Question about Sewing Machines
Looking for bobbin compartment cover for beldray 12 stitch sewing machine
manski
  • 15 Answers
SOURCE: kenmore 12 stitch sewing machine-wont sew
repair and parts it's all here just open this link....
all the advantages is here , hustle free, saves time and money ...
www.myrepairmaster.com.
Posted on Dec 10, 2007
SOURCE: singer simple sewing machine will not sew
need needle threading instructions singer 3116 simple. pictures would help. thank you
Posted on Mar 15, 2009
louislevel_2
  • 374 Answers
SOURCE: need sewing machince help????
hi;
breaking thread and thread below not hook up by upper thrread, this is due on not properly set up of thread tension,first check bobbins windin35caecd.jpgg see figure.the threads should
be counter clockwise.
the theading on upper set up should prorerly inserted follow figures.7dabcae.jpg
the dial set up tension should start at #3 to # 5
the stitch tension should be set to # 8 to # 12
use trial run for fabrics,diffferent set up in every fabric tru to study before sewing in other fabrics.have a nice day don't forget to rate me.thank s a lot
Posted on May 17, 2009
WonderTech
  • 268 Answers
SOURCE: my sewing machine keeps getting jammed when
Here are a couple of things to try.
* Un-thread your machine and remove your bobbin. Clean any loose thread or lint out of your
bobbin case. Re-thread your machine, reinsert and re-thread your bobbin.
* Change your bobbin
There could be a nick along the edge of your bobbin spool that’s catching your thread as you
sew.
* When you start to sew a seam, grasp the upper and bobbin thread tails. Hold them back
and out of the way as you sew your first couple of stitches. This will keep them from getting
caught in your machine.
I hope this helps.
Posted on Sep 15, 2009
sburtenshaw1
  • 5 Answers
SOURCE: Shirring fabric?
When putting your shirring elastic on the bobbin, don't thread the elastic through the bobbin holder,adjust the stitch length longer,and loosen the tension, other wise if you want to put it through the bobbin holder you have to loosen the tension screw on the bobbin holder, and then you have to adjust it back for ordinary sewing,
Posted on Feb 13, 2010
Empisal creations and episal EXP889 sewing machines.... which is the better one and more recent model
It really depends on what You envision yourself doing with the sewing machine and then finding the machine that has the most functions that fit your needs.
Empisal 889:
  • 36 Stitch functions
  • Front load bobbin
  • On/off switch
  • Left and middle needle position
  • 18 Stitches
  • 4 Step buttonhole
  • Stitch width control
  • 4.5mm Maximum stitch width
  • Soft cover
  • 4.5mm Maximum stitch length
  • Reverse stitch
  • Twin needle
  • Free arm
  • Carrying handle
  • Uncoupling bobbin winder
  • Clip on, clip off foot
  • Drop feed
  • Sews on buttons
  • Zipper foot
Empisal Expression 889 Sewing Machine Empisal Sewing Machines
Empisal Creations
  • 4 Step buttonhole
  • 19 Built-in stitch patterns
  • Oscillating hook
  • Sews on zips
  • Adjustable stitch length: 0 - 4mm
  • Adjustable zigzag stitch width: 0 - 5mm
  • On / Off swithch
  • Free Arn
  • Accessories
  • Reverse stitching
  • Horizontal spool holder
  • Self uncoupling bobbin winder
  • Cover on accessory compartment
  • Large working surface
  • Thread cutter
  • Adjustable presserfoot pressure
  • Built-in tension
  • Darning plate
  • Fold away carry handle
  • One touch snap on foot
  • Versatile utility stitches
  • Sews through heavy fabrics
  • LED lighting
Empisal Creations Sewing Machine Empisal Sewing Machines
https://www.russells.co.za/empisal-creations-sewing-machine
Dec 11, 2017 | Sewing Machines
Beldray 12 stitch sewing machine manual
call or email these sites
sewvacdoctor.com
a1sewingmachines.com
Mar 04, 2014 | Sewing Machines
12 wt thread
12 wt thread generally will not work well in the bobbin...
"Aurifil 12wt Thread
Aurifil 12 wt thread is ideal for hand quilting, big stitch hand quilting and machine quilting. 12 weight thread creates a more defined and often primitive look. It's great for designs that use a longer stitch length if using a machine. When machine quilting with 12 wt thread, use 40 wt in the bobbin, increase your stitch length, lower your tension, use Topstitch size 90 needles and stitch slowly."
May 08, 2017 | Bernina Activa 140
Can not find where to buy a new Beldray bobbin case
try these websites and email them or call them and ask them
about the part you need
Nov 26, 2012 | Sewing Machines
Beldray sewing machine won't make a stitch
try changing the needle--make sure the needle is the right one for
the fabric being sewed, and also inserted the right way in the needle
holder and all the way up into the needle holder
try rethreading the machine top and bobbin--make sure every
thread guide is used
make sure the bobbin is turned the right way in the bobbin case
if none of these suggestion help then the machine needs to be
checked to see if there is a problem with the timing.
Nov 01, 2012 | Sewing Machines
Hey did you managed with the lower bobbin at a beldray sewing machine...??i dont know how to pplace it becuz the needle wont take the lower thread...
Unfortunately, although the top solution is good for all other machines, you cannot get into the base of a Beldray, it is sealed shut. I really need the same help, It is not spooling around the bobbin, and you cannot remove the casing or the bobbin holder .
Jun 08, 2012 | Sewing Machines
I need a manual for Beldray 12 sewing machine cant see model number on it just 12
email these sites about a manual
sewvacdoctor.com
sewusa.com
May 26, 2012 | Sewing Machines
Need Manual for Beldray 0092 12 stitch sewing machine
try these sites you'll probably have to email about a manual
sewvacdoctor.com
Apr 22, 2012 | Sewing Machines
No manual for a beldray 12 stitch sewing machine
hello how does the beldray sewing machine works? please email on alysha678@gmail.com if you know please
Feb 10, 2012 | Sewing Machines
I lost Beldray 12 Stitch Sewing Machine, Model ES0068. he machine is not threading atT all but its running
Martyn Lloyd I have tried the tension knob from one end to the other nad it hasnt made one bit of difference. It would agree with whom ever said it wasnt a very user friendly sewing machine and I have been sewing a few a few years.
So I wouldnt recommend it to anyone.
Aug 03, 2011 | Sewing Machines
Sewing Machines Logo
55 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
