I was browsing with my digisol dg-bg4011n,when i disabled the connection and enabled it again its not working..i mean the internet LED light is not turning green...Please help,I'm in big trouble..
I was trying to boost the bitcomet speed, in some instruction, i disabled the high speed or LAN connection and enabled it again..from that time its not working...Please help.....
    New Friend:
  • 15 Answers
Try a fact resest should be a pin set hole in the back take a pin/paperclip tooth pick Press & Hold for 10 sec that should reset rotuer to factory defaults. That may help if not unplug router from power & unplug wan ethernet or unscrew wan coax for 30 sec if that still dont work call your internet service provider they can do remote reboots that may help
Posted on Jan 14, 2013
  • virajith4cha
    virajith4cha Jan 14, 2013
    what is this wan coax?..i'm new to this!!!
5 Suggested Answers
govinda123
  • 2263 Answers
SOURCE: why does my belkin g wireless modem router f5d7634
You said that the Internet connection is dropping. It is a modem *** router.
If there is any MTU settings , then reduce the MTU.
For example If MTU is 1500 then reduce it to 1400.
Otherwise you will need to upgrade the Firmware of the router.
Click Here for more info about the networking
Posted on Oct 07, 2009
govinda123
  • 2263 Answers
SOURCE: belkin g wireless modem router f5d7634 always disconnect
try to reduce the MTU settings on your router.
If possible upgrade the firmware of the router.
Click here for more info about the networking
SOURCE: Ethernet LAN light goes off after few seconds
when the booting all light are turn on that's normal , after few second ethernet light momently on because ethernet chip internaly loop and check the ethernet chip that why you seen the ethernet light momently on after that ethernet should lit on if you connect router ethernet link to pc or ethernet switch.
pls check the ethernet cable , if you connect to ethernet switch pls try with cross over cable and if you connected to pc pls check duplex to auto or forced to 100 Mbps
Posted on Sep 07, 2010
archaeology
  • 662 Answers
SOURCE: how to connect my Linksys
The Linksys Wireless router is fine, but your latop is not configured for DHCP (Dynamic Host Configuration Protocol). The computer is connected to the router at layer 2, whereas HTTP (Hypertext Transfer Protocol), sits
atop the TCP/IP (Transmission Control Protocol/Internet Protocol) layer, and seems to be trying to
query the ISP's (Internet Service Provider) network for a nameserver (via DNS (Dynamic Name Service) protocol) that doesn't exist on the ISP's network. Configuring the laptop for DHCP and specifying no nameserver will fix this (the ISP's network will dynamically assign a DNS).
Its also possible (though a remote possibility) that your Linksys wifi router may be configured to disallow TCP/IP virtual circuits to/from your computer's IP address - but this is a really advanced
capability of your Linksys wifi router - few know this capability even exists.
Connecting multiple wifi devices to the Linksys router should be no problem, just configure them all to interact with the router using DHCP.
Posted on Jul 04, 2011
Digisol dg bg4011n router is not working in ubuntu10.04 Isearched for the driver not get sofar
You need a device-driver for the Ethernet adapter inside your computer. Then, use an Ethernet cable to connect from your Ethernet port to one of the 'LAN' ports on the router.
Aug 30, 2014 | Computers & Internet
Cannot connect to internet>>>
Power off your modem and router
Wait for about 1 minute
Power on just the modem and let it cycle through it's tests (about 1 minute)
Power on the router and let it cycle through it's tests.
Sometimes you need to repeat this a couple times.
Jan 13, 2013 | Computers & Internet
From where can I downlaod driver for my Digisol DG-Bg 4011N, wireless ADSL Broadband Router
already have a driver attach in modem.is no updated driver because hardware dependent. so sent service center updated your modem hardware then update driver from service center it only for u worked ( it's not joke). or" buy updated modem.
Mar 06, 2012 | D-Link ADSL2/2+ Modem/Wireless Router...
My d-link router name no longer appears in my wireless networks list - I can not find it to connect to the internet wirelessly
Hi, this seems to be either an issue with your router's hardware or local computer wireless adapter hardware. In order to determine which one is it do the following:
1. Go and check the LEDs on your wireless router to see if there are any blinking or switched off as stated in the official manual documentation for DLink products (can be found here or here more specific).
