Question about Computer, Chip, Cruise Control for Ford Escort
Code p1113 on a 98 escort
Jerking and sputtering and losing power
  • Ford Master
  • 14,384 Answers
Here is a link to your code.
Posted on Jan 18, 2013
I have 2006 chevy equinov 3.4l awd.When i push on the gas it will run fine for about half a mile then it starts sputtering and sounds like backfireing and jerking and stalls out.
What is year--make--model?
How long since a tune-up?
If you think it is fuel issue, use a gage and check proper fuel pressure. There are some other tests you could try, but, too much liability, I can't be responsible for your safety.
Mar 14, 2016 | Cars & Trucks
My car jerks and seem to lose power especially when driving uphill. car sputters like its going to die. What is causing this?
Check your plugs and wires first and get back to me. Give me more information such as miles and latest maintenance performed on it.
May 22, 2015 | 2001 Mitsubishi Galant
92 maxima jerking an sputtering does not stall what could this be
It could be one or a combination of a few things. 1.) There could be moisture in the gas. 2.) A bad fuel filter. 3.) If you seem to lose power as you're driving, it could be your converter. I would check the fuel filter first.
Nov 07, 2011 | 1992 Nissan Maxima
2000 nissan xterra~ feels like i got watery gas (checked, no) or running out of gas (not). sputters and jerks and loses power badly until can push gas pedal to floor and won't go above 5 mph. first time it...
Mass air flow sensor might be dirty or failing.
Clean sensor when cold with mass air sensor cleaner only.
that controls the throttle opening and closing.
Jun 22, 2017 | 2000 Nissan Xterra
Engine sputters when accelerating to speed limit and fails to hold it . also loses power climbing hills
Check your EGR valve, IAC valve, fuel pressure regulator, fuel pump, fuel filter, spark plugs and spark plug wires
Jan 02, 2010 | 1993 Ford Escort 4 Door
2002 caravan ec, on acceleration, once warmed up, van sputters and loses power. Let up and accelerate slowly and you regain power. Also occaisionally jerks forward at stop light, and will sometines 'grind'...
Sounds like an ignition miss, Probably has an ignition cable arcing, I'd try and scan the computer for codes, you are looking for a PO300,301,302,303,304,305,or306. If you have any of these I'd start with plugs and wires. The grinding in reverse could be the low reverse planetaries, drop the trans pan and inspect for debris/metal on the magnet, if it looks like a chia pet, replace the trans with a reman unit.
Aug 24, 2009 | 2000 Dodge Caravan
When my car is running I experience a jerking several times.
engine not healthy likely a dead miss ..check codes and test for spark fuel and air
Jan 13, 2009 | 1999 Ford Escort
1997 Ford Escort losses power when car heats up. Starts fine and runs okay at first. Car will sputter,engine will bog down and eventually lose power after about 10 minutes on the road
Do you have a blown head gasket? Just a guess. If you do this is one of the symptoms. You may have some coolant in your oil. Check your inside the valve cover for water by looking in through the oil cap.
Jul 17, 2008 | 1994 Ford Escort
Computer, Chip, Cruise Control for Ford Escort Logo
53 people viewed this question
Top Ford Vehicle Parts & Accessories Experts
xxxxxx xxx
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Ford Vehicle Part and Accessory Expert? Answer questions, earn points and help others
