Question about Canon IP2700 Inkjet Printer
Photo paper print not clear even its new
When I print to a plain paper its color seems look real color but when i put into photo paper it make darker and the result is harder no fine color may seen I felt not satisfied
    Genius:
  • 1,669 Answers
Between the owner's manual below:
www.usa.canon.com/cusa/support/consumer/printers_multifunction/pixma_ip_ser...
and the disk that you received with the printer that you should have loaded into your computer, there are enough instructions so that you can adjust all of the color settings.
Posted on Jan 13, 2013
5 Suggested Answers
SOURCE: Canon Pixma MX700 fax and color problems
I think i just figured this out.
You need to find the Fax Menu -> Receiver Control Settings
Click the Fax button, then click menu and the left icon should be Receiver Control Settings.
Change to Tel Priority Mode.
Hope this helps
Posted on Jan 29, 2008
ginko
  • 19396 Answers
SOURCE: canon pixma ip6000d
First you need to check that the printer has the same problem with a new cartridge, otherwise may be a cartridge problem. After this try doing a nozzle cleanup. You will find the option on printer properties in control panel, or opening canon software from start menu. If after this you still have the problem then you should open the printer and clean the waste ink well and printer head.
Posted on Feb 15, 2008
rhoncruz
  • 134 Answers
SOURCE: white bands on color photo prints
Perform Print Head Alignment Instructions to perform a Print Head Alignment directly from the machine. If diagrams or ruled lines are misaligned, print head alignment is required. The print head alignment can be performed automatically or manually. If the automatic print head alignment does not work, adjust the print head manually. Automatic Print Head Alignment
  1. Press <ON/OFF> to turn on the machine.
  2. Load a few sheets of letter-sized plain paper in the auto sheet feeder.
  3. Press the Open button to open the Paper Output Tray. Then open up and set the extension by pressing down the hollow on the front side.
  4. Execute automatic print head alignment.
    1. Press <COPY> button.
    2. Press <Menu> repeatedly to select [MAINTENACE].
    3. Press the left or right cursor to select [AUTO HEAD ALIGN], then press the <OK>. (A pattern is printed and the print head is automatically aligned. It takes about five minutes to finish printing the pattern.)
Manual print head alignment
  2. Load two sheets of Letter-sized plain paper in the auto sheet feeder or cassette.
  3. Ensure that the proper paper source is selected.
  4. Execute manual print head alignment.
    1. Press <Menu> repeatedly to select [MAINTENACE].
    2. Press the left or right cursor to select [ALIGN PRINT HEAD], then press the <OK>. (The nozzle check pattern is printed.)
  5. Check the printed patterns and use the left or right arrow to input the number of the pattern in column A that has the least noticeable streaks.
  6. Press <OK> to move the cursor to column B, and then use the left or right arrow to input the number of the pattern that has the least noticeable streaks.
  7. Repeat the procedure until you finish inputting the pattern number for column P.
  8. When you have finished inputting all pattern numbers, press <OK>.
    Note: For columns A through N select the patterns with the least visible vertical streaks. For columns O and P select the patterns with the fewest visible horizontal streaks.
    <1> Example of the pattern with the fewest visible vertical streak
    <2> Example of the pattern with the most visible vertical streak
    <1> Example of the pattern with the fewest visible horizontal streak
    <2> Example of the pattern with the most visible horizontal streak
I hope it helps!!!
Posted on Dec 01, 2008
SOURCE: canon i9950 prints green on photo paper
I had the same problem. Having checked other websites I came across the following which narrowed down the problem to the Photo Cyan / Photo Magenta ink tanks, and replacing the Photo Magenta one (although it was not empty) has successfully resolved the problem. Eveidently ink from the original one was not flowing and so caused the syan cast. (I experimented by subsequently removing the Cyan one which produced prints with Magenta cast)
TEXT OF POST I FOUND:-
That post is labeled "Cannon (sic) S9000 Print Head" and concerns a greenish hue error in all print quality levels OTHER THAN plain paper. In other words, all output designated as Photo Paper Pro, Glossy, High Resolution Paper, etc., results in output with enormous and unacceptable levels of green hue. All output designated as "Plain Paper" whether the output actually is on plain paper or photo paper pro, turns out well.