LEDS are as follows (left to right - per official user manual/doc):
- Power LED = A solid light indicates a proper connection to the power supply. cdekatrr_0.png
- Internet LED = A solid light indicates a proper connection to the Internet port. This LED blinks during data transmission. cdekatrr_1.png
- WLAN LED = A solid light indicates that the wireless segment is ready. The LED blinks during wireless data transmission. cdekatrr_2.png
- Local Network LEDs = A solid light indicates a connection to an Ethernet-enabled computer on ports 1-4. This LED blinks during data transmission. cdekatrr_3.png
2. Check the laptop's or desktop wireless adapter if it is disabled or enabled and if is disabled enable it by going to your computer's Control Panel (either winxp or vista/win7) and go to network connections (in vista/win7 put the control panel in detailed view to see more options) and then right click on your wireless connection and click enable.
3. In a case that also the wireless adapter is enabled but you still cannot see any access points/wireless networks please go to your current wireless connection and right click go "Diagnose", this feature is mainly available in windows 7 or Vista. For windows XP, go to the command prompt by going to Start->Run->type in the box "cmd" without the quotes->Then type in the following set of commands.
ipconfig /release ---> This will refresh your wireless card IP settings/configuration to 0.
and after that command finishes, type in:
ipconfig /renew --> This will get new settings if the wireless card has problems finding an address from your router.
You can always reset your router (unplug from power supply, wait 2minutes then plug it back in)
or:
Reset the wireless adapter (right click from on the wireless adapter shown in the network connections, disable and then re-enable it) or computer.
Thanks please let me know if you need anything else.
Mar 20, 2011 | D-Link Wireless N 150 Home Router 4Port...
I cant connect my dell latitude d600 to the internet via ethernet it says its connected but browser wont work??
Try to disable your internet connection. Right click My Network Places in your desktop and chose Properties. Right click the network connection and disable. And make it enable again. Now try to browse website,now it work.
Mar 30, 2010 | Dell Latitude D600 Notebook
What does wiring fault light mean?
The Site Wiring Fault LED will indicate three status:
• Led On: The site wiring fault function is enabled and a site wiring fault is present.
• Led Off: The site wiring fault function is disabled.
• Led Flash: The Site wiring fault function is enabled and there is no site wiring fault.
When the input power is normal the Site wiring fault LED will flash.
• To disable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
• To enable this function, press the Site wiring fault LED button for 10 sec when the UPS is plugged in to wall power and the UPS is off.
Is the wiring fault light indicator lit? This means that the outlet that the unit is connected to is either not properly grounded, or has reversed wiring. First, try connecting the unit to another outlet. If the unit does not display the wiring fault light in the new outlet you will need to have an electrician correct the problem with the other faulty outlet.If it still displays the wiring fault more troubleshooting will be necessary to determine the cause
Feb 09, 2010 | CyberPower 725SL UPS System
My chat is disable in gmail i want to enable it.the error is chat is disable because ur interconnection is not proper or your adminstaror disable ur chat. but my internet connetion is proper and again i am...
First of all check the internet connection bandwidth. If it is too low it is the cause. Delete the Temporary Internet Files,cookies and browsing history, now you can see enable chat in your G mail account.
Nov 12, 2009 | Computers & Internet
Brand new linksys wireless, Host (Hard wired)has intermittent connectivity. Indicates it is conneted and is working properly.Cannot browse Web. The wireless part works great!
try to plug the Ethernet cord for the Host computer on another Ethernet port on the Linksys router.
have you tried replacing the Ethernet cable that's connecting the Host computer to the linksys router?
check if Host computer can get a response from a website by going to Start>Run, then type CMD on the Run box and click OK. On the black screen, type PING www.yahoo.com then press Enter.. if you get the word reply 4 times, it means the computer is connected to the Internet.
If there's no response from the PING test, it means there's totally no connection.
It's also possible the problem is with the Local Area Network adapter or Ethernet adapter. Try disabling the Ethernet adapter and re-enable it by going to Start>Control Panel>Network Connections, you should see the Local Area Connection, right click on it then select Disable then Enable it again. then observe if you're still experiencing intermittent connection on the Host computer.
and if you have security software, try disabling it temporarily and check the connection again.
and let's make sure the cable or dsl modem is connected to the Internet port on the back of the Linksys router.
May 10, 2009 | Linksys WRT160N Wireless Router
Computers & Internet Logo
120 people viewed this question
David Payne
David Payne
