Question about AEG Lavamat W1450 Front Load Washer
Were are the brushes position
I open the back of the washing machine,help me to find ,were are situated ,grazie carlo
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 25 Answers
In the back end of the motor
Posted on Mar 31, 2013
How to change the brushes
The motor is situated rear centre of the machine. It's best to remove it, either tip it back, ensuring it's stable and supported or remove back panel for access. Brushes are located on either side of the motor.
Mar 23, 2014 | Hotpoint Aquarius WMA42 Front Load Washer
Sul display della ia lavastoviglie whirlpool compare errore F6, che significa? Cosa posso fare? grazie
come fare il reset della scheda della lavastoviglie whirlpool adp 5555
per cancellare l errore e farla ripartire?
Grazie
Oct 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
My washing machine is not spining
It is likely that the Carbon Brushes of your Bosch washing machine need replacement. Get them from your nearest Bosch Spares stockist (P/N: 154740) Replace these on the motor armature, and it will be alright again. To be certain that it is indeed the Carbon brushes, open your washing machine and look on the motor (opposite side of the pulley) There has to be 2 grayish chalk type brushes running on a copper armature, these brushes have a lifetime of about 4 - 6 years before being diminished.
Hope this helps
* If you found this solution helpful, please vote positively.
Feb 18, 2011 | Bosch Washing Machines
I need to know where the filter of my washing machiene is?
Situated in the front, Bottom Right or Left Corner.. Look for a compartment you can flip open.
Good Luck!
Feb 16, 2011 | GE WSXH208A Front Load Washer
Brush relacement in bosch wfl2450 washing machine.
yes the brushes do have to go in a particular direction.
imagine that the flat surface of the brush's angled end has to make full contact with the edge of the circular commutator down inside. Once you've got one brush done, the other one is inserted with its end situated in the opposite way. Like so, sort of: ----\ O \---- !!!!
hope that makes sense
Aug 06, 2009 | Washing Machines
Fitting new belt on hotpoint washing machine
check if plug is loose on motor,in the general area where the belt was changed has anything been disturbed,cables i mean?,sounds like the motor brushes may be worn(this would cause motor to stop),they are situated 180degrees apart at one end of motor,they are easy to change,there is a spot at brushes to put a screwdriver in to remove brushes-hope this helps
May 15, 2009 | Hotpoint Aquarius WMA42 Front Load Washer
No suction
Are you saying that the motor runs but there is no brush rotation ?
If yes then firstly switch machine on then when you pull handle back as if to vacuum the carpet the clutch drive dial must turn to (drive, start, on,) position if it is stuck on (park, off. Stop, p,) position rotate it to drive etc as you pull handle back providing the clutch & both drive belts are ok the brush will spin.
The clutch drive dial knob is situated looking from the front of machine lower left hand side approx 50mm or 2” in diameter.
Please do this test & let me know results
Regards Chris..
Sep 28, 2008 | Dyson DC07 Animal Bagless Upright Cyclonic...
Washing machine brushes
What brushes???????? There are none in the motor...
Feb 10, 2008 | Washing Machines
Asko W620 washing machine not spinning
Sounds like the motor brushes need to be cleaned or replaced. Take the back off the washer, remove the motor and gently scrape the excess carbon or debris off the brushes with a pocket knife. I did this and it ran well for about 50 loads before building back up. I am ordering new brushes now because when I checked the brushes last week they were obviously worn more than 4 weeks ago.
Dec 11, 2007 | Asko W620
AEG Lavamat W1450 Front Load Washer Logo
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
