Question about Kenmore 46462 Front Load Washer
Error codes Hi! I can't seem to find my paperwork for this machine since moving and I need to know what the following error codes mean. Sometimes it stops mid cycle and flashes what looks like SUD or maybe 5UD. The other one happens more often and is a F02 error. Anyone know what these mean and how to fix? Thanks.
  • dana burgess Jul 09, 2007
    Thanks! I am using HE detergent but I'll cut down the ammount. (I use the recommended ammount but I'm always up for saving money if I can get away with less!) Also appreciate the info on the F02 problem. Now I know where to start!
  • maparra Mar 09, 2008
    My washer HE3 Quiet Pack 2, also stops mid cycle when it;s getting ready to drain and spin, Starts flashing Sud or F02. Usually have to stop it and restart it, sometimes takes a couples hours or doing this before it finally completes it's cycle only to start all over again with the next load.
    I was told the Sud means too much detergent, I am using alot less, but what about the F02?
I own a HE3 kenmore elite for 4 years now and the troubleshooting codes are: SUD When excessive suds are detected, a suds routine automatically starts. This causes the cycle to go longer to remove the excess suds. Reduce detergent amounts or use HE detergent. The F02 error I had with mine and it is a drain problem. Book says check the hose for kinks, clogged or is it more than 96 inches above the floor. On mine it was the fan pump on the forward motor that drains the washer. It was worn and not pushing out the water fast enough. You will hear a high pitched whine at the front bottom of the washer if this is bad. To reset the washer from the F02 error, select pause/cancel twice to cancel the cycle. Unplug washer or dissconnect power. good luck
Posted on Jul 08, 2007
Elextrolux EWF168540 W TimeManager 8kg stopping mid program without any error message
The recurrent problem may be due to a defect in the Time Manager.
Feb 01, 2017 | Washing Machines
What does Code F on washer mean?
Hi. Some of the Error Codes for Cabrio Starts F. So Look at the number coming after F. e.g. F81 -> lid opened.
Here is the a list of Error Codes on some site for troubleshooting.
Troubleshooting Cabrio Bravos Oasis Washer Problems
Aug 01, 2014 | Washing Machines
Hi - my washer machine stops mid cycle then beeps and shows a dL code. what does this mean? How can I fix this?
Listed below is the meaning off the error code, and corrective actions needed.
FdL Door lock error A Door Lock Error occurs if the door cannot be locked. It will try to lock it 6 times before displaying the error.
Potential Causes
• Door Lock Mechanism broken or removed from the Door
• Check Door Lock/Switch Assembly
• Check the wire harness connections to the Door Lock/Switch Assembly and Central Control Unit (CCU)
• Door Lock/Switch Assembly Failure
Replace failed component.
If you have any further questions please feel free to ask.
Nov 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code 5d?
Hi
This is actually a SD code meaning to many suds. The machine will drain out mid-cycle when you push stop. You can then start the load over without adding any additional soap. Make sure you use the recommended amount of HE soap.
thanks for contacting fixya.com
Nov 13, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Need to know what 50 means --washer keeps beeping after tub fills
Please see the following Whirlpool Service Manual for their Cabrio Washer (Basically the same as the Kenmore Oasis)
50 points to an obstruction keeping the basket drum from turning freely.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Nov 08, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine keeps stopping mid cycle
If you found coins and such in the drain filter then there is a possiblility that the impeller in the drain pump motor was damaged and you are not getting good water flow thru it. The machine will error out and stop mid cycle if it detects it has not drained in a set amount of time. OE indicated a drain error. I suspect you need to have the drain pump motor assembly replaced.
Nov 20, 2008 | LG WD-1280FHD Front Load Washer
Electrolux W375E
if you go to electrolux laundry systems you will be able to download the operating manual for the W375N. all error codes are on this PDF doc..
Nov 26, 2007 | Washing Machines
Hotpoint Aquarius+ FDW70 Error Codes
i have the same on my dishwasher and have just been looking on the net. Found out that the error code A10 means open/short circuit fill value traic. Whatever that means!!! and to book a service engineer. Hope that helps
May 04, 2007 | Hotpoint 24 in. FDW60 Free-standing...
Kenmore 46462 Front Load Washer Logo
823 people viewed this question
Sal De
fordexpert
Whirlpool
Whirlpool
