Hotpoint ultima wmd960 switches on but no water enters the drum after a while it comes up with f.01
    Genius:
  • Washing Mach... Master
  • 1,669 Answers
The main panel logic board is not going through its cycles.
Posted on Jan 13, 2013
  • 3 Answers
SOURCE: hi,how can i reset the
1. Switch on the power and when the language is displayed - press the child lock+ temperature+ spin buttons simultaneously for about 5 seconds. Release the child lock button when other languages appear. Scroll down using temperature button-until English is dispalyed. Select using child lock button.
Posted on Mar 01, 2011
murdozzz2
  • 75 Answers
SOURCE: Hotpoint Ultima W860
hi there f10 fault code means pressure switch not sensing,
this could be to do with low water pressure or a bad connection on the pressure switch or control module which is located at the back left hand corner of the machine, remove backplate to gain access and remake all connections on module, if this should not resolve the fault i would be looking to replace the pressure first part no= C00112659 cost about £15
ps. always disconnect from mains before carrying out any work
Posted on Dec 08, 2007
  • 6277 Answers
SOURCE: Hotpoint WMD960 on start says ' no water supply '.
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses.
If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call and a check that it isn't the control PCB ;-0(
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Posted on Aug 14, 2011
SOURCE: error message f-01 on hotpoint ultima wt741 washing machine
F01 is a motor faulty normally caused by the module,but sometimes thewiring to the motor plug that works loose as its to tight,give them alla good wiggle make sure there all in!
check this link for other error codes of hotpoint machines
http://www.hotpointservice.co.uk/hs/pages/content.do?keys=FAQ:ERROR_CODES
Posted on Dec 15, 2008
SOURCE: my machine is flashing F-01
so is mine 3rd August 20:20. I hope it is ok because sods law my warranty has just expired!!!! What does F-01 mean?
Posted on Aug 03, 2009
What causes a hotpoint ultima wmd960 noisy spin ?
Tub seal leaking letting water get to tub bearings need shaft and bearings replaced.
Aug 31, 2014 | Washing Machines
Our hotpoint ultima wmd960 washing machine timer stops with one minute remaining, but continues the wash cycle on 'a loop', and does not pump the water from the drum. We turn it off and then put it...
Have a look at this and check if your pump is full of things lost from pockets:
How to remove and clean your Hotpoint washing machine pump filter
However, I suspect the problem is really that something is causing the controller to (falsely) register an unbalanced load, and continually running the wash to try and redistribute the items.
Sorry I'm not sure what the fix is for that - could be motor tacho, or could be controller itself.
Jan 30, 2018 | Hotpoint Washing Machines
Hotpoint ultima wt741p is showing F:01 on the display screen when the machine starts up -the machine starts but no water comes through and the drum stays idle - any advice please ????
F:01 is display say some error problem occur in your machine, maybe the motor that pump water to fill the machine has not working or its sensor that water is flowing is not working also.
Jan 29, 2011 | Hotpoint Washing Machines
Hi,how can i reset the language on my wmd960 hotpoint ultima,thanks
Jan 14, 2011 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint WMD960 is less than a year old and keeps switching itself off during a wash.
If your washer is less than a year old,and you have proof of purchase, then I would advise you to contact Hotpoint direct as the washer will still be under guarantee, and anything you do to it could invalidate the guarantee.
You can contact them at the address as shown below.
WWW.HOTPOINTSERVICE.CO.UK
Fololow the appropiate link.
Jan 03, 2011 | Hotpoint Ultima WF860 Front Load Washer
Brown sludgy marks and particles on clothes.
fill the tub with only water! use pinesol and bleach! half a gallon of each run through wash cycle 3 times before ever letting it spin out! then complete all cycles that should do it! if not them you need to remove and clean under tub and re install
Jan 13, 2010 | Hotpoint Washing Machines
Access to the sump of WMD960 Hotpoint washing machine
There is a lower removable cover at rear of washer,remove this, locate and remove large black hose fastened to drum, locate and remove filter inside hose to clean.
Please rate my solution.
Thanks.
Aug 29, 2009 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
556 people viewed this question
Top Washing Machines Experts
