Question about Sony KP-51HW40 51" Rear Projection Television
How can I clean the gray fabric covering speakers?
I have tried several things but have a couple stains from the kids that will not come out. I would like to take the cover off and spray it good with the hose but not sure if it's possible.
    Scholar:
  • 150 Answers
The cover should be held on by 1/4" hex head screws, you can use a 1/4" nut driver to remove them, I dont know if they are 2 on the bottom or 6 from behind on the sides. then the fun of trying to clean the stains? maybe some hydrogen peroxide?
Posted on Jul 09, 2007
Remove bleach stains
For an immediate treatment of a bleach stain, try Sodium Thiosulfate (often referred to as photographic fixer, it is an agent that has been used as a way to neutralize bleaching effects of other substances. Blot stain at first with a white cloth that has been dipped in ST until stain begins to disappear of fabric becomes saturated. Rinse with cold water and repeat until desired effect or no more progress has been made.
If you wanna get rid of the stain without using laboratory grade chemicals, use white vinegar. Before this, make sure you rinsed bleach out of fabric, if you don't it will release a toxic chlorine gas.
Soak a clean white cloth with vinegar and start blotting stain, keep doing this until fabric won't hold anymore.
Apr 03, 2014 | Clothing
Tip
INK STAIN FABRIC REMOVAL NO PROBLEM
This is a quick and easy way to save you a lot of time and money if you have ever had a dissasterous ink spill on a velour type durable fabric, such as what I experienced in a car Dealership years ago, my new car get ready man sat in a brand new vehicle that had velour seats and forgot he had a pen in his back pocket, when he sat down in the cars seat the pen opened up staining the seat and his uniform real bad!!
Here is what I did.....
we got a lot of plain clean white cotton rags, and a couple of aerosol,cans of "Brake Cleaner" any brand that is the cheapest in price, spray the affected area and blot with a clean rag, use this proceedure over and over until you start to see the stain lifting out off the seat fabric, you know hwen you are done as the last blotting will result in a clean white rag and an impeccably cleaned seat fabric, the only thing that is left behind is a smell from the brake cleaner, let the car air out using a fan and all doors/windows open and after the seat drys use a scented spray on the repaired area, that will not restain the seat cushion again.
The smell will be gone after a couple of days and a little venting of the interior. $10.00 of aerosol cans and white rags versus a t least a couple of hundred dollars in an ordered replacement seat cushion, plus labor.
Have Fun!!!
on Aug 16, 2010 | Ford Crown Victoria Cars & Trucks
Tip
INK STAINED ON YOUR SEAT CUSHION FABRIC, NO TROUBLE
Have Fun!!!
Bleach stains on black jeans
Bleach doesn't stain ! it removes the dye from the fabric.
I would suggest trying to re dye the fabric with a black dye as Jeans material might be more successful .
Synthetic fabric is not as easy to re dye end up using a permanent black marker on Synthetic Shirt that I got bleach on. .
Mar 12, 2014 | Clothing
Do you need to put a cleaning agent on a fabric lounge before using the steam fo the Steam Matey
I would say no, if you have a specialised stain clean that area first. Start with warm soapy water and if that doesn't work use zippo lighter fluid on the stained a area to remove the stain. Zippo lighter fluid is great for removing stains as it is our alcohol. Always try any cleaning agent on an area of the lounge that if it makes the stain worse it won't ruin the lounge I.e under a cushion. When steam cleaning any fabric you should check the fabric specifications to see if its suitable for steam cleaning. Some fabrics like macrosuedes that have a backing on the fabric will delaminate when wet and ruin the fabric.
Aug 30, 2013 | Kitchen Appliances - Others
How to clean suede chair cover?
  • 1 Remove dust from suede by rubbing with a terry cloth towel in a circular motion.
  • 2 Rub smudges, dirt and dried stains with a pencil eraser. Good Housekeeping recommends using a kneadable eraser (available at art supply stores).
  • 3 Sand matted areas by briskly rubbing them with sandpaper or an emery board. This will restore some of the original texture.
  • 4 Dip the towel in white vinegar and gently dab any remaining stains. The suede should appear a slightly darker tan while damp, but not muddy or gray.
  • 5 Allow suede to air dry.
  • 6 Massage the entire surface of the fabric in a circular motion with a suede brush or toothbrush to reestablish a velvety grain.
  • Mar 05, 2013 | Health & Beauty
    My top loader whirlpool (3yrs old) appears to be causing stains: after careful monitoring it appears the fabric softener container conitunes to leak/drip/run down the central column - so staining sheets,...
    You can try a few differnt things, staining is usually caused by not hot enough water to disolve or hard water issues. A Washer cleaning use one gallon white vingar fill up washer with hot HOT water let sit over night than run washer next day on HOT hot. Second try washing in warm to hot water dluting softner more breaks down better. Also dluting the softner more in the cup will help washing in cold causes alot of these issues, Make sure water heater turned up hot enough, make sure washer has hot water fill?
    Aug 23, 2011 | Whirlpool Washing Machines
    "fabric softner staining the clothes"
    make sure you delute it with water. yes fabric softner will start to stain your clothes if you use too much of it. I would recomend stop useing it for a while. so you can clean the washer out. There is a product called Washer magic or Affresh that cleans out residues built up in your washer. or you can just run several loads of HOT water and bleach to clean it out. The hot water will melt the left over fabric softner in your washer. Fabric softner is kind of like hardend bacon fat thats what it looks like in your washer after time and if you do not clean your washer it builds up and builds up.
    Also i do recomend alternating liquid detergent and powdered detergent. The reason why is powder leaves a residue that liquid takes away and vise versa. try this and let me know how it goes
    Feb 12, 2009 | Maytag PAV2300 Top Load Washer
    Whirlpool duet front loader washer/dryer
    It is not the dryer causing the problem. We get the brown streaks on our white clothes before putting them in the dryer. I have ruined more white clothes over the past six months with this Duet washing machine!!! We also don't use bleach so I don't think it is the HE/Clorox combo that somebody mentioned earlier. Anybody know what exactly is causing this yet... before I throught the moldy stain causing Whirlpool duet out?
    Aug 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
    Whirlpool calypso GVW9959Q - Black stains on whites
    At the end of the cycle, the wash plate nutates for
    approximately 30 seconds to fluff the clothing after the
    final spin. The action of fluffing causes the outer wash
    plate seal to rub against the stainless steel basket while
    they are both relatively dry. This condition causes the gray
    discoloration.
    RESOLUTION:
    An updated machine control, part number 8542693, is
    now available. The updated control reduces the fluff time
    from 30 seconds to 8 seconds, allowing the clothing to be
    fluffed, without causing discoloration.
    Gray marks or smudges can be washed out of clothing
    after wiping down the basket. The consumer should use
    the recommended amount of HE detergent and the hottest
    water safe for the fabric or hand wash the garment under
    running water. In either case, the fabric must be cleaned
    prior to running through the dryer
    Feb 14, 2008 | Washing Machines
    Sony KP-51HW40 51" Rear Projection Television Logo
    44 people viewed this question
    Top Sony Televison & Video Experts
    Steve Allison
    Steve Allison
    Jaime Hernandez
    Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
