we can trouble shoot it further....
Mar 08, 2009 | Onkyo TX-SR705 Receiver
Transformer main coil shorted.
You have to do the math according to the circuit path, and all components in between. Break out the voltage meter.
Sep 26, 2007 | Aiwa PX-E860 Turntable
Top Emerson Audio Players & Recorders Experts
Greg Cann
Greg Cann
Are you an Emerson Audio Player and Recorder Expert? Answer questions, earn points and help others
