Question about Bose Lifestyle 8 series II System
Bose lifestyle plays for 5min shuts down
Lifestyle 25 app 10 years old after 5-10 min sound goes off like be on mute main display normal
  • eric swanson Jan 16, 2013
    still has same issue Thanks anyways
    Genius:
  • 1,669 Answers
Do the easy troubleshooting first! Get a source of clean, dry compressed air and blow out the inside works. Next, get some contact spray and spray into the volume control potentiometer and work it down and up.
Posted on Jan 13, 2013
SOURCE: Bose lifestyle 12 music center display inop
My display has not been working for years. Replaced c17 cap wich was 33uF 63 volts on lower pcb board( only one on system) . Old cap was good so this was not the problem. Replaced c16 wich was 100uF 25 volts with a 100uF 63volts. Display works, old cap read low. Both c17, and c16 are located on the lower left hand corner of the larger pcb looking from the front of the unit. Hope this helps.
Posted on Jan 15, 2009
SOURCE: System Info from Bose not displayed on Samsung TV
Unplug the power cord and plug it rght back in, I had this same problem and was troubleshooting forever.
Posted on Feb 05, 2009
SOURCE: Running my Blu Ray DVD thru the Bose Lifestyle 18
hi there,
1-connect the blu-ray to your tv via hdmi cable and this will run picture.
2-connect the blu-ray via digital optical cable to the optical input on the bose system. then using your bose menu, (system menu)set your auxillary sound output to digital optical.
when watching dvd thru bluray player select aux on the bose and you're away.
good luck
Posted on Feb 24, 2009
SOURCE: Bose Lifestyle V20 Error 180
Below is solution from an earlier post, I'm trying it out now as I have the same issue, system bought in Jan 09. I have received and installed the latest update from Bose recently, now this. Will call Bose tomorrow to fix if they can't they will be getting it back.
We disabled the power cord from the back of the media console (where the HDMI cables connect) and left it off for a minute or two.
Powered the media console back on and it is working as expected.
Was told by the Bose tech that the common reason for this issue is due to the use of the HDMI cables that have a propritary security protocol that is used between the media console and the component it is attached to (ie TV, Cable/Sat, BluRay ...ect).
I asked if there was a BIOS upgrade if it was indeed a "handshaking" issue and was told there was not one (yet).
If one becomes available, it will be shipped via mail on a CD\DVD that can be used in a CD\DVD player that is connected to the media console using the HDMI cable.
Posted on Mar 10, 2009
  • 30 Answers
SOURCE: Bose Lifestyle System 12-no lights in display-TV sound doesn't wo
There is a service available at www.AnyoneCanFixIt.com where you can send it to fix the display. Quick service and way cheaper than Bose.
Posted on Jan 31, 2010
How do I setup and new samsung led with a 12 year old bose lifestyle 25 series II?
... According to their manuals. The TV is new so it should cover that end. Bose.com covers the other.
May 14, 2011 | Bose Lifestyle 25 System
Bose lifestyle 5 keeps shutting off sound
KEEPS SHUTTING OFF SOUND AFTER ABOUT 1 TO 2 HOURS OF PLAYING. HAS POWER, EVERYTHING LIGHTS. I THINK THE PROBLEM IS SOMEWHERE INSIDE THE ACCOUSTIMAS MODULE OR THE SUBWOOFER.
Dec 13, 2010 | Bose LifeStyle 5 Series-III CD Shelf...
Bose Lifestyle 28 Sound Problem
I also get this problem sometimes with mine. Usually when you call Bose they suggest that you do a "hard" reset meaning you unplug the power cord from the wall and wait about one min. Then plug the unit back in and it should work.
The other thing that you can try if the system still isn't working is to check that all the wires running into and out of the sub-woofer are all plugged in and aren't loose.
If either of these two solutions don't work you can alway call Bose tech support @ 1-877-210-3782 (they are open Monday Friday: 8:30 AM 8:00 PM ET)
Mar 31, 2010 | Bose Lifestyle 28 System
Bose lifestile 5 sound from the right speaker exit only
may be problem in the main unit change the IC or check the cable inside the main unit
Jul 11, 2009 | Bose Lifestyle 28 System
BOSE 38-WHITE BACK:ERROR 801-LOUD SCRITCHING NOISE AFTER SHUT OFF
Hello any cable or satelite tv show is now more comonly in high definition sound and video! and the techs are wrong because their are plenty of movies on tv including news channels that broadcast in surround sound ,but in order to get that surround sound you must either have a connection from the tv,s audio out or you can also out put the sound from the cable or satelite box out to your bose system as as the scritching sound where does it only happen when in surround mode or stereo mode ? if you play a dvd or cd does it still make noise? and can you be more specific on your terminology SCRITCHING not really shure what you mean by that word! thank you glenn mayer
Mar 06, 2009 | Bose Lifestyle 38 System - white Theater...
No sound from my bose lifestyle 18 system
CHECK THE SOUND SYSTEM ARE YOU SELECTED FROM AUDIO SETUP CONFIGARATION.
CHECK THE MUTING STATUS.
BEST REGARDS NUWAN.
Dec 23, 2008 | Bose Lifestyle 18 System
Will not play rented DVD's
This may sound silly, but have you tried a DVD lens cleaner?
Oct 18, 2008 | Bose Lifestyle 28 System
Bose - Custom EQ Error: 10
Hi, I have just had the same problem and the advice from BOSE was to turn everything off and disconnect the sub from the main unit, wait 10 mins and turn everything back on, making sure to turn the sub on first.
As it happens i then noticed I had connected the sub via the BOSE link speakers plug to the main unit rather than the correct "MAIN" socket. - so if you are reading this you know I am a fool! But the sound now works.
Basically BOSE confirmed the reason for error 10 is that the main unit is not detecting the sub and speakers.
Anyway, I hope my foolish mistake, helps save time and blushes for anyone reading this link.
J.
Sep 01, 2008 | Bose Lifestyle 28 System
Aug 16, 2007 | Bose Lifestyle 12 System
Bose Lifestyle 8 series II System Logo
202 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
