Question about Akai S5000 - Midi Sampler
Data wheel faulty - Akai S5000 - Midi Sampler
  • planetstudio
    planetstudio Jan 13, 2013
    im looking to buy this item its listed as having faulty data wheel does anyone know wether these are prone to developing dry joints through heavy use or the wheel actually failing if so does anyone know hoow much approx a new wheel costt and if its acessable and and easy insttall or is this an item i should just avoid with this fault
  • daounandout
    daounandout Jan 09, 2014
    I have to do the exact same thing. Not sure how common this problem is though... anyone know where to buy these from?
My 1998 pontiac sunfire speedometer works intermitantly i just got a speeding ticket because it wasnt registering any speed what is wrong and how do i fix it
automatic , probably a faulty vehicle speed sensor or manual a faulty sensor in the transmission
check wiring and connections for corrosion , oil , broken wires
Jul 09, 2017 | Pontiac Cars & Trucks
Tip
Data Recovery (possible) from faulty hard drives
DAMAGED HARD DRIVE - DATA RECOVERY
Data recovery from faulty hard drives is difficult and can be costly. There is no guarentee that you can recover data from a faulty hard drive.
If the hard drive makes a clicking noise the the hard drive is dead.
First thing to try, is to remove the damaged hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an USB mass storage device (external hard drive) and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services. The reason for this high cost, they dismantle and remove the platters in the hard drive in a clean room environment and set up the platters up in jig/drive to retrieve/copy the data.
on Jun 11, 2010 | Computers & Internet
What is a abs modular on a Escalade Cadillac?
Jesse, The module will not stop fluid to rear brakes, a bad master cylinder will,leaking lines, air in brake system, faulty metering block if equipped, collapsed flex lines or pinched brake line faulty caliper or brake cylinders,etc. will cause the possible feeling of no rear brakes.
(ABS Module components) the ABS speed sensors and the ABS control module . When the brake is applied, the ABS control module reads the speed data from the speed sensor and sends the correct pressure to each wheel to prevent any wheel lock up, eg. sliding/skidding Links below have more info.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Service Stability System AND abs Pump issue
ABS Control Module Replacement Service Cost YourMechanic
https://www.rockauto.com/en/catalog/cadillac,2002,escalade,5.3l+v8,1431695,brake/wheel+hub,abs+control+module,1844
Feb 24, 2016 | Cars & Trucks
I have an ESP problem in my Mercedes Benz C220 CDI, 2008 and the problem is an ESP CURRENTLY unavailable. Cruise controls and speedtronic inoperative
It is usually a ABS wheel speed sensor has gone faulty, but you would have to have electronic diagnostic done to read off a fault code (DTC) and maybe a live data scan . Hope this helps
Nov 21, 2014 | 2008 Mercedes-Benz Mercedes Benz C Class
Wheel speed sensors
lift the car off the ground remove tires, unclip the electrical wires, hook up an ohm meter to the wires leading to the wheel, spin the rotor, if the sensor is good you will see a pulse, your numbers will rise and fall as you turn the wheel if it does not do this it is faulty. here is a video for better clarification. sorry the camera isn't that great. https://www.youtube.com/watch?v=Apq6rgfKvIY hope this helps
Dec 11, 2013 | Dodge Magnum Cars & Trucks
2001 Acura mdx abs light stays on. Code reads 04?
I think you pulled the code incorrectly, or are reading it wrong. To get code:
1. Jump pins 4 & 9 on OD2 connector.
2. Turn key 2 clicks.
3. ABS light should blink to give you code. (long blinks for first digit, short ones for second. Example: One long blink and three short blinks would be 13).
Honda ABS trouble codes list :
11= Right front wheel sensor (open/short to body ground/short to power)
12= Faulty right front wheel sensor pulse signal
13= Left front wheel sensor (open/short to body ground/short to power)
14= Faulty left front wheel sensor pulse signal
15= Right rear wheel sensor (open/short to body ground/short to power)
16= Faulty right rear wheel sensor pulse signal
17= Left rear wheel sensor (open/short to body ground/short to power)
18= Faulty left rear wheel sensor pulse signal
21= Continous Operation (chipped pulser)
31-38 are all the same: "solenoid"
51= Motor lock
52= Motor stuck off
53= Motor stuck on
54= Main realy stuck off
61= Ignition voltage
81= CPU (central processing unit)
Jul 03, 2013 | Cars & Trucks
I dropped my fantom 500GB external hard drive (#TBD500C16). Now it no longer is visible on MyComputer... It makes some humming noises for a minute or so,,, then becomes silent. Is there anyway to...
The hard drive is faulty and we mortals cannot retrieve data from a faulty hard drive.
There are companies that can retrieve data from a faulty hard drive BUT it will cost you an arm and a leg for their services.
If future with these external hard drives, it pays to have a second one so you can back up your data on the second hard drive in case the first hard drive becomes faulty.
Dec 19, 2011 | Fantom Computers & Internet
How to recover data from my damage hard desk
Recovering data from a faulty or damaged hard disk is impossible for users, it requires specialized tools and knowledge.
There are companies that specialized in recovering data from faulty and damaged hard drives BUT it will cost you an arm and a leg for their services.
If you still wish to retrieve your data then Google search for data retrieval companies.
Jan 16, 2011 | Computers & Internet
Just before the car comes to a complete stop, the anti-locks kick in, even on a dry surface. i replaced front pads and rotors, but problem continues. rear drums and shoes look great. this is on a 1996...
more then likely, the problem is a bad wheel bearing. the magnetic encoder is integral to the bearing in this unit. common problem. too confirm, and to identify the faulty bearing, you need to go for a drive with a scan tool connected watching the live data. when the ABS event occurs, watch the wheel speed sensor outputs to see which one is reading slower then it should. good luck!
Jun 04, 2010 | 1996 Pontiac Bonneville SE CA Value
When i start my 2008 endeavour,the brake light wont go off. Then when i start to drive, the traction icon comes on. Any solutions?
There are a few items to check.
1) Brake fluid level
2) Brake pads
3) Wheel sensors and wiring (these send data to ABS and traction control)
If all the braking system seems to be fine then I would guess a wheel sensor is faulty which would make the warning lights come on.
Mar 30, 2010 | 2008 Mitsubishi Endeavor
Akai S5000 - Midi Sampler Logo
144 people viewed this question
Top Akai Computers & Internet Experts
Michael Vincent Cruz
aravind shet
aravind shet
Are you an Akai Computer and Internet Expert? Answer questions, earn points and help others
