Question about Sport & Outdoor - Others
How to change a wheel on a roller-skate? - Sport & Outdoor - Others
    Problem Solver:
  • 16 Answers
To change a wheel on your roller skate please do the following:
Unscrew and remove the axle bolts from the front wheel with an Allen wrench. Pull the front wheel out of the wheel frame. Remove the bearings and spacer from the wheel. All components should slip out together. Place the spacer and bearings into the new wheel. Place the new wheel on the wheel frame. Replace the axle and tighten it using the Allen wrench. If your spacer is aluminum, tighten the axle as far as it will go. If your spacer is plastic, tighten the axle almost as far as it will go, then loosen it slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If the wheel wobbles, tighten the axle. Repeat the previous steps for the remaining wheels.
Posted on Jan 13, 2013
My dyer squeaks
a squeaky dryer means the casting wheels on the dryer are broken and need of replacement their kinda like skate wheels but more durable to stand up to heat however a simple hack such as using metal skate like rollers should help in a far long run
Apr 22, 2017 | Dryers
What is ice skate? And where can I get the ice skates for girls?
ice skating is like roller skating only on ice
ice skates are available from most sports shops
Oct 14, 2016 | Sport & Outdoor - Others
My daughter broke the part of her skates that holds the break can I replace this and if so from where and how
try phoning your local roller skating rink they may have a service to fix skates or will be able to advise where there roller derby skaters get their skates repaired locally.
Aug 23, 2015 | Cycling
Buying roller skate parts can be expensive. How can I prolong the life of my skate wheels?
The inside of the wheels is usually the first to go - you should rotate your wheels so that the worn out edge is on the outside, this will wear the wheels out evenly and they will last longer.
Jan 17, 2013 | Sport & Outdoor - Others
The wheels on my roller skates are vibrating and sluggish when I skate, what could cause this?
. It seems as though your line bearings inside the wheel need to be changed. To do this you should: Use an Allen wrench to remove the axle from the front wheel. Pull out the front wheel. Remove the old bearings from either side of the wheel. They should pop right off if you use a bolt or something similar. Place new bearings on either side of the wheel. If necessary, use a flat surface for extra leverage. Place the wheel in the wheel frame. Use the Allen wrench to replace the axle. If your spacer is aluminium, tighten the axle bolts as far as they will go. If your spacer is plastic, tighten the bolts as far as they will go, then loosen them slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If it wobbles, tighten the axle. Repeat the steps for the remaining wheels.
How to change the line bearings in my skate wheels?
Use an Allen wrench to remove the axle from the front wheel. Pull out the front wheel. Remove the old bearings from either side of the wheel. They should pop right off if you use a bolt or something similar. Place new bearings on either side of the wheel. If necessary, use a flat surface for extra leverage. Place the wheel in the wheel frame. Use the Allen wrench to replace the axle. If your spacer is aluminum, tighten the axle bolts as far as they will go. If your spacer is plastic, tighten the bolts as far as they will go, then loosen them slightly. Spin the wheel to see how easily it rolls. If it doesn't spin freely, loosen the axle. If it wobbles, tighten the axle. Repeat the steps for the remaining wheels.
One of my bower roller skates has a wobbly when can I fix this or will I need to buy a set of wheels?
Jan 13, 2013 | Sport & Outdoor - Others
Dryer sounds like it has a shoe inside. makes thump sounds when running.
does the sound get quieter as it heats up ? if so its likely a drum support (roller) kind of like a roller skate wheel. If sound dosent change after running a while hot you may have a actual drum issue
Aug 06, 2010 | Frigidaire Dryers
I have the cobalt 8.8 and I have had the skates for 4 months and the bottom of the skates cracked on both skates in the same place and tour has not replay to any of my attempts to contact them what should...
I would suggest that you contact the store at which you bought the skates and either get them to exchange them for you or ask them to contact the company for you.
Apr 02, 2010 | Sun Tour Cobalt 8.8 Roller Hockey Skates
Converting Little Tikes Roller Blades
My nephew has these skates and I just converted them from the training position to the inline position. The skates come with a bag of extra parts that you need to make the conversion. Basically you need the same bolt that is used for the first wheel and the middle wheel since the back two wheels are mounted on a long bolt that doesn't work for just one wheel. If you didn't get these spare parts then you're probably out of luck. If you're converting to the inline position you might be able to just use the front and rear positions but the plastic frame may not be strong enough. Good luck!
Mar 04, 2009 | Toys
Sport & Outdoor - Others Logo
473 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