This problem is not unique to the S9000, as I experienced it identically with the S820 and predictably can occur in any printer with the six cartridge print head.
It is a frustrating problem because you know that the printer is physically capable of printing WITHOUT the hue (as it proves to you each time you choose a "plain paper" paper setting.)
Troubleshooting by reinstalling and updating the printer drivers, and uninstalling/reinstalling the ZoomBrowser EX, replacing the ink cartridges, and deep cleaning are all blind alleys.
A call to Canon support solved the problem for me with this simple and important revelation:
The Plain Paper setting is unique in its use of only 4 of the 6 cartridges. In the Plain Paper setting, only the black, cyan, magenta and yellow cartridges are utilized. The Photo Magenta and Photo Cyan are not utilized. In all higher resolution settings, i.e., in all other settings, all 6 cartridges are utilized.
It follows that if one's problem disappears when not using these two Photo cartridges (i.e., when printing at the Plain Paper setting), then the problem lies with these cartridges.
(In my case, I'd loaded a plain "Cyan" cartridge in the "Photo Cyan" slot during earlier trouble shooting and had forgotten to replace it with the proper Photo Cyan cartridge.)
Problems with magenta hues would admit of the same solution.
Hope that helps anyone else out there tearing out their hair trying to troubleshoot this. "
Posted on Aug 03, 2009
Canon pixma pro9000 -2 i have done all the print head cleaning and deep cleanig and the test shows no cloggs -- when i print specifying low quality ( fast ) and plain paper, the photo looks marginal...
Hello Charles! Welcome to FixYa!
Actually as you told that you have replaced ink cartridge sometimes ago so with the new ink the effect of primary colors is more and when you print on the high quality the effect of primary color is more.
If you are printing the photos with software the try to print it on medium quality, even on low quality, The result will be fine. You can change the setting of printing in any software. After a time while when the ink will be used the result will automatically fine even on High quality.
I hope you have a clear picture in your mind.
Sir, If you find my service helpful for you then please don't forget to Rate the Service as "Five Stars" and give Words of appreciation as Feedback
Thank You for taking my service and using FixYa
Dec 17, 2011 | Canon Office Equipment & Supplies
When printing, if I select any other form of paper than "Plain Paper", e.g. "Photo Glossy Paper", the print (of a photo) comes out with a distinct Magenta overhue. The true colours are...
Hello Landscapeman ,
You need to specify the paper type when the print dialog box appears. Heavy glossy paper needs to spend more time in the fuser so that the toner is fixed.
Mar 25, 2008 | Computers & Internet
Colour prints coming out with a lilac hue
check whether the printer is in proper mode or not
Feb 29, 2008 | Epson Stylus Photo 950 InkJet Printer
Shows code U165
This section explains the way to confirm the ink status and the procedure to replace ink tanks. When ink runs out or other errors occur, an error message is displayed on the LCD to inform you of the error. See "An Error Message Is Displayed on the LCD".
When printing from your computer, error messages appear on your computer screen as well.
NOTE
Be sure to install the ink tanks in the correct order indicated by the label on the Print Head Holder.
The machine will not print if an ink tank is installed in the incorrect position.
With the LCD of this MachineMake sure that the machine is turned on, then press the COPY, FAX, SCAN, or MEMORY CARD button. The current ink level will be displayed on the LCD for a few seconds.
g0011480_tcm14-605381.png(A) Confirm whether any symbols are displayed here.
g0011482_tcm14-605375.pngColor or black ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011483_tcm14-605376.pngColor or black ink may have run out. See"An Error Message Is Displayed on the LCD".
REFERENCE
The ink status information is also displayed on the screen that appears during printing.
An error message may be displayed on the LCD during printing.
g0011494_tcm14-605377.pngMachine detected ink out condition. See "An Error Message Is Displayed on the LCD" and take appropriate action.
(B) Empty ink tank.With the Ink LampsYou can confirm the status of each ink tank by the ink lamps. Open the Scanning Unit (Printer Cover) of the machine to confirm how the ink lamps light or flash.
