Question about Home Security
I have a white Rodgers 1f88 300 thermostat (both upstairs and downstairs). The downstairs unit now shows a blank display. Is there a reset? I checked for a battery and it does not have one. Can you help?
  • 22 Answers
Thank you for your interest with Emerson White Rodgers. My Name is Joselito Laxamana from technical department. To reset the thermostat by removing the wires from terminals R and C and removing batteries for 2 minutes. After resetting the thermostat,
replace the wires and batteries. If the thermostat has been reset and still does not function correctly contact your heating/
cooling service person or place of purchase.
Let us know if you need anything else.
Posted on Jan 17, 2013
liteswink
  • 99 Answers
SOURCE: We have the white and rodgers thermostat model
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Posted on Jun 28, 2010
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
liteswink
  • 99 Answers
SOURCE: white-rodgers 1c26-101 owners manual, does anyone
Link: Installation Instruction
Posted on Apr 07, 2010
SOURCE: The thermostat is a White-Rodgers 1F82-261.
The display on my thermostat is locked on 72 degrees. When I turn the switch from a/c to the off position, it appears that the heat comes on.
Posted on Jul 27, 2010
reddawgesq
  • 134 Answers
SOURCE: I have a White Rodgers White-Rodgers 1F85RF-275,
Download a PDF version of the Operating Manual HERE. ___ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Posted on Feb 03, 2011
I have a White Rodgers thermostat series 1F78-151 that is displaying we at the top?
Hi. This is Aaron Moratalla from White Rodgers. For 1F78-151, "WE" means Wednesday. If left side temperature is stuck at 67F and there's no Hot air coming out then try ressting your thermostat by:
1. set system to Heat mode
2. press simultaneously the Up, Down arrows and Time button for 2sec.
3. the screen should blank out momentarily then show 62F in the right side.
4. set a higher temperature in the right side than the left side of LCD to have a call for heat.
If you are still having problems please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
NO DISPLAY ON UNIT
Pull your display off wall and see if your unit has batteries. If you have a blue wire or, a wire connected to the "B" terminal in your thermostat(the part connected to wall, this should produce the power to show display. If you do not have a blue wire, it is dependant on the batteries for display. Change out batteries and see what happens. Obviously with no display, your system won't work. If this doesn't solve your problem, replace the thermostat.
Apr 26, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Two zone heat /ac upstairs thermostat appears to be on but no air is being forced through vents. downstairs zone works fine.
Sounds like a problem with your furnace or blockage in your duct work, not a problem with the thermostat. You are not missing a cat are you? The Operating Manuals for many White-Rodgers thermostats can be found in PDF form HERE, however they are not indexed by model number so you will have to download each file in turn until you find the one you want. All of the file names beginning with "0037-" seem to be W-R products.*Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Aug 20, 2010 | White Rodgers White-Rodgers 1F85RF-275...
Thermostat resets itself to 85 degrees a couple hours after I set it to 74 degrees
To manually operate the thermostat set the system to cool and fan to auto then press the HOLD button one time then release, you will see the hold word on the screen after that up the UP or DOWN arrows is setting the desired temperature.
Jul 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
The thermostat is a White-Rodgers 1F82-261. We have the very same thermostat on both the upstairs and downstairs systems. Both thermostats have all settings set exactly alike. The upstairs system has...
Steps that you need to do.
First is to reset the unit by pressing the reset button for two seconds right below the fan switch.
Second is to re- program the thermostat correctly, make sure that the unit work fine when the thermostat has been bypass.
Then monitor the thermostat operation, I think this will resolved the problem. If you need further assistance call this number 18002842925.
I have attached the link of the MANUAL
Jun 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
I have a White-Rodgers Thermostat and it has the word (Filter) on the left side and a (Flame) showing on the right hand side, I'm not sure why we changed the filter two months ago. Does anyone know what...
Flame Icon is displayed when the SYSTEM switch is in HEAT position. Display "FLTR" when the system has run for the programmed filter time period as a reminder to change or clean your filter.
You can reset the counter by going inside the configuration table of the thermostat. If you need further clarification call our WR hometechline 18002842925.
Mar 07, 2010 | White Rodgers White-Rodgers 1F85RF-275...
First off, I have e-mailed and faxed White-Rodgers over the last week with no reply. I own the 1F94-371 Thermostat. A week ago, the display went blank. Looked like a battery issue, but I see no battery. ...
Dear Steven,
First of all the thermostat that you have is hardwire powered. You need to check for the power coming in the thermostat which is the c- terminal. If that is confirmed reset the thermostat, reset button
located on the back of the thermostat body.
If you need further support call the techline 18002842925.
Jan 27, 2010 | White Rodgers White-Rodgers 1F85RF-275...
My name is Tim Burke from White-Rodgers. If you hear the "click" the thermostat is calling. It would appear that their is a wiring issue to the funace. Please contact our customer service toll free hot line and they will be happy to walk you thru it and assist you. 877-978-7828
Regards,
Tim
tim.burke@emerson.com
Tim
Oct 19, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Honeywell T8000C Thermostat Problem
If you have a volt meter, remove the thermostat off from the mounting plate and check for 24 volts AC across red (R) and White (W). Then check across Red and Yellow (Y). If you do not find any voltage, follow wire as much as you can all the way back to the air handler that is connected to it. Look inside and see if there is a small Auto (car) type of fuse in the wiring harness. Test and replace if necessary. Jump out the Red and Green terminals on the air handler and replace the door. See if the blower turns on. If so, you have narrowed it to the wiring to the thermostat. If not, you have a power problem and will need a technician.
Sep 28, 2007 | Heating & Cooling
Home Security Logo
1,118 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
