Question about Klipsch Image S4 Headphones
Klipsh s4i wiring
Wire pulled out of volume control
My radio turns all the way up when I only turn it up to 1? I can't figure it out it won't let me listen to it on normal volume
Either the radio is wired incorrectly, or the volume control circuit on the radio has failed. Either way, you will need to pull the radio from the car, check the extant wiring, and may need to replace the radio.
May 13, 2015 | Cars & Trucks
What colour wire does what with Samsung in ear earphones
This is an educated guess.
You should have 4 rings around your 3.5mm connector. From the tip to the base of the connector....
#1 - left audio - Black
#2 - right audio - Red
#3 - Ground - bare copper
4# - Mic/volume - green/brown
The wires for the left and right channels (pins 1 and 2) and the ground, (pin 3) should run from the connector through the volume control, to each ear piece. The mic/volume wire should terminate at that control. although it could connect to more than one place within the control.
You may be able to open the volume control, gently, and see which wire stops there and which continue on through.
I hope this gives you enough information to complete your project.
Dennis
Apr 22, 2014 | SAMSUNG EHS64AVFWE Stereo 3.5mm White...
How can i turn down my talk back its too loud
If it was an aftermarket install there may not have been a volume control put on it. Some times not even an on-off switch. To ad a volume control locate the jumper between the External and PA speaker. You can get a volume control at Radio Shack. Locate an area inside the rear panel that will allow the installing of the volume control. Cut the jumper wire and slide shrink tube on wires. Solder a length of wire on each end and solder the other ends to the volume control. You can use bell wire for this purpose or get wire at Radio Shack.
Feb 27, 2011 | Galaxy Radios DX-33HML 40-Channels Base CB...
My stero is not loud enough.
Check for the tape monitor being on or amp mute type function. Larry's Electronics
Apr 27, 2010 | Audio Players & Recorders
My guitar volume won't turn off
the problem i analyse is 1) the wires of the volume control (it has three wires wired to the input of the amplifier) wire 2 and 3 have got shortened.
2) the field effect transistor of the preamplifier has got shortened . the fet is in built in certain guitars.3) if its wire wound volume control then it has lost grounding , that is wire no 3 has lost its grounding (usually this is associated with a hum from the amplifier
Sep 19, 2009 | ESP Ltd EX-50 Electric Guitar
Harmon/Karden 2006 Radio/CB/CD Passanger control does not work
The passenger controls on the rear speakers are pretty easy to diagnose.  The wire for Volume up is Pink/white, the volume down is gray/white.  If the Pink/white wire is shorted to ground somewhere, then as soon as you turn on the radio, it will be like having the volume selector pushed up, and it makes sense how you describe it goes to mute and then returns to full volume as soon as you let go.   You don't say what model it is (I doubt it's a Road Glide, gotta be an Ultra), so it's not too hard to get at.  Pull the outer fairing and look on the back of the HK Radio.  There are 2 big connectors, when looking from the front you want the connector on the right.  Pin 23 is down volume, pin 34 is up volume for the rear controls ONLY.  So I would check the continuity to ground at pin 34 first, in other words pull the connector off the back of the radio, take a test lead and hook one end to +12v. Touch the tip to any grounded metal and it should light.  Now touch the tip to pin 34 on the harness side of the connector.  If the test light lights up, you have a short to ground on the pink/white wire.  Now go to the right rear speaker on the tour-pak and disconnect the 6 pin connector and try the test again.  The pink/white goes from pin 34 on the radio and runs through the harness to the passenger controls and nowhere else.  It shouldn't be grounded anywhere.  Let me know what you find out.
Jan 13, 2009 | Harley Davidson 426290 AM/FM Radio
Broken speaker
the only way is o replace the wires from end to end.. you may have to do some soldering inside the subwoofer and the satellite speakers
May 12, 2008 | Altec Lansing Multimedia Computer Speakers
Klipsh Promedia 2.1
I was face the same problem 2 year's ago.This problem occur when you move the speaker's here and there.at that time speaker's wire diconnected in inside...please check the whole wire by electricians for where exactly it is disconnected...
Sep 10, 2006 | HP ProMedia Computer Speakers
Option S4i > 512MB SD card Possible?
I have a friend who had an s4i with a 1gig sd card with no problems.
Aug 30, 2005 | Pentax Optio S4i Digital Camera
Klipsch Image S4 Headphones Logo
37 people viewed this question
Top Klipsch Audio Players & Recorders Experts
Sock Puppet
rhodesworks
Are you a Klipsch Audio Player and Recorder Expert? Answer questions, earn points and help others