  • Ink lamp is on
The ink tank is correctly set and there is enough ink remaining to print.
  • Ink lamp is flashing
Flashing slowly (at around 3-second intervals)
Ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.
Flashing quickly (at around 1-second intervals)
The ink tank is inserted in the wrong position or it is empty. Ensure that the ink tank is in the correct position as directed by the label on the Print Head Holder. If the position is correct and its lamp flashes, it is empty. Replace it with a new one.
  • Ink lamp is off
The ink tank is not set properly or the function for detecting the remaining ink level is disabled.
If the ink tank is not set properly, press the g0009324_tcm14-605384.png mark on the ink tank until the tank clicks into place. If it does not click into place, make sure that the orange protective cap has been removed from the bottom of the ink tank.
If the function for detecting the remaining ink level is disabled, replace the ink tank with anew one. See "Replacing Ink Tanks".
If the lamps are still off after reinserting the ink tanks, there has been an error and the
machine cannot print. Check the error message displayed on the LCD. See "An Error
Getting the Clear Ink Status InformationClear ink is used only when printing on plain paper.
When Plain paper (Cassette) is selected for Media type and printing begins when clear ink (PGI-9Clear) is low, a message will be displayed in the LCD.
g0011497_tcm14-605385.png(A) Confirm whether a symbol is displayed here.
g0011502_tcm14-605378.pngThe clear ink is low. You can continue printing for a while, but we recommend you to have a new ink tank available.g0011503_tcm14-605379.pngThe clear ink tank is empty. See ""The clear ink tank is empty. Replacing the ink tank is recommended." U045" and take appropriate action.
NOTE
  • The ink status information is also displayed on the screen that appears during printing.
  • Clear ink is used only when printing on plain paper. Therefore, it is possible to print on photo paper, or any type of paper other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
The following error message will be displayed on the LCD when the clear ink has run out during printing on plain paper.
g0011506_tcm14-605380.pngRefer to "Replacing Ink Tanks"If you continue printing under the clear ink out condition, see ""The clear Ink has run out. Replace the ink tank." U165/U166" and take appropriate action.When the clear ink hasrun out, printing on plain paper from the Cassette is not possible. The fax, which is received under the clear ink out condition, will be stored in memory.
NOTE
It is possible to print on photo paper, or any media type other than plain paper, loaded in the Rear Tray, even if clear ink has run out.
Oct 01, 2011 | Canon PIXMA MX340 Wireless Office...
Colors and photos do not look right when printing on glossy paper using the HP Z6100PS large format printer. With photos on glossy paper, the ink seems to reflect off the paper, making the photos have a...
Hi
Did you try to calibrate on the same media what you want to print?
Try to delete any other calibrations stored. And re-calibrate the plotter on the same media or a plain paper.
DO RATE MY SOLUTION
Jul 07, 2011 | HP Designjet Z6100 InkJet Printer
Why does the entire photo printout with a pinkage color overlay when indicating using glossy photo paper, even different photo paper. This occurs with several different programs not just Photoshop. I've...
That happens if you put photo cyan where the plain cyan ink should be, also photo magenta is too weak to be used in the magenta slot. I've also seen generic inks that weren't the right colors.
Jul 09, 2009 | Canon i9900 InkJet Photo Printer
Just want to print black !
hallow ,,,if your lookin to just print black and white so .while printing ,go the printing properties or prefrencies ,,in the colour option click just use black and white
Jan 10, 2009 | Office Equipment & Supplies
Cannot clean Canon i960
The print driver might not be sending the correct color profile for photo paper. Check that your selection of the paper type "sticks", that is, that it doesn't revert to plain paper when you click on the print button.
If the print dialog is not working properly, then please get in touch with Canon's tech support to resolve this.
Jul 26, 2008 | Canon I960 InkJet Photo Printer
Printer will not print black ink
Chewbacca08's solution gave me an idea. I set the print setting to photos paper (even though I was trying to print on plain paper) and IT WORKED. It's worth a shot before you trash a perfectly good printer.
Jun 25, 2007 | Canon i850 InkJet Photo Printer
Canon IP2700 Inkjet Printer Logo
22 people viewed this question
old marine
old marine
