Question about Leapster Learning System
Hi... I have a leapster which we purchased on march, 2008.Recently, the screen doesnot seem to respond for the stylus. but the button works well. what can we do to fix it? [i live in indonesia]
  • 1 more comment
  • omullens21 Feb 07, 2009
    The touch screen on my leapster does not seem to be working. I tried the recalibration technique but cannot clear the last center cross hair. Any more ideas, please?
  • Anonymous Mar 12, 2009
    I had the same issue and calibrated it according to the solution stated earlier and it worked perfectly.
    Thanks much,
    Scott
  • janineasmith Mar 21, 2009
    I had the same problem and the calibration fixed the problem for me. Thank you for the info!
If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Posted on Jan 31, 2009
How do i recalibrate the leapster gs screen stylus and screen
SolutionIf your Leapster system does not respond to the stylus pen, it needs to be calibrated. To calibrate your Leapster system:
  1. Turn the unit on and wait for the sign-in screen to appear.
  2. Hold down the Home, Hint, and B buttons simultaneously.
  3. When the screen changes, press the A button.
  4. Using the Stylus, touch the center of the targets.
Jan 28, 2013 | LeapFrog Toys
The pen has stopped working when touching the screen
If your Leapster 2 will turn on, but the touch screen is not responding to the stylus, try re-calibrating the stylus with the screen using the steps below: 1. Turn your Leapster 2 off, and remove the game cartridge.
2. Hold down the 'hint' button while the game is off. The 'hint' button is the middle small button in the row of three above the directional pad on the left, with a '?' on it.
3. With your finger still firmly on the 'hint' button, turn the Leapster 2 back on. Keep your finger on the 'hint' button.
4. The screen should be displaying the calibration screen. You can release the 'hint' button now.
5. Press the 'A' button on the right to enter the calibration screen.
6. A small '+' sign will appear on the screen. Touch it with the stylus. A new '+' sign will appear. Touch this with the stylus too, and repeat for as many '+' signs as your Leapster 2 throws at you.
7. The screen will return to the calibration screen. You can now turn the machine off. Leave the cartridge out of the console, and turn it back on.
8. Your stylus and touch screen should now be working, enabling you to sign in as usual.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on
Thank you for using fixya! I hope I had helped you with your problem. May you have a good day!
Mar 28, 2011 | Leapster 2 Handheld Game
The touch screen does not respond to the stylus what can i do?
Welcome to Fixya. If you need to sync the device to the stylus just follow the steps below.
9. If it is working correctly then you can turn it off, add a game cartridge and turn it back on.
Thanks for using Fixya,
Mar 02, 2011 | LeapFrog Leapster 2 Learning System
I recalibrated the leapster2. It recognizes the stylus on the calibration screen. When I reboot it still doesn't recognize the stylus at all. Please help.
If your Leapster does not respond to the stylus pen, it needs to be calibrated.
The following are instructions below on how to recalibrate the leapster.
1. Insert a cartridge, turn the unit on and wait for the sign-in screen to appear.
2. Hold down the Home, Hint and B buttons simultaneously.
Thanks for using Fixya.
Feb 06, 2011 | LeapFrog Leapster Electronic Book:...
Leapster 2 does not respond to the sylus.
I had the same problem. I tried to clean it, brush out crumbs, gently "bleed" it and so on until I saw Quebol96's answer to the same problem: www.fixya.com/support/t3077478-leapster_will_not_recognize_pen_first
Quebol96's solution worked perfectly!
From Quebol96:
Answer If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
Feb 24, 2010 | Leapster Learning System
My daughter has a Leapster 2 that is only about 2 months old and the touch screen does not work
Answer
I had the same problem and here is the answer I found at leapfrog.com which fixed my daughter’s disney princess leapster 2’s problem. Good luck!
5) Restart unit
Jan 30, 2010 | LeapFrog Leapster Learning Game System
Cant sign in
Jul 02, 2009 | LeapFrog Leapster Learning Game System
Hi... I have a leapster whose stylus and screen aren't responding well to each other. For example, in color corral, you can color at the top of the screen, but can't select any tool changes at the bo
Call up Leapster (c/s I reached was not in USA) and they will have you send in your Leapster and send you back a new or refurbished one. I was told this a few years ago, but never mailed it in. We had an issue with it shutting off, but seems to be ok? The kid's don't complain.
May 31, 2009 | Leapster Learning System
Leapster screen not responding to the stick
If you don't see any X's then you have to clean the screen very well with some Windex and dry it well. Take any crumbs out of the screen edges and then "milk" the screen with the thumb gently. What happens is that the digitizer gets pressure areas built up so you want to dislodge it. You might need 3-4 "milking" tries. By milking I mean pressing on the screen with the thumb (gently) till you see the screen "bleed."
Also after this align the screen.
Jan 23, 2009 | Leapster Learning System
Leapster doesn,t respond when the pen touch screen
for leaster 2 -
turn off unit, take out cartridge.
hold the hint button, turn unit on.
press A button, touch the stylus on all the cross hairs that appear.
power unit off when done.
power back up.
(got these from the leapfrog site and it worked for me!)
Sep 29, 2008 | LeapFrog Leapster Electronic Book:...
Leapster Learning System Logo
686 people viewed this question
Top Leapster Toys Experts
thegtw
Michael Vincent Cruz
Dennis Crouse
Are you a Leapster Toy Expert? Answer questions, earn points and help others
